Coding screw up.
Coding screw up.
Postby Gishank » Sat Mar 25, 06 1:56 pm
Ok, i was making a weapon which shoots vase's for a laugh but it doesn't work the weapon doesn't shoot. The projectile's correct (I think) neways heres the code.
Proj:
// ProjVase= Vase Projectile
class ProjVase expands Shuriken;
    mpDamage=100.00
    spawnWeaponClass=Class'DeusExDeco.WHRedVase'
    ItemName="|p4Throwable |p3Vase"
    speed=100.00
    MaxSpeed=1000.00
    Damage=100.00
    Mesh=LodMesh'DeusExItems.WHRedVase'
WeaponThrowableVase:
// Throwable Vase - ProjWHREDVASE!.
class WeaponThrowVase expands WeaponShuriken;
    ProjectileClass=Class'BlueKnuckles.ProjVase'
    ItemName="Throwable Vase"
    PlayerViewMesh=LodMesh'DeusExDeco.WHRedVase'
    PickupViewMesh=LodMesh'DeusExDeco.WHRedVase'
    ThirdPersonMesh=LodMesh'DeusExDeco.WHRedVase'
    Icon=Texture'DeusExUI.Icons.BeltIconDragonTooth'
    Description="A throwable Vase.'"
    beltDescription="|p2Throw Vase"
It's proberly somthing obvious which i've missed out.
Postby Allan » Sat Mar 25, 06 6:17 pm
if a weapon's bHandToHand is true(Like with WeaponShruiken), more often than not the player mesh has to have some kind of animation. Dunno why, just does...(Not certain on this)
Also, the spawnWeaponClass needs to actually be a weapon, it was just a mesh before :P .
Try this code:
    mpDamage=100.00
    spawnWeaponClass=Class'YourMod.WeaponThrowVase'
    speed=100.00
    MaxSpeed=1000.00
    Damage=100.00
Also, Try adding bHandToHand=False in the actual weapons default properties.
DeusExItems is for item meshes, like pickups, etc. I think you meant DeusExDeco, so i changed it.
Postby Gishank » Sat Mar 25, 06 6:24 pm
Lol, so obvious. Thanks.
Postby Gishank » Sun Mar 26, 06 9:31 am
Sorry for the double post but i still have the problem.
Postby Allan » Sun Mar 26, 06 3:08 pm
Try setting the weapons bHandToHand to false, that's the only other thing i see wrong with it, unless you actually left the last code with YourMod om it instead of BlueKnuckles (I didn't notice that the name was there before...)
// ThrowingFlasks.
class ThrowingFlasks expands DeusExWeapon;
simulated function PreBeginPlay()
//Override any unneeded defaults.
simulated function bool TestMPBeltSpot(int BeltSpot)
   return (BeltSpot >=4 && <=6);
     bInstantHit=False
     bAltInstantHit=False
     bUnlit=True
     bHasMuzzleFlash=False
     GoverningSkill=Class'DeusEx.SkillWeaponLowTech'
     HitDamage=100
     InventoryGroup=124
     maxRange=1800
     AccurateRange=1500
     ProjectileNames(0)=Class'BlueKnuckles.ProjVase'
     bHandToHand=False
     AmmoName=Class'DeusEx.AmmoNone'
     ReloadCount=1
     PickupAmmoCount=20
     LowAmmoWatermark=4
     InventoryGroup=205
     beltDescription="B-DESC"
     ItemName="Name"
     Description="Description"
     largeIconWidth=36
     largeIconHeight=45
     CollisionRadius=5.000000
     CollisionHeight=12.000000
     PlayerViewOffset=(X=30.000000,Y=0.000000,Z=-5.000000)
     largeIcon=Texture'DeusExUI.Icons.LargeIconShuriken'
     Icon=Texture'DeusExUI.Icons.BeltIconShuriken'
That code should sort you out :) , just put it over the weapon code that you had, change the bits you want, and you'll be ready to go :D . And i just noticed, your vases will stick to the walls XD !!
Users browsing this forum: No registered users and 134 guests
