Alrightythen
Alrightythen
Postby Spiderbot01 » Fri Feb 10, 06 7:12 pm
Unless Alrightythen turns up I have a question, I recently added poolparty to the server and editor packages because I wanted to host the poolparty map (which for the record didnt work) so I looked at what was in poolparty.u in unreal ed, I dont understand the code that comes up in the blue box, so I was wondering if anyone knew for example Shop Hiedout and OwnedSwitch what they did and if I were to use them what I should use them for? Especially [A]nobody as I was under the impression you two worked together on mods for a while...
Postby Gishank » Fri Feb 10, 06 7:22 pm
Simple solution....
Add it to a map and use it lol.
Or...
Open WOTGreal and look at the uc files code he should of put notes in on what it does.
