UnrealScript / a few tricks mostly for mutators
Postby Dae » Tue Aug 22, 06 12:29 pm
Taken from alpha labs private:
If a mutator is supposed to work only on a specific map, that's how you can teach it recognising maps:
if ( Level.NetMode != NM_Standalone )
   switch LevelString
      case "DXMP_CMD.LevelInfo0":
      // Actions only for DXMP_CMD
      break;
      case "DXMP_Area51Bunker.LevelInfo0":
      // Actions only for DXMP_Area51Bunker
      break;
If you're planning to make functions of your mutator recognise user typed string, like, for example, user ID on the server (MMSwitcher), that's how you can do it:
function Mutate (String S, PlayerPawn Player)
   local string usrstr;
   // The following code will obtain everything user
   // typed after command "mutate typed". If you
   // typed "mutate typed blah", it should return "blah"
   // in a client message
   if (mid(S, 0, 5) ~= "typed ")
      usrstr = mid(S, 5);
      Player.ClientMessage("You typed"@usrstr);
   Super.Mutate(S,Player);
The essence of MMSwitcher - the code of switching player's team without killing him or her and with updating his or her user.ini. Team IDs:
0 - UNATCO
1 - NSF
local pawn victim;
Level.Game.ChangeTeam(victim,0); // set to needed team
PlayerPawn(victim).ClientChangeTeam(0); // set to needed team
That's how we can find a suitable for spawning spawn point (thanks to Nobody for the code):
local navigationpoint navpoint;
navpoint=Level.Game.FindPlayerStart(victim,0);
// Move victim to it
victim.setLocation(navpoint.location);
If you want to erase all augs and to add a specific one, that's how you can do it (this is what me and Alex coded for upcoming mutator against dejavu's program which kills 0aug servers. However, this method will not be used in the mutator by other reasons).
local augmentation aug;
DeusExPlayer(Owner).AugmentationSystem.ResetAugmentations();
aug = DeusExPlayer(Other).AugmentationSystem.Spawn(class'DeusEx.AugLight', DeusExPlayer(Other).AugmentationSystem);
DeusExPlayer(Other).AugmentationSystem.FirstAug = aug;
DeusExPlayer(Other).AugmentationSystem.GivePlayerAugmentation(class'DeusEx.AugLight');
