Server hosting
Postby Gustertote » Mon Dec 15, 03 7:28 pm
Come some one tell me how to host a server. Tell me how to give the server name on the server list, how to set a admin pasword and how...EVERYTHING really...
thanx
BLUE and RED
Gustertote
Postby Dae » Mon Dec 15, 03 7:34 pm
Goto DeusEx/System folder,
create simple .txt file and rename it into .bat, click right click on the file, click edit, then write down in it:
echo i'm bum but i can launch the server
DeusEx.exe DeusEx.exe DXMP_Smuggler.dx -server
pause
First line - magic words.
Second line opens the Deus Ex server function on dedicated by default without opening DX (throught .bat it reduces some lag and simply, it's easier). Now your server is up (probably) and you can set it's properties, goto command line, type preferences and there you can fix anything on it.
Postby Dae » Mon Dec 15, 03 7:35 pm
I have moved da topic into ALPHA Forum Index -> Deus Ex Multiplayer as u see.
Postby ZepHroN » Mon Dec 15, 03 10:02 pm
Dont forget "I am also REALLY gullable" at the end of the magic words....jeez...how could you forget that Daedalus....pfft.
ZepHroN
