Bind that opens the augmenu
Postby Hanover Fist » Fri Aug 25, 06 2:44 am
I was wondering if any of you knew how to bind the augmenu to a key like the inventory to F1.
Hanover Fist
Postby Hanover Fist » Sat Aug 26, 06 5:21 pm
No one?
Hanover Fist
Postby [FGS]Majestic » Sat Aug 26, 06 5:51 pm
I don't know yet but I'm gonna search it out for you.
Edit: I got it. Go to your user.ini and change keybinds in the following chapters: [Engine.Input] and [Extension.InputExt]
Once there change the following.
<your preferred key>=ShowAugWindow
Don't forget to do it in your [Extension.InputExt] too!! It should work after you've done that.
[FGS]Majestic
Postby -TheSpecialist- » Sat Aug 26, 06 5:52 pm
Never tried it, just type augmenu behind the equals sign in the ini. Or whatever other phrase comes after the button augmenu is currently binded to.
So F1 = Augmenu
I don't even know if it works.
- Tracer - Thief - Osborne -
-TheSpecialist-
Postby Hanover Fist » Sat Aug 26, 06 7:34 pm
Oops I meant the multiplayer aug menu.
Hanover Fist
Postby -TheSpecialist- » Mon Aug 28, 06 1:20 am
Is this for some kind of bind that will switch your team and back again?
-TheSpecialist-
Postby Hanover Fist » Wed Aug 30, 06 11:50 pm
What? Read it again.
Hanover Fist
Postby Dae » Thu Aug 31, 06 6:21 am
-TheSpecialist[A]- wrote:Is this for some kind of bind that will switch your team and back again?
No, you can switch team only in that window.
