DXMP Cheats for Server Admins
Postby King J / TJ » Sat Feb 07, 04 6:42 pm
been trying to discover the DXMP cheats for server admins but cannot find out.
Could someone give me a detailed walkthrough of how to summon something like a cat, Terrorist etc, etc.
If you could tell me that that would be great :lol:
Thanks
King J / TJ
King J / TJ
Postby Jeoh » Sat Feb 07, 04 7:41 pm
    ENABLE CHEATS:set DeusEx.JCDentonMale bCheatsEnabled True
    acousticsensor
    adaptivearmor
    alexjacobson
    ammo10mm
    ammo20mm
    ammo3006
    ammodart
    ammodartflare
    ammodartpoison
    ammonapalm
    ammoplasma
    ammorockets
    ammorocketwp
    ammosabot
    annanavarre
    atm
    attackhelicopter
    augballistic
    augmentationupgradecannister
    augcloak
    augdatalink
    augemp
    augenviro
    augiff
    augshield
    augstealth
    augtarget
    autoturret
    babykarkian
    ballisticarmor
    bartender
    basketball
    binoculars
    blackhelicopter
    boatperson
    bobpage
    boneskull
    bookclosed
    bookopen
    bumfemale
    bummale
    bummale2
    bummale3
    businessman1
    businessman2
    businessman3
    businesswoman1
    butler
    button
    candybar
    cat
    ceilingfan
    chef
    childmale
    childmale2
    cigarettemachine
    cigarettes
    cleanerbot
    computerpersonal
    computerpublic
    computersecurity
    cop
    crateexplosivesmall
    crateunbreakablelarge
    crateunbreakablemed
    crateunbreakablesmall
    credits
    datacube
    dentonclone
    doberman
    doctor
    earth
    empgrenade
    fan1
    fan2
    faucet
    female1
    female2
    female3
    female4
    fire
    fireextinguisher
    fish
    flagpole
    flare
    flowers
    fly
    garysavage
    gordonquick
    gray
    greasel
    guntherhermann
    harleyfilben
    hazmatsuit
    hkbuddha
    hkhangingpig
    hkmilitary
    hooker1
    hooker2
    jaimereyes
    jcdentonmale
    jock
    joegreene
    jojofine
    josephmanderley
    junkiefemale
    junkiemale
    karkian
    karkianbaby
    keypad1
    keypad2
    keypad3
    lam
    lamp1
    lamp2
    lamp3
    lifesupportbase
    liquor40oz
    liquorbottle
    lockpick
    lowerclassfemale
    lowerclassmale
    lowerclassmale2
    luciusdebeers
    maid
    male1
    male2
    male3
    male4
    maxchen
    mechanic
    medicalbot
    medkit
    mib
    microscope
    militarybot
    minisub
    mj12commando
    mj12troop
    morgoneverett
    multitool
    mutt
    newspaper
    newspaperopen
    nicoletteduclare
    nurse
    pauldenton
    pigeon
    pillow
    pinballmachine
    poolball
    rachelmead
    rat
    rebreather
    repairbot
    retinalscanner
    riotcop
    roadblock
    rocket
    rocketlaw
    rocketwp
    salior
    sarahmead
    seagull
    secretservice
    securitybot2
    securitybot3
    securitybot4
    showerfaucet
    showerhead
    sodacan
    soldier
    soyfood
    spiderbot
    spiderbot2
    terrorist
    tiffanysavage
    toilet
    tracertong
    unatcosecretary
    unatcotroop
    van
    vendingmachine
    vialambrosia
    vialcrack
    waltonsimons
    watercooler
    waterfountain
    weaponassaultgun
    weaponassaultshotgun
    weaponbaton
    weaponcombatknife
    weaponcrowbar
    weaponempgrenade
    weaponflamethrower
    weapongasgrenade
    weapongepgun
    weaponhideagun
    weaponlam
    weaponlaw
    weaponminicrossbow
    weaponmodaccuracy
    weaponmodclip
    weaponmodlaser
    weaponmodrange
    weaponmodrecoil
    weaponmodreload
    weaponmodscope
    weaponmodsilencer
    weaponnanosword
    weaponnanovirusgrenade
    weaponpeppergun
    weaponpistol
    weaponplasmarifle
    weaponprod
    weaponrifle
    weaponsawedoffshotgun
    weaponshuriken
    weaponstealthpistol
    weaponsword
    whchairovaloffice
    whpiano
    whredcouch
    wib
    winebottle
No problem.
Jeoh
Postby DoughBoy » Sat Feb 07, 04 7:42 pm
ok do this in order:
1. Login to admin e.g. adminlogin password here
That should bring up a message saying that you are now an administrator
2. After you have logged into admin do this command:
Delte say and type:
admin set human bcheatsenabled true
3. Try to summon somthing
delete say and type summon cat
That sould work and summon a cat
DoughBoy
DoughBoy
Postby Jeoh » Sat Feb 07, 04 7:43 pm
I listed all I know.
Jeoh
Postby King J / TJ » Sat Feb 07, 04 7:45 pm
so how do i know what the pass is - in the server setup ( deus ex main screen ) it dosent have anywhere to put a pass!
Help!
Thanks
( Im a real n00b - very common these days )
King J / TJ
Postby Jeoh » Sat Feb 07, 04 7:49 pm
O.k...
1. Go to your Deusex/System folder(default C:/Deusex/System
2. Open User.ini
3. Search for Adminpass=
3a. It isn't there.Go to 5
3b. It is there.Go to 4
4. Fill in your pass.
5. Open your Deusex.ini
6. Search for Adminpass=
7. Fill in your pass.
Jeoh
This is weird....
Postby King J / TJ » Sat Feb 07, 04 7:58 pm
i have searched thru User.ini AND deusex.ini but "Adminpass=" ( without qotes ) was not found!!!!
Can i add adminpass into the ini file manually and if so where?
Thanks
King J / TJ
Postby King J / TJ » Sat Feb 07, 04 8:10 pm
would the adminpassword= thing work instead of Adminpass= ?
im gonna try, will report back
King J / TJ
Postby Dae » Sat Feb 07, 04 8:21 pm
Yeh, adminpassword= works. And dont mix it with gamepassword= - that gives private access to your server.
Also, in servers where is no DXMTL mod installed there is no message showing that you had logged in as administrator. If you use DXMTL, sometimes spawnmass won't work and sometimes summon don't need to enable cheats. This all is configurable in DXMTL .ini files.
Postby Blade » Sat Feb 07, 04 8:56 pm
isnt is much more easier to configure pass and all the rest from the advanced properties of unreal server? i find it is so, at least i dont have to find the deusex.ini file every time!
and in games without dxmtl it DOES show a message when you log in!
May the Force be with you...
Blade
Postby King J / TJ » Sat Feb 07, 04 9:02 pm
how do you get the unreal server properties window - i dont HAVE unreal tourlament!
King J / TJ
Postby King J » Sat Feb 07, 04 9:08 pm
Also how do you "break" unbreakable objects? E.G. Large Crates, Attack Helicopters
I REALLY need to tidy up the map :P
King J
Postby Jeoh » Sun Feb 08, 04 1:18 pm
killall crateunbreakablelarge
for the large ones
killall crateunbreakablemedium
for the medium ones
killall crateunbreakablesmall
for the small ones
Jeoh
Postby Blade » Sun Feb 08, 04 1:56 pm
unrealserver is the icon you get in your system tray (near the clock) when you start a dedicated server, it's called so since deus ex is based on unreal, wheter or not you have unreal tournament is not important! :lol:
you can access the properties either rightclicking that icon or typing "preferences" from within the game
Blade
Thanks
Postby King / King J / Tristan » Sun Feb 08, 04 3:43 pm
Thanks for all the info u guys. it was a real help! :P
Postby Dae » Sun Feb 08, 04 4:22 pm
Get SMG mod and summon infinity xr-9, using it you can kill special object on the map, comparing with killall command, that kills all object of this type on whole level.
Also, kinda hax0r type: set objectname binvincible false
Postby jamiew99 » Sat Jul 14, 07 4:03 pm
i cant logon my admin, i delete say and type adminlogon "mypass" and it says encregonized command, plz help
Arthur Dent wrote:So why a whelk in particular?
jamiew99
Postby Alex » Sat Jul 14, 07 4:34 pm
1. Adminlogin not adminlogon
2.
Sun Feb 08, 2004
Don't revive old topics!
Please read this:
http://www.dxalpha.co.uk/forum/viewtopic.php?t=6670
Mods & admins, don't warn the guy. He's new... you know.
Postby Dae » Sat Jul 14, 07 4:34 pm
It's adminlogin password, without quotes ""
Postby synthetic » Sat Jul 14, 07 6:57 pm
I have been registered for a while and I still dont quite get it when its ok to post in some old topic that matches your problem, or when you have to make a new one without admin yelling "there already is such thread" at you. :/
Postby Dae » Sat Jul 14, 07 7:09 pm
reviving old topics is a rule mainly for topics of the past from General chat
that's what Wasted did with Darren's topics before he was banned
but this isn't a case really
Postby Big Daddy » Sat Jul 14, 07 8:50 pm
What, so necroposting is looked down upon sort-of in a radius of 2 years?
Users browsing this forum: Google [Bot] and 8 guests
