Useful Functions
Useful Functions
Postby Alex » Sat Apr 07, 07 8:50 am
Ever created or found useful UnrealScript functions? (So stand-alone functions!) Post them here, so others can use them aswell!
Postby Alex » Sat Apr 07, 07 9:27 am
Ok, I created a function, just for this topic. I only just finished it, but I tested it, and it should work just fine.
I remade this function:
http://nl2.php.net/manual/en/function.substr.php
I also used the examples of that page to test my function.
static final function string substr(coerce string string, coerce int start , optional coerce int length)
  local string    tmpString;
  local int   tmpInt;
  if(start >= 0)
    tmpInt = len(string)-start;
    tmpInt = start*-1;
  tmpString = right(string, tmpInt);
  if(length > 0)
    tmpString = left(tmpString, length);
  else if(length < 0)
    tmpString = left(tmpString, len(tmpString)+length);
  return tmpString;
If you want to test out the function:
// SubStr. Made by Alex ~ http://www.dxalpha.com/
class SubStr extends Actor;
function PostBeginPlay()
  local string testString;
  Super.PostBeginPlay();
  testString = "abcdef";
  log(substr(testString, 1));     // bcdef
  log(substr(testString, 1, 3));  // bcd
  log(substr(testString, 0, 4));  // abcd
  log(substr(testString, 0, 8));  // abcdef
  log(substr(testString, -1, 1)); // f
  log(substr(testString, -1));    // f
  log(substr(testString, -2));    // ef
  log(substr(testString, -3, 1)); // d
  log(substr(testString, 0, -1));  // abcde
  log(substr(testString, 2, -1));  // cde
  log(substr(testString, 4, -4));  // empty
  log(substr(testString, -3, -1)); // de
  local int   tmpInt;
  if(start >= 0)
    tmpInt = start*-1;
  if(length > 0)
  else if(length < 0)
  return tmpString;
  bHidden=true
Just compile that actor, and add it to your ServerActors.
It will log the results in your server-console as soon as you start your server :)
Any questions? Go ahead & ask. For the use of this function or other explanation:
Postby MainMan » Sat Apr 07, 07 9:49 am
Wow, looks nice...
A function that exists in the DeusEx version of Object.uc, but not many people know about (as it is unique to DX)
native static final function string GetConfig( string ConfigSection, string ConfigKey);  // DEUS_EX CAC
Yes, it natively, dynamically retrieves information from the DeusEx.ini file. Normally, config files can only be written to, but when you "read" them, you are in fact just reading from the class (which has loaded the config file once during the server launch). This function actually enables you to read from the file. Nice.
An example of use would be:
str = "TestArray["$testIndex$"]";
return Class'IniTest'.Static.GetConfig("PackageName.IniTest", str);
Where "PackageName.IniTest" is the header in the .ini file, and TestArray is the variable.
E.g. the ini file would be like:
[PackageName.IniTest]
TestArray[1]=aaa
TestArray[2]=qqq
TestArray[3]=ggggg
TestArray[4]=fff
TestArray[5]=ccc
So if you were to enter testIndex as 4 on the example above, it would return "fff" in that code.
The only disadvantage is, that it can only read from the DeusEx.ini package, and not any others - so your info must be in there.
Postby Alex » Sat Apr 07, 07 9:54 am
I made the following function a while ago. I thought it returns the amount of occurances of a certain string in an other string.
static final function int strfind(coerce string Haystack, coerce string Needle)
  local int StringIndex;
  while(instr(Haystack,Needle) != -1)
    Haystack = Right(Haystack,(Len(Haystack)-instr(Haystack,Needle))-1);
    StringIndex++;
  return StringIndex;
So it would be like:
someInt = strfind("applepie", "p");
That would return 3. Not sure though, will test it some other time today.
It returns an int, so don't try to place it into a string ;)
Postby Alex » Fri May 25, 07 5:43 pm
If you want functions that are in other language's, such as JavaScript or PHP or whatsoever and they are not in UnrealScript: Just post here. I can hopefully/probably write them in UC format.
Postby Batchy » Wed Jan 09, 08 5:46 am
Does UScript have a function like strlen?
If not, Could you whip one up :D
Batchy
Postby Dae » Wed Jan 09, 08 10:46 am
Batchy wrote:Does UScript have a function like strlen?
len("batch"); would return 5 :)
Postby Batchy » Thu Jan 10, 08 5:39 am
Ahh ok, I should of gone through his code more thoroughly and i would of seen it xD
Batchy
Re: Useful Functions
Postby han » Mon Sep 22, 14 7:10 pm
Set/GetPropertyText() are quite handy for ducktype copying variables especially enums, which would require checks for each case. e.g.
ReplacementInv.SetPropertyText("SkinColor", OtherInv.GetPropertyText("SkinColor"));
Maybe a fixed TraceTexture() version is sth. you might like (a whole new feeling with right footstep sounds).
// Find the FBspNode for Point.
INT FindNode( UModel* Model, INT iPlane, FVector Point )
   guard(FindNode);
   check(Model);
   INT Index = iPlane;
   while ( Index != INDEX_NONE )
      FBspNode& Node = Model->Nodes(Index);
      if ( Node.iSurf != INDEX_NONE )
         FBspSurf& Surf = Model->Surfs(Node.iSurf);
         //debugf( TEXT("FindNode: Testing: FBspNode(%i) with FBspSurf(%i).Texture %s."), Index, Node.iSurf, Surf.Texture ? Surf.Texture->GetName() : TEXT("None") );
         UBOOL Valid = 1;
         FLOAT OldPlaneDot = 0.0f;
         // Check for NumVertices == 0
         if ( Node.NumVertices )
            for ( INT i = 0; i < Node.NumVertices && Valid; i++ )
               // Get Points.
               FVector& A = Model->Points(Model->Verts(Node.iVertPool + i).pVertex);
               FVector& B = Model->Points(Model->Verts(Node.iVertPool + ((i+1) % Node.NumVertices)).pVertex);
               // Now build a plane.
               FPlane Plane( A, (B-A)^FVector( Node.Plane.X, Node.Plane.Y, Node.Plane.Z ) );
               // Now check Point against this plane.
               FLOAT PlaneDot = Plane.PlaneDot( Point );
                  // Sign changed, check next FBspNode.
               if ( OldPlaneDot * PlaneDot < 0.0f )
                  Valid = 0;
               // Sign stayed the same, everything fine.
                  OldPlaneDot = PlaneDot;
            // Passed check.
            if ( Valid )
               //debugf( TEXT("FindNode: Passed.") );
               return Index;
            //else
               //debugf( TEXT("FindNode: Failed.") );
         //else
            //debugf( TEXT("FindNode: Skipping: Node.NumVertices == 0.") );
      //else
         //debugf( TEXT("FindNode: Skipping: Node.iSurf == INDEX_NONE.") );
      Index = Node.iPlane;
   return INDEX_NONE;
   unguard;
//native(3220) final iterator function TraceTextureHan( class<Actor> BaseClass, out actor Actor, out name TexName, out name TexGroup, out int Flags, out vector HitLoc, out vector HitNorm, vector End, optional vector Start, optional vector Extent )
void AHXPlayerPawn::execTraceTextureHan(FFrame& Stack, RESULT_DECL)
   guard(AHXPlayerPawn::execTraceTextureHan);
   P_GET_OBJECT( UClass, BaseClass );
   P_GET_OBJECT_REF( AActor, Actor );
   P_GET_NAME_REF( TexName );
   P_GET_NAME_REF( TexGroup );
   P_GET_INT_REF( Flags );
   P_GET_VECTOR_REF( HitLoc );
   P_GET_VECTOR_REF( HitNorm );
   P_GET_VECTOR( End );
   P_GET_VECTOR_OPTX( Start, Location );
   P_GET_VECTOR_OPTX( Extent, FVector( 0.0f, 0.0f, 0.0f ) );
   P_FINISH;
   FMemMark MemMark( GMem );
   if ( !BaseClass )
      BaseClass = AActor::StaticClass();
   FCheckResult* Res = XLevel->MultiLineCheck( GMem, End, Start, Extent, 1, Level, 0 );
   PRE_ITERATOR
      if ( Res )
         *Actor      = Res->Actor;
         *HitLoc      = Res->Location;
         *HitNorm   = Res->Normal;
         *TexName   = NAME_None;
         *TexGroup   = NAME_None;
         *Flags      = 0;
         if ( Res->Actor == Level )
            Res->Item = FindNode( XLevel->Model, Res->Item, Res->Location );
            if ( Res->Item != INDEX_NONE )
               FBspNode& Node = XLevel->Model->Nodes(Res->Item);
                  FBspSurf& Surf = XLevel->Model->Surfs(Node.iSurf);
                  if ( Surf.Texture )
                     *TexName   = Surf.Texture->GetFName();
                     if ( Surf.Texture->GetOuter() )
                        *TexGroup   = Surf.Texture->GetOuter()->GetFName();
                  *Flags = Surf.PolyFlags;
         Res = (FCheckResult *)Res->Next;
         Stack.Code = &Stack.Node->Script( wEndOffset + 1 );
         *Actor = NULL;
         break;
   POST_ITERATOR
   MemMark.Pop();
   unguardexec;
Problem of old DX TraceTexture() was that that Surf.Texture's properties were used.
Although Res->Item an index to the first coplanar FBspNode (linked over FBspNode.iPlane), so the clipping stuf was missing to find the correct FBspNode.
han
Postby Allan » Tue Sep 23, 14 10:11 pm
han wrote:Maybe a fixed TraceTexture() version is sth. you might like (a whole new feeling with right footstep sounds).
   guard(FindNode);
   check(Model);
   INT Index = iPlane;
         UBOOL Valid = 1;
               // Get Points.
                  Valid = 0;
            // Passed check.
            if ( Valid )
               return Index;
            //else
         //else
      //else
   return INDEX_NONE;
   unguard;
   P_FINISH;
   if ( !BaseClass )
   PRE_ITERATOR
      if ( Res )
         *Flags      = 0;
                  if ( Surf.Texture )
         *Actor = NULL;
         break;
   POST_ITERATOR
   MemMark.Pop();
   unguardexec;
Got to admit, this would be a lot of use to me to find out if this would help my fireballs grab the correct textures to set on fire, and tracehits get the right textures to apply the right decals to. Does this require any additional DLLs or can I just dump this verbatim into a .uc?
I'm sounding all nub because outside of UScript, I'm a bit of a coding dunce. xD
Postby han » Tue Sep 23, 14 10:37 pm
You need to put it in your own dll. Didn't see the uc functions in the first post. XD
However, i put a package together with some stuff ripped out of my main project and slightly modified it, although the package is untested, it has a static version of the modified TraceTexture in it, so it could be called from somewhere else (Documentation is in the *.uc file).
Coolbits-20140923.zip
(30.51 KiB) Downloaded 1104 times
han
Users browsing this forum: No registered users and 66 guests
