SDK Right click error >.>
Postby Gishank » Wed Aug 16, 06 8:51 am
Right i can use SDK all well etc, but i really need to fix this bug other wise i'm fucked, and can't be arsed anymore, because if i right click in any of the four editing windows, it takes forever to right click, even when the window has appereard it is buggy :-/ Help?
Postby Wise Man - 2 WAIZ 4 U » Wed Aug 16, 06 9:56 am
Is this to blame for the fact that you've applied for clans claiming mapping skills, and never had any evidence?
Now i'll wait for a witty response from another spectator.
Postby Gishank » Wed Aug 16, 06 10:08 am
Excuse me? I can map, maybe if you helped fixed this bug and shut your trap i will show you some.
Postby Spiderbot01 » Wed Aug 16, 06 10:11 am
Yeah wasn't it you that said:
Im aM Da PwNAgE aT SdK!!11one
Klop it could just be something to do with your computer itself. If all else fails... Reinstall!
Postby Gishank » Wed Aug 16, 06 10:14 am
Nope, that was wasted.
I'm not re-installing windows... :P Maybe SDK....
Postby DarkKnight » Wed Aug 16, 06 10:18 am
Go into start -> run -> type dxdiag
Click on "Save all information".
Post the contents of the text file you just saved.
Postby Spiderbot01 » Wed Aug 16, 06 10:28 am
No it was Wise man that said that Klop I didn't mean you >_>
Postby Gishank » Wed Aug 16, 06 10:28 am
System Information
Time of this report: 8/16/2006, 10:23:25
Machine name: KLOPSPC
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 1 (2600.xpsp2.050301-1526)
Language: English (Regional Setting: English)
System Manufacturer: eMachines, Inc.
System Model: Imperial
BIOS: Revision 0.90
Processor: Intel(R) Celeron(R) CPU 2.20GHz, ~2.2GHz
Memory: 1GB RAM
Page File: 255MB used, 562MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0904 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce4 MX 440
Manufacturer: NVIDIA
Chip type: GeForce4 MX 440
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0171&SUBSYS_84701462&REV_A3
Display Memory: 64.0 MB
Current Mode: 800 x 600 (32 bit) (75Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.4523 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 7/28/2003 15:19:00, 3902603 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 7/28/2003 15:19:00, 1341339 bytes
Device Identifier: {D7B71E3E-4231-11CF-7966-7AA402C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0171
SubSys ID: 0x84701462
Revision ID: 0x00A3
Revision ID: 0x00A3
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24C2
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/29/2002 01:32:50, 51968 bytes
| Driver: usbd.sys, 8/18/2001 13:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/29/2002 02:06:38, 51072 bytes
| Driver: kbdclass.sys, 8/29/2002 01:27:02, 23424 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/29/2002 03:46:42, 38024 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 8/29/2002 03:50:10, 22016 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x1241, 0x1166
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 8/18/2001 13:00:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Generic SoftK56
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: Internet Ethernet - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Praetorians (DX7) - Registry: OK, ExeFile: Praetorians.exe ()
Praetorians Multiplayer Demo (DX7) - Registry: OK, ExeFile: Praetorians.exe ()
Star Wars Galactic Battlegrounds (DX7) - Registry: OK, ExeFile: battlegrounds.exe (1.00.0000.0000)
Star Wars Galactic Battlegrounds: Clone Campaigns (DX7) - Registry: OK, ExeFile: battlegrounds_x1.exe (1.01.0000.0000)
Total Annihilation (DX7) - Registry: OK, ExeFile: TOTALA.EXE (<File Missing>)
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 35.6 GB
Total Space: 57.3 GB
File System: NTFS
Model: SAMSUNG SV0602H
Drive: D:
Model: SAMSUNG CDRW/DVD SM-348B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.1106 (English), 8/29/2002 01:27:56, 47488 bytes
System Devices
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_8086&DEV_2561&SUBSYS_00000000&REV_03\3&61AAA01&0&08
Driver: C:\WINDOWS\System32\DRIVERS\pci.sys, 5.01.2600.1106 (English), 8/29/2002 01:09:12, 62976 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_8086&DEV_2560&SUBSYS_00000000&REV_03\3&61AAA01&0&00
Driver: n/a
Name: Intel(r) 82801DB/DBM USB 2.0 Enhanced Host Controller - 24CD
Device ID: PCI\VEN_8086&DEV_24CD&SUBSYS_3186109F&REV_02\3&61AAA01&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 19328 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:52, 135552 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 51968 bytes
Driver: C:\WINDOWS\System32\hccoin.dll, 5.01.2600.1106 (English), 8/29/2002 03:40:56, 5120 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 23:36:34, 67072 bytes
Name: Intel(r) 82801DB Ultra ATA Storage Controller-24CB
Device ID: PCI\VEN_8086&DEV_24CB&SUBSYS_3186109F&REV_02\3&61AAA01&0&F9
Driver: C:\WINDOWS\System32\DRIVERS\intelide.sys, 5.01.2600.1106 (English), 8/29/2002 02:27:48, 4736 bytes
Driver: C:\WINDOWS\System32\DRIVERS\pciidex.sys, 5.01.2600.1106 (English), 8/29/2002 01:27:48, 23680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\atapi.sys, 5.01.2600.1106 (English), 8/29/2002 01:27:50, 86912 bytes
Name: Intel(r) 82801DB/DBM USB Universal Host Controller - 24C7
Device ID: PCI\VEN_8086&DEV_24C7&SUBSYS_3186109F&REV_02\3&61AAA01&0&EA
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 19328 bytes
Name: Multimedia Audio Controller
Device ID: PCI\VEN_8086&DEV_24C5&SUBSYS_3186109F&REV_02\3&61AAA01&0&FD
Driver: n/a
Name: Intel(r) 82801DB/DBM USB Universal Host Controller - 24C4
Device ID: PCI\VEN_8086&DEV_24C4&SUBSYS_3186109F&REV_02\3&61AAA01&0&E9
Name: SM Bus Controller
Device ID: PCI\VEN_8086&DEV_24C3&SUBSYS_3186109F&REV_02\3&61AAA01&0&FB
Driver: n/a
Name: Intel(r) 82801DB/DBM USB Universal Host Controller - 24C2
Device ID: PCI\VEN_8086&DEV_24C2&SUBSYS_3186109F&REV_02\3&61AAA01&0&E8
Name: PCI standard ISA bridge
Device ID: PCI\VEN_8086&DEV_24C0&SUBSYS_00000000&REV_02\3&61AAA01&0&F8
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/18/2001 13:00:00, 35840 bytes
Name: Intel(R) 82801BA/CA PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_82\3&61AAA01&0&F0
Device ID: PCI\VEN_14F1&DEV_2F00&SUBSYS_8D8B155D&REV_01\4&3B90381F&0&58F0
Driver: n/a
Name: Realtek RTL8139 Family PCI Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_3186109F&REV_10\4&3B90381F&0&10F0
Driver: C:\WINDOWS\System32\DRIVERS\RTL8139.sys, 5.396.0530.2001 (English), 8/17/2001 13:12:42, 23070 bytes
Name: NVIDIA GeForce4 MX 440
Device ID: PCI\VEN_10DE&DEV_0171&SUBSYS_84701462&REV_A3\4&3839C141&0&0008
Driver: C:\WINDOWS\System32\DRIVERS\nv4_mini.sys, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 1341339 bytes
Driver: C:\WINDOWS\System32\nvinstnt.dll, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 126976 bytes
Driver: C:\WINDOWS\System32\nvsvc32.exe, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 77824 bytes
Driver: C:\WINDOWS\System32\nv4_disp.dll, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 3902603 bytes
Driver: C:\WINDOWS\System32\nvoglnt.dll, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 3850240 bytes
Driver: C:\WINDOWS\System32\nvcpl.dll, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 4841472 bytes
Driver: C:\WINDOWS\System32\nvmctray.dll, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 49152 bytes
Driver: C:\WINDOWS\System32\nview.dll, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 852038 bytes
Driver: C:\WINDOWS\System32\nvwddi.dll, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 45127 bytes
Driver: C:\WINDOWS\System32\dmcpl.exe, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 1323008 bytes
Driver: C:\WINDOWS\System32\nvshell.dll, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 471112 bytes
Driver: C:\WINDOWS\System32\nvtuicpl.cpl, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 143360 bytes
Driver: C:\WINDOWS\System32\nwiz.exe, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 323584 bytes
Driver: C:\WINDOWS\System32\nviewimg.dll, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 512000 bytes
Driver: C:\WINDOWS\System32\keystone.exe, 6.14.0010.4523 (English), 7/28/2003 15:19:00, 286806 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 7/28/2003 15:19:00, 52951 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 7/28/2003 15:19:00, 22977 bytes
Driver: C:\WINDOWS\nview\generic.tvp, 7/28/2003 15:19:00, 30902 bytes
DirectX Components
ddraw.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 292864 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 10496 bytes
d3d8.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 1201152 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes
d3d9.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 1703936 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 436224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/18/2001 13:00:00 33040 bytes
dplayx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 230400 bytes
dpmodemx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 77824 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/18/2001 13:00:00 42768 bytes
dpwsockx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 79360 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 723968 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 381952 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/18/2001 13:00:00 53520 bytes
dinput.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:50 151552 bytes
dinput8.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:50 168960 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 467968 bytes
joy.cpl: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:28 65536 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 223232 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:50:10 31744 bytes
dsound.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 381952 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 491520 bytes
dmusic.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 122880 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes
dmime.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 181248 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 1769472 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/18/2001 13:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 8/18/2001 13:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 English Final Retail 8/18/2001 13:00:00 21504 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes
devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 132608 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/29/2002 03:40:52 498205 bytes
mciqtz.drv: 4.00.0096.0729 English Final Retail 8/17/1998 10:21:54 11776 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 173056 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 257024 bytes
qdv.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28 316928 bytes
qdvd.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28 470528 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 1798144 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0907 English Final Retail 8/30/2005 09:14:00 1227776 bytes
quartz.vxd: Final Retail 8/17/1998 10:21:56 5672 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/29/2002 03:41:18 251904 bytes
vidx16.dll: 0.00.0000.0000 English Final Retail 8/17/1998 10:21:56 10240 bytes
iac25_32.ax: 2.00.0005.0054 English Final Retail 6/23/2000 14:06:08 192000 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 6/22/2000 13:49:24 842240 bytes
ir50_32.dll: 5.2819.0015.0056 English Final Retail 6/23/2000 10:36:48 745984 bytes
ivfsrc.ax: 5.11.0015.0056 English Final Retail 6/22/2000 18:11:56 145408 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 324096 bytes
ks.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 48512 bytes
mspclock.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896 bytes
kstvtune.ax: 5.03.0001.0904 English Final Retail 7/19/2004 16:19:30 285696 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 04:26:38 39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 226304 bytes
vfwwdm32.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:18 49664 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 04:26:38 52096 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.0000.0900
CC Decoder,0x00200000,2,1,,5.03.0000.0900
WST Codec,0x00200000,1,1,,5.03.0000.0900
DirectShow Filters:
WMAudio Decoder DMO,0x00600800,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
MSScreen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Logitech Video/Audio Tee,0x00200000,1,1,vatee.ax,8.04.0003.1005
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0907
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0904
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0907
WM ASF Reader,0x00400000,0,0,qasf.dll,6.05.0001.0900
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0907
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0907
Indeo® Video 5.11 Compression Filter,0x00200000,1,1,IR50_32.DLL,5.2819.0015.0056
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
StreamBufferSink,0x00200000,0,0,sbe.dll,6.04.2600.1106
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0907
Indeo® Video 5.11 Decompression Filter,0x00640000,1,1,IR50_32.DLL,5.2819.0015.0056
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0907
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0907
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
Internal LMRT Renderer,0x00800001,1,0,LMRTREND.dll,6.00.0004.0827
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0907
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0907
File Source (Netshow URL),0x00400000,0,1,dxmasf.dll,6.04.0009.1125
TrueMotion 2.0 Decompressor,0x00600001,1,1,tm20dec.ax,1.00.0000.0001
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0904
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0907
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Windows Media Multiplexer,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASX file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASX v.2 file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1125
NSC file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0907
Windows Media source filter,0x00600000,0,2,dxmasf.dll,6.04.0009.1125
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0907
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.04.2600.1106
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0904
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0907
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0907
WM ASF Writer,0x00400000,0,0,qasf.dll,6.05.0001.0900
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0904
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0904
Cutlist File Source,0x00200000,0,1,qcut.dll,6.00.0002.0902
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0907
.RAM file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1125
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0904
Windows Media Update Filter,0x00400000,1,0,dxmasf.dll,6.04.0009.1125
ASF DIB Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASF ACM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASF ICM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASF URL Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASF JPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASF DJPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASF embedded stuff Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
URL StreamRenderer,0x00600000,1,0,LMRTREND.dll,6.00.0004.0827
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.11.0015.0056
StreamBufferSource,0x00200000,0,0,sbe.dll,6.04.2600.1106
WMP CD Filter,0x00600000,0,1,wmpcd.dll,8.00.0000.4487
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0904
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0907
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0907
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0907
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0907
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0907
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0907
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0907
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0907
XML Playlist,0x00400000,1,0,dxmasf.dll,6.04.0009.1125
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0907
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0907
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0907
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0907
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0907
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.0000.0900
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.0000.0900
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0904
Indeo® Video 5.11 Compression Filter,0x00100000,1,1,IR50_32.DLL,5.2819.0015.0056
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0907
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
Logitech Video (I420),0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Ligos Indeo® Video 5.11,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0907
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0907
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0907
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.0001.0907
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0907
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0907
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0907
MSN Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.0001.0907
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0907
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0907
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0907
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0907
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0907
WDM Streaming Capture Devices:
Labtec webcam plus,0x00200000,0,2,,5.03.0000.0900
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.0000.0900
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Video Capture Sources:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00200000,0,0,encdec.dll,6.04.2600.1106
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.04.2600.1106
XDS Codec,0x00200000,0,0,encdec.dll,6.04.2600.1106
WDM Streaming Communication Transforms:
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0907
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0907
BDA Receiver Components:
BDA Slip De-Framer,0x00600000,1,1,,5.03.0000.0900
As you can see my pc is gay.
Postby ICE » Wed Aug 16, 06 10:33 am
How do u know if your pc is female or male anyway because my pc is gay aswell but it will no longer be after my reformat.
ЛЕДImage
The recent message was not spam but was a topic warmer and the message was copyrighted for eternity!Im in czech at the moe.
ICE
Postby Gishank » Wed Aug 16, 06 10:35 am
I formatted, but i lost my old CD, so i had to get a fake off my mates bro... Then i had to wait about 2 months for the CD key -.-"
Postby DarkKnight » Wed Aug 16, 06 11:34 am
Sh¤gån wrote:I formatted, but i lost my old CD, so i had to get a fake off my mates bro... Then i had to wait about 2 months for the CD key -.-"
Ouch at the graphics card and cpu you have...
Postby Allan » Wed Aug 16, 06 11:40 am
I have better graphics power on this thing! *Points to old, beat up computer in my parents room with a 128MB graphics card in, which set me back £90(Including installation)*
Still, at least you've got a better G-Card than I used to using UEd. I used to have an 8mb... *Oddly, it was able to bypass all checks for G-Card memory though...* Even now, this error frequents moi. What I do is:
Save whatever I'm working on(Script or level).
Then, instead of closing UEd in normal fashion, close it using Task Manager. For some reason, this patches it up for me every time =)
Postby Gishank » Wed Aug 16, 06 12:11 pm
My pc was made in 2001 before that it was a Win '98. Meh, "trys what allan says"
EDIT: Nope :'(
Postby Bob » Wed Aug 16, 06 5:22 pm
Restart your pc.
UEd eats RAM by the bucket loads.
Postby Gishank » Wed Aug 16, 06 5:24 pm
Erm, nope that won't work, i've restarted 3 times after this started happening.
Postby Magus » Mon Aug 21, 06 11:04 pm
Then get a better comp, you retarded idiot. Celerons suck.
Admin: no flaming.
Magus
Postby MainMan » Mon Aug 21, 06 11:08 pm
Magus wrote:Then get a better comp, you retarded idiot. Celerons suck.
Your maps are crap - you're far from being a "map wizard", so shut up please.
Postby Allan » Mon Aug 21, 06 11:32 pm
Magus wrote:Celerons suck.
By the nature of their creation, they suck.
Intel Celeron chips is the market name for what is their "Reject Bin" of sorts. Any processors that fail to meet the needs of the current Pentium batch for one reason or another gets effectively recycled, stuff not used due to its failures taken out, and sold on. So, considering you're PC was made in 2001... You have a failed original class P4 running your PC.
Postby DarkKnight » Mon Aug 21, 06 11:41 pm
The Celeron is meant to be a low-cost high yield chip. It's really not meant to break any speed barriers. =/
http://www.tweaktown.com/articles/879/1 ... index.html
F.E.A.R breaks the balls of most CPU's, but murders the Celereon/Sempron. =/
Postby Gishank » Tue Aug 22, 06 8:42 am
Magus. How the fuck do you think i'm going to get a new computer, i don't have a forest of money trees ya'know.
Postby Magus » Tue Aug 22, 06 12:44 pm
Oh yea, I forgot they don't let retarded people get well-paid jobs. -.-
Magus
Postby Gishank » Tue Aug 22, 06 12:48 pm
Rofl.... I'm 13, i can't get a job... now whos the retard...
Postby Alex » Tue Aug 22, 06 12:49 pm
Sh¤gån wrote:Rofl.... I'm 13, i can't get a job... now whos the retard...
I'm 16 I started working when I was 14, now I earn $400 a month. Don't whine. You can always get a job.
Postby Gishank » Tue Aug 22, 06 12:51 pm
The only job i can do at the age of 13 is paper boy. And fuck i'm not getting up 3 hours earlier every day just to earn £3.00 a month.
Postby Alex » Tue Aug 22, 06 12:52 pm
Sh¤gån wrote:The only job i can do at the age of 13 is paper boy. And fuck i'm not getting up 3 hours earlier every day just to earn £3.00 a month.
Create your own job? I did that when I was... 9, earned couple of euro's a week with it.
I made some kind of kids-newspaper, if I remember correctly. It was quite popular, almost every kid wanted one.
And after that, I washed cars, just look at your 'customers' with a sweet smile, and they pay you $20 a car.
Postby Gishank » Tue Aug 22, 06 1:00 pm
I tried the paper idea ages ago, yet people wouldn't pay 50p for it :-/
Postby Alex » Tue Aug 22, 06 1:00 pm
Sh¤gån wrote:I tried the paper idea ages ago, yet people wouldn't pay 50p for it :-/
Your neighbourhood sucks
Postby Gishank » Tue Aug 22, 06 1:04 pm
Agreed. Lol, meow.
Postby Spiderbot01 » Tue Aug 22, 06 1:18 pm
May I just say OVER PRICED CAR WASHING FTW :]
Postby Alex » Tue Aug 22, 06 1:19 pm
Spiderf[A]g01 wrote:May I just say OVER PRICED CAR WASHING FTW :]
some even give $30 ^_^, and taking glass bottles away (Like, to around the corner, 5 minute's work), 5$ =)
