Two new Masterservers: Please test
Postby Imperial » Wed Feb 21, 07 3:20 pm
Could you please try and host on both of these Masterservers, I will show you how to both host on them and see them :
To just host on them enter this:
( The First one is is hosted courtesy of DarkKnightKiller , which is jsut hopefully permeanent if all works out, while the second is hosted by me, which will be temporarily/only as a test)
If you have Nephthys insert these two into your
[DeusEx.DeusExGameEngine]
ServerActors=Nephthys.NptServerUplink MasterServerAddress=67.86.252.168 MasterServerPort=27900
ServerActors=Nephthys.NptServerUplink MasterServerAddress=89.100.53.55
If you don't have Nephthys Insert this into
ServerActors=IpServer.UdpServerUplink MasterServerAddress=67.86.252.168 MasterServerPort=27900
ServerActors=IpServer.UdpServerUplink MasterServerAddress= 89.100.53.55 MasterServerPort=27900
And to see them: (Without mmuserinterface)
[DeusEx.MenuScreenJoinGame]
;MasterServerAddress=67.86.252.168
for my one to be seen you put ;MasterServerAddress=67.86.252.168
and for DarkKnightKiller's to be seen you put
;MasterServerAddress=89.100.53.55
so the one without the ; entry may be seen and the one with it, will not.
Or alternatively, you can use MMuserinterface, which is simple, so I don't need to explain that.
Remember at the moment, this is only a test
Postby Alex » Wed Feb 21, 07 3:34 pm
Did you guys open all ports? Not only 27900 but also 28900?
Postby Imperial » Wed Feb 21, 07 3:37 pm
That isn't appearing up in cmd to be opened.
Tell me how to open it and I will.
"Listening for and servicing Messages
"Approved: 3
Pending: 0 Ignored: 0 rejected:0"
Postby Hacker_>< » Wed Feb 21, 07 3:42 pm
address need to be domain names because when the they get resolved in unreal script its string to ip
Hacker_><
Postby Imperial » Wed Feb 21, 07 3:44 pm
So it won't work without domain then?
Postby Alex » Wed Feb 21, 07 3:45 pm
It does work. You need to open 27900 & 28900 in your router.
Postby Imperial » Wed Feb 21, 07 3:46 pm
i don't have a router :wink:
Postby Alex » Wed Feb 21, 07 3:48 pm
Can you browse the masterserver list? Since I can't.
Postby Hacker_>< » Wed Feb 21, 07 3:49 pm
i try to connect my server to the master server and on the console it shows nothing of a connection to the master server.
Hacker_><
Postby Imperial » Wed Feb 21, 07 3:51 pm
We discovered ucc Masterserver after cd\deusex\system is better instead of ucc master masterserver.ini
Postby Hacker_>< » Wed Feb 21, 07 3:55 pm
so your using ucc masterserver c\deusex\system?
Hacker_><
Postby Imperial » Wed Feb 21, 07 3:56 pm
~[A]lex~ wrote:Can you browse the masterserver list? Since I can't.
Yes, but nothing shows on either one _ _
Approved: 2
If its approved why in Gods name isn't it shwoing..
Postby Hacker_>< » Wed Feb 21, 07 3:59 pm
i just try that in cmd and its only loading a master server without any settings. Thats why you use the masterserver.ini.
Hacker_><
Postby Imperial » Wed Feb 21, 07 4:02 pm
are you using sdk?
Postby Hacker_>< » Wed Feb 21, 07 4:03 pm
no i am just using cmd and ucc.exe.
Hacker_><
Postby Imperial » Wed Feb 21, 07 4:06 pm
oh you already have ucc?
Oh then it doesnt matter.
Although, it wouldn't do any harm to install sdk, retry it and see what happens
Postby Imperial » Wed Feb 21, 07 4:10 pm
Hacker_>< wrote:so your using ucc masterserver c\deusex\system?
no no
cd\deusex\system
and after that ucc masterserver
Postby Hacker_>< » Wed Feb 21, 07 4:12 pm
yes but you are still loading it without any settings. when you load it does this come up.
!! Loading Config: MasterServer.ini
GameName: DeusEx
Operation Mode: TCPLink
!! Loading TextFile Operation Mode Defaults
TextFile Mode Output: servers.txt
!! Loading TCPLink Operation Mode Defaults
TCPLink Mode Service Port: 7792
!! Initializing sockets.
UDP socket bound at port 27900
TCP socket bound at port 7792
Listening on TCP socket.
!! Listening for and servicing messages.
Approved: 0 Pending: 0 Ignored: 0 Rejected: 0
Hacker_><
Postby Imperial » Wed Feb 21, 07 4:15 pm
ah ok.
I am getting the same message as you are, except Approved : 1
EDIT: Approved 3 now
Postby Hacker_>< » Wed Feb 21, 07 4:28 pm
did you get any more approves?
EDIT:can you see my server in the list
Hacker_><
Postby Allan » Wed Feb 21, 07 4:34 pm
Nope, can't see your server =(
But it seems uplinks are working:
ScriptLog: UdpServerUplink: Master Server is 67.86.252.168:27900
ScriptLog: UdpServerUplink: Port 7782 successfully bound.
ScriptLog: UdpServerUplink: Master Server is 89.100.53.55:27900
Postby Imperial » Wed Feb 21, 07 4:37 pm
[A]llan wrote:Nope, can't see your server =(
Yes, uplinks are most certainly working, for me too, but the servers jsut aren't showing, for reasons unknown to me.
However, to avoid any confilct/prevention of the servers not been seen, I took away anything reguarding dxmtl.eu and gamespy, both which are being attacked.
Postby Imperial » Wed Feb 21, 07 4:53 pm
Approved, from 5 to 2 now to 3
Postby Alex » Wed Feb 21, 07 5:14 pm
You guys really did something wrong. I just setup a MS, and it works just fine.
ServerActors=Nephthys.NptServerUplink MasterServerAddress=82.157.195.191 MasterServerPort=27900
Postby Imperial » Wed Feb 21, 07 5:14 pm
Could you come onto MSN please Alex?
Postby Alex » Wed Feb 21, 07 5:16 pm
Which one?
Postby Hacker_>< » Wed Feb 21, 07 5:19 pm
i think i know why there master server is not showing other servers. When my server connects to there master server it keeps get a ē\status\ request every second from 207.38.8.15.
masterserver.ini
(709 Bytes) Downloaded 286 times
Hacker_><
Postby Alex » Wed Feb 21, 07 5:27 pm
Hacker_X, you gave Imperial your masterserver.ini? Could you attach it please?
Postby Alex » Wed Feb 21, 07 5:43 pm
Ok, Hacker_X, your MasterServer.ini is wrong. It's bugged. Imperial now hosts a masterserver which works. I tried it myself.
Postby Kaiden » Wed Feb 21, 07 5:45 pm
How do you connect to his masterserver? (Imperials)
