Cheats UC?
Cheats UC?
Postby {17}Ales » Thu Oct 19, 06 9:04 pm
Hey how would you use cheats like tantalus in uc for something like a tantalus gun.
{17}Ales
Postby Bob » Fri Oct 20, 06 12:12 am
Forgive my ignorance, but what is UC?
Postby Allan » Fri Oct 20, 06 12:26 am
Unreal Console? or Unreal Code(Script)?
Postby Mastakilla » Fri Oct 20, 06 8:58 am
Why make a gun that uses a tantalus cheat, why not just make it a very high hitdamage.
Postby MainMan » Fri Oct 20, 06 10:47 am
So what you're saying is... you want a gun, that kills people? 'Cause that's a new idea... :P
Postby Gishank » Fri Oct 20, 06 3:22 pm
Ales, what IS the point in having a gun which tantalus's people...
Postby Cozmo » Fri Oct 20, 06 4:25 pm
So it can kill invincible stuff as well? And that boomy effect. :roll:
Postby {17}Ales » Fri Oct 20, 06 5:36 pm
~Cozmo~ wrote:So it can kill invincible stuff as well? And that boomy effect. :roll:
Its was an example now is there anyway to do this?
{17}Ales
Postby Mastakilla » Fri Oct 20, 06 6:43 pm
If you mean a weapon that can give the effect of a cheat, then yeah probably.
If you mean a weapon that cheats, then your out of your mind.
Postby MainMan » Fri Oct 20, 06 9:53 pm
Yeah it is possible. Just take a look at the code in exec function tantalus in the player class, and put it into the processtracehit() in the weapon class. Hang on I'll find the code for ya.
Postby Spiderbot01 » Fri Oct 20, 06 9:56 pm
Make me a gun that flys around and tries to tantalus me and I will truly be impressed.
Postby MainMan » Fri Oct 20, 06 10:09 pm
From the player class we can extract:
exec function Tantalus()
   local Actor            hitActor;
   local Vector           hitLocation, hitNormal;
   local Vector           position, line;
   local ScriptedPawn     hitPawn;
   local DeusExMover      hitMover;
   local DeusExDecoration hitDecoration;
   local bool             bTakeDamage;
   local int              damage;
   if (!bCheatsEnabled)
      return;
   bTakeDamage = false;
   damage      = 1;
   position    = Location;
   position.Z += BaseEyeHeight;
   line        = Vector(ViewRotation) * 4000;
   hitActor = Trace(hitLocation, hitNormal, position+line, position, true);
   if (hitActor != None)
      hitMover = DeusExMover(hitActor);
      hitPawn = ScriptedPawn(hitActor);
      hitDecoration = DeusExDecoration(hitActor);
      if (hitMover != None)
         if (hitMover.bBreakable)
            hitMover.doorStrength = 0;
            bTakeDamage = true;
      else if (hitPawn != None)
         if (!hitPawn.bInvincible)
            hitPawn.HealthHead     = 0;
            hitPawn.HealthTorso    = 0;
            hitPawn.HealthLegLeft  = 0;
            hitPawn.HealthLegRight = 0;
            hitPawn.HealthArmLeft  = 0;
            hitPawn.HealthArmRight = 0;
            hitPawn.Health         = 0;
            bTakeDamage = true;
      else if (hitDecoration != None)
         if (!hitDecoration.bInvincible)
            hitDecoration.HitPoints = 0;
            bTakeDamage = true;
      else if (hitActor != Level)
         damage = 5000;
         bTakeDamage = true;
   if (bTakeDamage)
      hitActor.TakeDamage(damage, self, hitLocation, line, 'Tantalus');
Therefore, the bits we are interested in are:
            bTakeDamage = true;
            hitPawn.Health         = 0;
            bTakeDamage = true;
            bTakeDamage = true;
         damage = 5000;
         bTakeDamage = true;
   if (bTakeDamage)
These deal with the checking if what you tantalused was a pawn, a mover (door) or a decoration.
Next we can place it into the weapon class. Firstly I had a look at the ProcessTraceHit function:
simulated function ProcessTraceHit(Actor Other, Vector HitLocation, Vector HitNormal, Vector X, Vector Y, Vector Z)
   local float        mult;
   local name         damageType;
   local DeusExPlayer dxPlayer;
   if (Other != None)
      // AugCombat increases our damage if hand to hand
      mult = 1.0;
      if (bHandToHand && (DeusExPlayer(Owner) != None))
         mult = DeusExPlayer(Owner).AugmentationSystem.GetAugLevelValue(class'AugCombat');
         if (mult == -1.0)
            mult = 1.0;
      // skill also affects our damage
      // GetWeaponSkill returns 0.0 to -0.7 (max skill/aug)
      mult += -2.0 * GetWeaponSkill();
      // Determine damage type
      damageType = WeaponDamageType();
      if (Other != None)
         if (Other.bOwned)
            dxPlayer = DeusExPlayer(Owner);
            if (dxPlayer != None)
               dxPlayer.AISendEvent('Futz', EAITYPE_Visual);
      if ((Other == Level) || (Other.IsA('Mover')))
         if ( Role == ROLE_Authority )
            Other.TakeDamage(HitDamage * mult, Pawn(Owner), HitLocation, 1000.0*X, damageType);
         SelectiveSpawnEffects( HitLocation, HitNormal, Other, HitDamage * mult);
      else if ((Other != self) && (Other != Owner))
         if (bHandToHand)
         if (bPenetrating && Other.IsA('Pawn') && !Other.IsA('Robot'))
            SpawnBlood(HitLocation, HitNormal);
   if (DeusExMPGame(Level.Game) != None)
      if (DeusExPlayer(Other) != None)
         DeusExMPGame(Level.Game).TrackWeapon(self,HitDamage * mult);
         DeusExMPGame(Level.Game).TrackWeapon(self,0);
We can see that the part here calling the damage is:
         if (bHandToHand)
Therefore, when I put in code based on the tantalus command, the completed function will look like:
   local float        mult;
   if (Other != None)
      if (Other != Self)
         //MM: ADDED===
         if (Other.bOwned)
      //MM: ADDED=======
            bTakeDamage = true;
         SelectiveSpawnEffects( HitLocation, HitNormal, Other, 5000);
      //MM: ADDED=======
      else if ( (hitPawn != None) && (hitPawn != Pawn(Owner) )
            hitPawn.Health         = 0;
            bTakeDamage = true;
         if (bHandToHand)
      //MM: ADDED=======
            bTakeDamage = true;
      //MM: ADDED=======
      if (bTakeDamage)
         //MM: Take Damage must be called on the server (that's what Role_authority means)
         if(Role == ROLE_Authority)
            Other.TakeDamage(5000, self, hitLocation, line, 'Tantalus');
         DeusExMPGame(Level.Game).TrackWeapon(self,5000);
Hope it helped!
Postby ~ô¿ô~Nobody~ » Fri Oct 20, 06 10:31 pm
I doubt it will have helped him.
Postby MainMan » Fri Oct 20, 06 10:32 pm
~[A]Nobody~ wrote:I doubt it will have helped him.
Why? :?
Postby ~ô¿ô~Nobody~ » Fri Oct 20, 06 10:33 pm
Because he is not that experienced at coding. He cannot use the code without knowing the basics.
Postby MainMan » Fri Oct 20, 06 10:35 pm
~[A]Nobody~ wrote:Because he is not that experienced at coding. He cannot use the code without knowing the basics.
Yes, but I was just explaining what I was doing, to try and help him learn. But at the end, I just gave him a block of code that he can copy-and-paste, without understanding.
Postby ~ô¿ô~Nobody~ » Fri Oct 20, 06 10:46 pm
hmm. i see.
Postby ICE » Fri Oct 20, 06 11:00 pm
heh i know abit |:
ЛЕДImage
The recent message was not spam but was a topic warmer and the message was copyrighted for eternity!Im in czech at the moe.
ICE
Postby MainMan » Fri Oct 20, 06 11:03 pm
heh i know abit |:
Just copy and paste the last bit into your weapon script dude. Try to read my explanation of how I made that code too, though - it will help you to learn :)
Postby Mastakilla » Sat Oct 21, 06 12:27 am
I still think making it a really high hitdamage would've been easyer.
Postby clyzm » Sat Oct 21, 06 4:26 am
Spiderf[A]g01 wrote:Make me a gun that flys around and tries to tantalus me and I will truly be impressed.
Actually that's easy. Just change a player class mesh to "pistol" or whatever, make its weapon the "tantaluspistol" (coding it beforehand) and unlimited ammo.
Either that or just make the GM or GF meshes invincible so that the third person mesh is viewable only.
