advanced naming
advanced naming
Postby █Anonym0uz█ » Tue Oct 21, 03 8:03 pm
hi to you all
i'd like to know the tricks people use when writing their name:
1) i've finally managed to find out how to change color, so no problem with it :D
2) i CAN'T (really can't) find out what the code |b stands for, any advice :?: ?
3) i'd like to know how to put strange characters in my name (i mean chars from the extended ascii table like █ or ▲ or Ã
█Anonym0uz█
Postby Dae » Tue Oct 21, 03 8:29 pm
Now I can answer only for 3-rd question. All you need to add symbols into your nickname - to open user.ini file, located in DeusEx/system directory and to select symbols you need in table of symbols. Selected name you must put in the 'name' tag. For example,
Name=Ômègà
Tips:
- You need to save you user.ini file in encoding that will save your characters (select one; to be careful, first of all, copy selected name in another place and if something bad will happen you can get it back instead of doing all work again).
- Don't forget that in 'killed' message your symbols won't be displayed. For example, my nickname is Ðáédálus, when i'll kill somebody, that guy will see message "You have been killed by lus".
- Don't forget, that, for example, russian guys have russian Deus Ex encoding, italian - italian DX encoing, specified for their language. In some encoding they will see different symbols. Some nicknames in my russian encoding are unreadable.
Postby Aussiefella » Tue Oct 21, 03 9:48 pm
oooooohhhh while we are on the subject mate, can you tell me how to change my name to blue?
Aussiefella
Postby JeJ » Wed Oct 22, 03 12:18 pm
You'll probably find that most servers, those with the MTL installed, will not accept colour changes in your name. That goes especially for the more well known Aug servers, though most 0 aug servers are the same way.
If you're North American, and want to put "fancy" characters in your name, use charmap. DeusEx doesn't support a whole pile of fonts, as Daedalus said, but I know you can use Times New Roman and Arial.
JeJ
Postby Dae » Wed Oct 22, 03 1:12 pm
IMHO all errors are with language encodings. Name displaying is independent of font in which you've added name in your user.ini because it's only one name-displaying font in DeusEx :)
Postby Aussiefella » Wed Oct 22, 03 10:26 pm
ohhhh, i want to know how to color my name.......:'(
Aussiefella
Postby █anonymouz█ » Thu Oct 23, 03 7:40 pm
i had already tried with editing the user.ini:
i have put characters from other languages (like the ones daedalus has in his name) successfully, but i can't use the █ (alt-219) or similar ascii chars (when i save as unicode they show in the user.ini but not in deusex, nowhere). now i explain better: i don't know if you know rosso, but he is an italian guy who made a flag (, though i don't know if it displays well here) and i said i'd make it too BUT I'M NOT ABLE TO!!!!
█anonymouz█
Postby Dae » Thu Oct 23, 03 8:28 pm
I don't know exactly how did russo made his flag, because i have seen him in game only few times (Warriors don't play on famous servers as partizan, vollkrass were). All servers they're playing are like Another UT demo server's or on some italian ones. All servers they're playing don't have DXMTL installed, so, i guess, russo made his flag as you did on forum in the last message - using colored | symbol.
Postby Dae » Thu Oct 23, 03 8:30 pm
By the way, i never heard of flags in Deus Ex Textures/Fonts in my dx editing practice.
Postby █anonymouz█ » Fri Oct 24, 03 6:32 pm
wait a moment...
in my previous post i've used the alt+219 (█) char and not | and i think rosso did use it too since you can see the squares in his name when you are killed and see the coded name (|p1█|p0█|p2█ or something like that)
second thing, what is dxmtl?? is it that thing that makes dxmtlteamdeathmatch and similar games? is it the cause why i can't play that games???? if it is so, where can i download it?
█anonymouz█
Postby █anonymouz█ » Fri Oct 24, 03 6:51 pm
maybe i've found dxmtl
so answer only the first question (the same █)
█anonymouz█
Postby Aussiefella » Sun Oct 26, 03 12:25 am
could you register please Anounamous man?
Aussiefella
Postby Dae » Sun Oct 26, 03 8:43 am
Yeah, it's like forum etiquette and it's easier to talk while you know who are you talking to.
Postby Blade » Tue Oct 28, 03 7:34 pm
ok, i've registered
(even if i don't see any major change)
now can someone tell me how to display alt+219 or similar character in deusex?
by the way, does someone know what are the class name you should use to refer to players while scripting in multiplayer?
May the Force be with you...
Blade
Postby Blade » Tue Oct 28, 03 7:35 pm
damn
thank you, now my name has gone to hell
damn again...
Blade
Postby Aussiefella » Tue Oct 28, 03 9:26 pm
what do you mean your name has gone to hell?
Aussiefella
Postby Blade » Wed Oct 29, 03 11:53 am
i mean exactly 'my name has gone to hell'
i mean the name on the forum:
first it was █anonymouz█
now that i'm registered it shows a damn char code instead of █ (see my name on the left!)
however, no news on displaying chars from (extended) ascii set (like █ alt+219)????
Blade
Postby Dae » Wed Oct 29, 03 2:50 pm
Yes, because it's forum protection maybe. Anyway you can change your nickname in profile or ask me for doing it (i'll do this faster).
Postby Blade » Sat Nov 01, 03 3:47 pm
i've changed my profile, inserted an avatar and also changed my signature in something less idiot...
and another thing on the topic subject (see above):
i've seen the character better (it's often used in a gods' server name too) and it's not really like █ because its edges are like those of a stamp...
any ideas?
Blade
Postby Dae » Sat Nov 01, 03 4:22 pm
Like yyyyyyyyyy (on Joe's server)?
Or characters like box or like this € ? By the way, you can get box symbol in Deus Ex adding ~ symbol through ini files ( ~ symbol is displayed different in Deus Ex fonts ).
Postby Blade » Sun Nov 02, 03 3:07 pm
|ALPHA|Daedalus wrote:Like yyyyyyyyyy (on Joe's server)?
not that character, it is shown on another gods server, not joe's
|ALPHA|Daedalus wrote:Or characters like box or like this € ? By the way, you can get box symbol in Deus Ex adding ~ symbol through ini files ( ~ symbol is displayed different in Deus Ex fonts ).
yes yes yes
i'll try ~
and for "characters like box or like this € "?
Blade
Postby Blade » Tue Nov 04, 03 7:17 pm
i have tried ~ but in deusex it shows like a really little box, while the character i'm talking about is as tall as a common letter and large an half...
Blade
Postby Dae » Wed Nov 05, 03 1:56 pm
I dunno that one character, if you'll find it - tell me please :)
Postby Splitter » Sun Nov 30, 03 7:45 pm
Can anyone tell me how change the color of your name, i've checked this thread but it doesn't mention it :?
»§plíttèr/§plícè«
» ÐÇsß « » eNigma² «
Getting TK'd since 24/11/03
Splitter
Postby Aussiefella » Fri Jan 09, 04 7:36 am
yes! i want to know aswell!
Aussiefella
Postby DarkKnight » Sat Jan 10, 04 2:07 am
name c|888888 ][GODZ][DarkKnight c|666666
that will give silver :D
If you want to know about name colour (Or if I got it wrong) Go here and if that doesnt work then try This one :D
EDIT:Btw did you mean this one?▓
Postby Blade » Sat Jan 10, 04 5:27 pm
no i meant █, but it's the same
if you know how to insert that character into your name please tell me
someone told me it's on the keyboard, but i don't have it
tried also editing the ini file, but doesn't work either
p.s.: has anyone ever tried to press alt+126 during the game? why does that strange screen appear? (i've tried it in mp, but maybe it's the same in sp too)
Blade
Postby DarkKnight » Sat Jan 10, 04 5:32 pm
Well if you press shift+~ when in talk you will bring down the console menu....which does nothing :D you can do every thing it does .....by just using the quick console :?
Postby Blade » Sat Feb 07, 04 8:59 pm
found it out 8)
never mind
Blade
Postby MainMan » Sun Sep 04, 05 8:35 pm
did you find out how to colour your name?!
