Dejavu exploiting
Postby Dae » Mon Aug 21, 06 9:45 am
It will be a small patch on a tube with a big hole. So sooner or later the patch will burst open.
Postby Alex » Mon Aug 21, 06 9:46 am
Spiderf[A]g01 wrote:Can't someone just use it against him?
Sure we can. But it wont help would it? And we would lower ourselves to his level.
Postby [FGS]Majestic » Mon Aug 21, 06 10:58 am
Yeah, hacking himself would be really sad. Lol, there are like 3 "fuck you deja" servers 0 aug now :D :) ..hopefully it can be fixed but it seems very effective, even after 5 seconds the server crashes :(
[FGS]Majestic
Postby synthetic » Mon Aug 21, 06 1:49 pm
im curious how konamis plan might work, mailing gamespy part that is. theoretically Anyone could host a 0aug server, wait it to get wiped and then report to gamespy. Obviously a patch would be priority #1 but 20 emails going gamespy way might be interesting. I also considered the possibility of notifying his university. He claims he has nothing to do with this, at least he did last night, and I was told he also gave the bot out to [3]. So dejavu wont end up as the only enemy and crasher probably.
I usually avoid this forum but for obvious reasons I made an exception, I wish daedalus and alex luck patching up the hole, until next time dejavu finds a new route.
REN is planning on buying a 0aug server shortly, possibly partly auged. So we hope to aquire a working patch.
Postby Krieg » Mon Aug 21, 06 2:10 pm
partly augged :shock: , their are enough good augged servers , [3] and stezorz one are enough
Postby synthetic » Mon Aug 21, 06 2:18 pm
I said "possibly" and "partly" shadow =), as far as we've discussed it it will be 0-auged.
Postby Spiderbot01 » Mon Aug 21, 06 2:46 pm
I assume your Sig is an ironic joke...
Postby Krieg » Mon Aug 21, 06 3:23 pm
he loves ironie
Postby monkee » Mon Aug 21, 06 4:59 pm
o_O
monkee
Postby Spiderbot01 » Mon Aug 21, 06 5:16 pm
It would be useful if we had a paying gamespy person, might pay a bit more attention to them..
Postby Imperial » Mon Aug 21, 06 6:51 pm
Tried to contact Gamespy, in the end, it lead me to support, but not for contacting them about masterserver issues, or anything to that extent. It says that the game supplier is responsible for their masterserver however, as they are the ones who provide the information. Unfortunately, it is very hard to contact Eidos Interactive, with no contact information left on thier site. I also doubht they would care.
However, if anyone knows the contact for gamespy it would be much apreciated.
Thanks.
Postby Dae » Mon Aug 21, 06 6:52 pm
Just a small hint: Ion Storm doesn't exist.
Postby Imperial » Mon Aug 21, 06 6:54 pm
Got confused, meant eidos. :oops:
Postby DarkKnight » Mon Aug 21, 06 6:56 pm
Well, my server appears to be running quite well... at least for the last 7 hours.
<3 iptables
Postby Imperial » Mon Aug 21, 06 6:59 pm
I take it that there is no more probs then. Or did you al just download Dae's Mutator?
Postby Dae » Mon Aug 21, 06 7:00 pm
I haven't made it yet. Stuck somewhere :o
Postby Imperial » Mon Aug 21, 06 7:04 pm
o.o
Well then he must have ended his atack on 0aug servers, won't be the last of it though I doubht.
Postby DarkKnight » Mon Aug 21, 06 7:13 pm
Imperial wrote:o.o
Even if Deja does attack my server, it will get him nowhere.
:wink:
Postby Spiderbot01 » Mon Aug 21, 06 7:28 pm
DarkKnight wrote:
Imperial wrote:o.o
:wink:
You can't outsmart an aussie...
Postby DarkKnight » Mon Aug 21, 06 7:45 pm
DarkKnight wrote:
Imperial wrote:o.o
:wink:
Or iptables, for that matter.
(His entire IP pool is blocked at the kernel level, the packet never reaches my server. :) )
Postby MainMan » Mon Aug 21, 06 7:46 pm
DarkKnight wrote:(His entire IP pool is blocked at the kernel level, the packet never reaches my server. :) )
That's phat. Is it possible to do that on a windows-hosted server?
Postby DarkKnight » Mon Aug 21, 06 8:28 pm
Not without a 3rd party app, I belive. :?
Just checked, your best (and most effective) way for a Windows based server is a software firewall, Windows has no inbuilt functions that would suffice. =/
For Linux hosters;
iptables -A INPUT -s 193.95.228.0/24 -j DROP
Run as root, or with sudo. It silently drops all packets from that IP.
(All distro's should have iptables, and you could add a port if you didn't want to ban him totally..)
Postby clyzm » Mon Aug 21, 06 8:30 pm
No wonder all the latest 24/7 game servers are run on Linux.
Postby MainMan » Mon Aug 21, 06 8:31 pm
For Linux hosters;
What about a hardware router firewall?
Postby kBo » Mon Aug 21, 06 8:42 pm
For Linux hosters;
WinPCap does the trick:
http://winpcap.mirror.ethereal.com/301a ... _tut5.html
If you want to patch the game, I recommend setting up a server on your PC, attaching to it with OllyDBG or IDA and setting breakpoints on malloc() calls. You might be able to learn something that way.
kBo
Postby DarkKnight » Mon Aug 21, 06 11:16 pm
~MainMan~ wrote:What about a hardware router firewall?
Goes without saying, if you can block ip's with your router, do it. :)
kBo wrote:WinPCap does the trick:
The bug is quite well explained.
All it would need for a fix is a few extra tests/conversions before it actually calls malloc(), the trick being, how do you apply it?
(That question is more broad then the simple actions.)
Postby MainMan » Mon Aug 21, 06 11:18 pm
DarkKnight wrote:Goes without saying, if you can block ip's with your router, do it. :)
Yup I can 8)
What's the IP I need to block?
Postby Allan » Mon Aug 21, 06 11:35 pm
193.95.228.0, me thinks, based on the command for the Linux way of protecting it.
*checks if my router can block IP's...*
Postby rob » Mon Aug 21, 06 11:43 pm
rob
Postby DarkKnight » Mon Aug 21, 06 11:44 pm
Allan wrote:193.95.228.0, me thinks, based on the command for the Linux way of protecting it.
The command blocks 193.95.228.0 - 193.95.228.255 :)
Edit: Also, make sure you check your logs before you restart your server, if he starts using zombies, or other people start using it, you can just repeat, repeat, repeat.
