I hate movers! Help! How to Use!
Postby Aidan » Sat Sep 16, 06 6:11 am
Hey, I opened this topic to ask, how the hell to work a dx mover! i've been at it for months, browsed every site available. Please don't give me a link to another mover site unless it can solve this problem...
At the stage when you resize your building brush and intersect with the blue brush, create a DXMover. Then, move the red and blue brush out of the way leaving the purple brush (DXMover). After I do these steps, rebuild geometry, save my test level (for my mover) and then go to play it, I seem to walk right through my door and then when I go to turn around and walk back, it's like there's some invisible one-way forcefield that keeps me from moving back. When I run and jump back, when I jump, I stick to a part of the forcefield suspending in mid-air, and when I let go of my "w" button (forward button) I fall back down. This may be really fucked up but could someone plz help? :(
Postby Dae » Sat Sep 16, 06 6:48 am
If you resize your mover with a "Scale" tool, you should set "transform permanently" flag for the brush. I'm not sure if this is what you need, so please, enclose here a map file with your mover.
Postby Aidan » Sat Sep 16, 06 7:44 am
Thanks Dae, hope you figure out what the problem is.
pshycotest.dx
(9.34 KiB) Downloaded 277 times
Postby Dae » Sat Sep 16, 06 8:14 am
I changed some textures to more accurate ones, but the actual solution is, what I said, to set "transform permanently" flag (see attachment). Also your mover was located in "additive" brush, I wonder why.
Btw this flag was a kind of invention for me when i started mapping. When i copied things from other maps (original singleplayer ones), I couldn't rotate them, because they had been resized by mappers with "Scale" tool and "transform permanently" allowed me to rotate them with no problems.
pshycotest.dx
Now - fixed.
(7.59 KiB) Downloaded 272 times
That's the solution.
(63.96 KiB) Downloaded 308 times
Postby Aidan » Sat Sep 16, 06 8:18 am
Thanks so much dea, so let me get this through my head. After I make the mover, I select it and choose "transform perminently"? :?
Postby Dae » Sat Sep 16, 06 8:26 am
PsHyCo)(K!//3R wrote:After I make the mover, I select it and choose "transform perminently"? :?
Yes, but only if you used scaling.
Postby Aidan » Sat Sep 16, 06 8:28 am
ok! thanks again! :mrgreen:
Postby MainMan » Sat Sep 16, 06 8:54 am
The easiest way however, is when you make the brush for the mover (the blue brush), right click it, and click 'Copy Polygons To Brush'. Then delete the blue brush (it should already be selected, so just press 'Del', and then add your mover. (do not move the red brush)
Postby Aidan » Sat Sep 16, 06 9:01 am
oh no! another problem has occured! When I make the mover that you press the switch and it moves up and down, half of it, I just walk right through when the other half, there is the invisible forcefield once again :cry: [It's the one with the huge button]
pshycomap.dx
ARGGGHHHH!!
(10.37 KiB) Downloaded 272 times
Postby Dae » Sun Sep 17, 06 6:14 am
1. Right click > Movers > Show Polys
2. Right click > Transform > Transform Permanently
Actually I didn't know till now that I needed to perform also "Show polys". I wonder how would original SDK fans solve this problem :P
Edit: fixed a mistake.
pshycomap.dx
(10.62 KiB) Downloaded 267 times
Postby Aidan » Sun Sep 17, 06 7:25 am
Thanks again dea, Ill keep this in mind for next time. But there's one small problem...theres no "movers" option on unrealed2 when you right click a mover, is there another way to fix the problem, or do you know where I could get my hands on a copy of the Original SDK?
Postby Dae » Sun Sep 17, 06 8:13 am
No movers option? Then what are other options in that menu?
Postby Aidan » Sun Sep 17, 06 8:29 am
yeah, unrealed2 kinda sucks, what do I do? do I get the Original Unreal ed?
(840.66 KiB) Downloaded 238 times
Postby clyzm » Sun Sep 17, 06 8:31 am
Maybe it's not "mover" but "deusexmover"...
I'm not sure, been a while since I mapped.
Postby Aidan » Sun Sep 17, 06 8:41 am
the only way you could get a "deusex mover properties" option is if you choose the "deusex mover" class before you create the mover, but even then you wont get a drop down box to select "Show Polys". Oh well, lol :D lets see what dea has to say..
THIS IS FRUSTERATING!!!!!!!!!!!!
Postby Spiderbot01 » Sun Sep 17, 06 10:15 am
~[A]Daedalus~ wrote:I changed some textures to more accurate ones, but the actual solution is, what I said, to set "transform permanently" flag (see attachment). Also your mover was located in "additive" brush, I wonder why.
Is that why when you try and rotate stuff, the brushes randomly change shape/position? How do you sort this?
Postby Aidan » Sun Sep 17, 06 10:25 am
I'm not sure, lol, lets wait and see what dea says :)
Postby Dae » Sun Sep 17, 06 10:26 am
Yes, hit "transform permanently" and they won't.
)P(sHyCo)(K!//3R
Man, you use original Software Development Kit = SDK = UnrealEd1. The icon of UnrealEd2 is green.
Btw, I'm Dae, not dea
Postby Aidan » Sun Sep 17, 06 10:31 am
Sorry, Geez, anyways thanks Dea
Postby MainMan » Sun Sep 17, 06 10:41 am
Look, seriously, forget all this resizing stuff, to make a mover, do this:
1. Build a box, height 128, width 64, depth 16.
2. Click 'Add Brush'.
3. Move the Red brush out of the way.
4. Select the newly made blue brush (the 128*64*16 one that you added).
5. Right click on it, and select 'Copy polygons' then 'to brush'.
6. Hit the 'Delete' key on your keyboard, and press yes when the box comes up to ask if you are sure. (this will delete the blue brush, since it was already selected.)
7. Press 'Add mover'
8. Move the red brush out of the way, and go to the mover properties.
9. In the 'Object' section, set 'InitialState' to 'TriggerToggle'.
10. In the 'Mover' section, set 'MoverEncroachType' to 'ME_IgnoreWhenEncroach'.
11. In the 'Events' section, set the 'Tag' to 'TestDoor1'.
12. Set up the keyframes. (I'm assuming you know how to do this - if not, then give me a shout.)
13. Add a Switch2 (Decoration > DeusExDecoration > Switch2)
14. Select the Switch2 properties.
15. In the 'Events' section of the switch2, set the 'Event' to 'TestDoor1'.
16. Hit F8, and click 'Rebuild Geometry'.
17. Play.
Postby Allan » Sun Sep 17, 06 11:07 am
~MainMan~ wrote:Look, seriously, forget all this resizing stuff, to make a mover, do this:
17. Play.
And I've been intersecting the brushes to be made into a mover for this long =O D'oh! *bangs head* owie...
Postby Aidan » Sun Sep 17, 06 8:39 pm
Lol, thanks guys, i appreciate your help and all, but...I already figured it out :D
Now my maps will finnaly be better, but I have 1 more question, it's not that difficult, but do you just press brush intersection when attaching a mover onto an already made mover and when I want to attach buttons to my mover? ](*,)
Postby MainMan » Sun Sep 17, 06 9:23 pm
)P(sHyCo)(K!//3R wrote:Lol, thanks guys, i appreciate your help and all, but...I already figured it out :D
Argh! You don't need to intersect anything!!
Postby Aidan » Sun Sep 17, 06 9:38 pm
If I don't need to intersect anything, then how do I attach movers together to make one big mover and also attach buttons to movers??!?!? ARRGGHH *Has Mental Breakdown*
Postby Dae » Mon Sep 18, 06 6:48 am
If you need to make a "complicated" mover made of many brushes (cubes, cylinders, other cubes and etc), then just make it from "normal" brushes and after that put into a big building brush, intersect it (in order to put "normal" brushes in one) and make a mover. I know you didn't understand anything, just go to here:
http://tack.planetdeusex.gamespy.com/Ho ... eDoor.html
You cannot make a "complicated" mover with "copying polygons to brush".
You can attach an actor to a mover by doing this steps:
1. Go to Actor's properties -> movement.
2. Set AttachTag to the tag of the mover.
Postby Aidan » Mon Sep 18, 06 6:52 am
Ty, Dae, but nowhere on steve's site does it tell how to make a complicated mover, and I don't think there are any UC tuts either :?
Postby Dae » Mon Sep 18, 06 7:03 am
http://tack.planetdeusex.gamespy.com/Ho ... Part1.html
(read paragraphs 2 and 3).
Using CaroneElevatorSet is not neccesary.
Postby Aidan » Mon Sep 18, 06 7:20 am
ok, so after I intersect all my brushes together, export, then import them as one brush, I build the brush as a (non-mover) with any texture(as the mover has my textures on it anyways), then intersect it, then make the mover? do I need to hit "show polys" or "Transform Perminantly"?
Postby Dae » Mon Sep 18, 06 7:25 am
You need this only if you scaled things using "Scale" tool!!
Postby PsHyCo)(K!//3R » Fri Sep 22, 06 2:00 am
Ok, I'm back, lol. I wasn't on for a bit because I changed my e-mail on my ")P(sHyCo)(K!//3R" account and it locked me out and is now waiting for activation, Dae could you please re-activate it then delete this account when you have, ty :(
Anyways, back to the topic on hand. I had created a complicated mover, there is a somewhat invisible forcefield around it, I think because my window isn't connected to any other part of my brush :? Is this ok?
I'm going to transfer my brush from my windows98 comp(thats what I use to edit since UED1/2 barely crashes) and edit this post and posst the download, give me one second...
Aidan's Brush.zip
My Crapy Brush
(1.6 KiB) Downloaded 374 times
PsHyCo)(K!//3R
