Making a Mutator(Non-MTL branched)
Postby Allan » Fri Feb 03, 06 2:58 pm
Right, i'm planning to try and make a mutator, and i'm stuck for how to even start with it...
If someone would give me a hand with making a basic Non-MTL mutator, i'll be most grateful :)
Postby Gishank » Fri Feb 03, 06 3:37 pm
Why not make it mtl based?
Postby ~ô¿ô~Nobody~ » Fri Feb 03, 06 7:04 pm
because not everyone is called klop and knows everything :P
@allan: actually everyone just makes mutators not basing on MTL
if you create a class like
class MyMutator extends Mutator
then it is not based on MTL
to make it possible to base a Mutator on MTL you needed to use the MTL extender pack © [A]Nobody
Postby Cozmo » Fri Feb 03, 06 7:29 pm
the MTL Extender pack......... is?........
Postby Alex » Fri Feb 03, 06 7:30 pm
A pack which enables you to use DXMTL152b1.u in your mod. Not really required for mods.
Postby Cozmo » Fri Feb 03, 06 7:31 pm
~[A]lex~ wrote:A pack which enables you to use DXMTL152b1.u in your mod. Not really required for mods.
Eh? thats just what i need! so a gametype could expand the mtl game?
Postby Alex » Fri Feb 03, 06 7:32 pm
I don't think you are able of making a gametype...
Postby ~ô¿ô~Nobody~ » Fri Feb 03, 06 7:35 pm
he wanted to say that this is the ticket to make a MTL based gametype
however.. it's a bit more advanced to make a new gametype anyways (undependent of MTL)
if you know how to make a normal new gametype you can do a MTL based one with the extender pack too (it's just a little bit more advanced)
Postby Alex » Fri Feb 03, 06 7:36 pm
I suggest making a new gametype not based on DXMTL first, when you managed to do that, come back to the topic of "I want the MTL extender so I can make a MTL based gametype"
Postby MainMan » Fri Feb 03, 06 8:07 pm
Yeah, almost all mutators are not based on mtl. (apart from the ones included in DXMTL, such as anti cheat etc.)
Your every-day mutator has nothing to do with mtl.
Postby Gishank » Fri Feb 03, 06 8:09 pm
Can someone make a topic on the basics of making a mutator. Seeming as i haven't made one before please?
Postby Allan » Fri Feb 03, 06 9:16 pm
Huh? How did the topic change to Gametypes instead of Mutators... Well, any of you guys reccomend any websites for making mutators for Deus Ex?
Postby Cozmo » Fri Feb 03, 06 11:34 pm
Yeah ive made a gametype before with new playerclasses edited dx.ini and it all works but in game it just says the basic deus ex gametypes on the multiplayer menu
~[A]lex~ wrote:I don't think you are able of making a gametype...
Im not absolutely daft...
Yes i am a bad coder but it compiles =]
Postby ~ô¿ô~Nobody~ » Sat Feb 04, 06 12:10 am
indeed, you don't need to be an [A]lex to make a new gametype :P
Postby Alex » Sat Feb 04, 06 9:41 am
Correct, but actually making an MP gametype is a bit harder than SP I'm afraid...
Postby Gishank » Sat Feb 04, 06 9:44 am
<~>K}Ã?Ã?<~> wrote:Can someone make a topic on the basics of making a mutator. Seeming as i haven't made one before please?
Postby Allan » Sat Feb 04, 06 4:35 pm
This is just a stupid quick piece of mutator code, but can someone tell me if it would work, and how to get it set up for DXMP?
// CarcassRemover.
class CarcassRemover expands Mutator;
Var DeusExCarcass C;
Function PostBeginPlay()
   foreach AllActors( class 'DeusExCarcass', C )
         C.Destroy();
Postby MainMan » Sat Feb 04, 06 4:40 pm
that will only delete the carcasses that are already in the map at the beginning. (i'm not sure why you would have them anyway)
Postby Allan » Sat Feb 04, 06 4:48 pm
Doh! There has got to be an easier way of making mutators than this hit-and-miss crap i seem to be doing...
Postby MainMan » Sat Feb 04, 06 4:54 pm
well what do you want to do? Make it like in dxag, so the player doesnt have a carcass? (without changing the player class)
