Does anyone...
Does anyone...
Postby Spiderbot01 » Sat Sep 16, 06 2:55 pm
Have or know a concise guide to admin commands? Like how to change server settings etc? If so Id greatly appreciate it :]
Postby Krieg » Sat Sep 16, 06 4:10 pm
Something i was wondering as well.Knowing them would make it much easier for me as an admin of ren server.
Postby Alex » Sat Nov 11, 06 9:58 am
I am aware of the fact that this is an old topic, but I will post anyways.
What kind of admin commands? As example, setting a server to 0 aug & full skill, while ingame?
Postby Spiderbot01 » Sat Nov 11, 06 11:56 am
YES. THAT IS EXACTLY IT.
Postby ~ô¿ô~Nobody~ » Sat Nov 11, 06 12:28 pm
actually that commands always have a defined structure
admin set Package.Class property newValue
Package - the package, where the class is located in. (like Deusex.u)
Class - the actual classname (like DeusExMPGame)
property- the property variable, that was declared inside the class (like InitialAugs)
newValue - the new value, that the property shall get (like 0)
you will have realized that the property and the class is identical to the ones in the deusex.ini
[DeusEx.DeusExMPGame]
SkillsTotal=2000
SkillsAvail=10000
SkillsPerKill=500
InitialAugs=2
AugsPerKill=1
ScoreToWin=20
so, you can also change other properties by that..
so.. for adjusting the initial augs, you need to type
admin set DeusEx.DeusExMPGame InitialAugs 3
for setting the initial augs to 3
same you can do with augPerKill or scoreToWin, which is the full game time (in case your game mode is time) or which represents the scores that a player (in DM) or a team (in TDM) needs to win the game
Postby Alex » Sat Nov 11, 06 1:17 pm
Can be done shorter:
admin set DeusExMPGame InitialAugs 3
But this is only with Engine. and DeusEx. !
Postby ~ô¿ô~Nobody~ » Sat Nov 11, 06 1:32 pm
I know, also I just waited that someone would smart-ass that out.
Postby Hanover Fist » Sat Nov 11, 06 5:09 pm
Hanover Fist
