[MUTATOR] MMImTyping
Postby Allan » Mon Oct 09, 06 4:21 am
~MMImTyping~
~Description~
This mutator shows up a speech bubble above the heads of any players typing, so people know when they're about to type-kill someone :)
~Version~
This is version 1.1 of this mutator.
~Features~
Shows when a player is typing a message, by displaying a speech bubble above their head.
Penalises players for killing players that have been typing over a certain time frame.
Hides bubbles of those in cloak.
Prvents type kills on people in cloak counting against a player.
Allows players to be in God while typing(Not recommended, off by default)
~Known Bugs~
The only bugs I've found so far are:
- The bubble doesn't attach to the player properly. By this, I mean you can just walk away from the speech bubble, if you hold down a directional button before typing.
- Crouching, then starting typing, then uncrouching results in you getting the bubble going straight into the middle of your head.
- Using Typers in God prevents people from using God without having it bound to a key.
~Special Thanks~
[A]lex for trying to help with the code (Sorry I couldn't get back to you :( )
Gunz Online, for giving me the idea.
Everyone I Type-Killed to test the kicking on! xD
~Other~
This mod has been protected with [A]Nobody's protection tool.
Anyone desiring a non-protected version, drop me a PM/Email, and i'll get back to you. :)
Full installation instructions are avaliable in the read-me file that comes with this mod's .zip (Even though it is mainly automatic)
~Download Linkage~
*See attached file*
MMImTyping Self Installer.zip
MMImTyping -- Displays when players are talking by making a floating speech bubble above their head. (This version is practically self installing. Just needs some editing to the .ini)
(44.79 KiB) Downloaded 1781 times
MMImTyping110.zip
MMImTyping -- Displays when players are talking by making a floating speech bubble above their head. (This version is manual install only.)
(11.37 KiB) Downloaded 1890 times
Postby clyzm » Mon Oct 09, 06 4:28 am
Good job.
God mode isn't a good idea, but meh.
Postby Dae » Mon Oct 09, 06 7:50 am
Wow great job :)
But I'd improve the texture a bit.
Also we don't use 'v', like MMName100, not MMNamev100.
Postby ~ô¿ô~Nobody~ » Fri Oct 13, 06 6:51 pm
A very nice addition to MP. Indeed.
I'll give you some performance hints about it later. :)
Postby Allan » Sun Oct 15, 06 11:51 pm
*Updated -- 15.10.06, 23:51*
MMImTyping100 is here!!! =D
Postby KillerZ » Sat Oct 21, 06 6:53 am
I have a bad browser, can I get a diffrent download link?
IM tryiong to D/L download.php instead o f the file
KillerZ
Postby Dae » Sat Oct 21, 06 7:58 am
KillerZ wrote:I have a bad browser, can I get a diffrent download link?
Just rename download.php to MMImTyping100.zip
Postby VodunLoas » Sat Oct 21, 06 8:04 am
That may not work dae. I had this happen on certain sites before, and it actually downloaded the .php page. It didnt show any of the code embeded, just the html you see.
Postby Allan » Sat Oct 21, 06 8:14 am
Here's the link I put up on the DXC boards: http://uploads.kcorphq.co.uk/uploads/Mo ... ing100.zip
Should work A-ok! =)
Postby Gishank » Sat Oct 21, 06 8:32 am
Allan, you can always apply for a private account so your files are not 100% public....
LINKAGE!
Postby KillerZ » Sun Oct 29, 06 12:02 am
The Night Watchman
You have the same avatar that I use at .: ALLGAMINGNETWORK :. and THe Chrono Compendium, Its my Favorite "Unablee to give a damn, stopping"
Admin: read rules before posting
KillerZ
Postby Gishank » Sun Oct 29, 06 9:34 am
I presume there was flame there before about me removing it before an admin edited it...
Well look, this picture is near enough everywere on the net, it's not as if you own it.
Postby Dae » Sun Oct 29, 06 10:37 am
No, there wasn't. It's just an off topic.
Postby KillerZ » Mon Nov 20, 06 1:39 pm
Aahh Sorry, That should have been sent in PM.
As for this mod, ITs been nstalled on my server a while now, and its EXELLENT
KillerZ
Postby Allan » Sun Dec 17, 06 1:01 pm
~~~Updated to MMImTyping110~~~
(Now also has automatic install version, with only deusex.ini fiddling with needed to completely install it!)
Postby Kaiden » Sun Dec 17, 06 1:06 pm
Nice 8) No need to download it though, already set it up! :)
Welcome back to the forums.. You seem to have been away for a while O_o.
Postby Allan » Sun Dec 17, 06 1:11 pm
Ya, AOL cut my internet off... (They're hereafter to be called Arseholes On-Line by my family forever more.)
Postby ~ô¿ô~Nobody~ » Sun Dec 17, 06 1:12 pm
I'd never choose AOL. AOL needed to pay me for using their ISP offers. :lol:
Postby Allan » Sun Dec 17, 06 1:15 pm
My parents are internet n00bs. That's probably the only reason we ever had AOL.
Postby Imperial » Sun Dec 17, 06 1:37 pm
~[A]Nobody~ wrote:I'd never choose AOL. AOL needed to pay me for using their ISP offers. :lol:
HMM? :?
Postby Dae » Fri Feb 02, 07 6:34 pm
Find the line : [DeusEx.DeusExGameEngine], then add the lines:
ServerActors=MMImTyping110.MMIAmTyping
ServerPackages=MMImTyping110
After that, you run your server, and provided you have DXMTL, or some equivilent (AlrightyGame,CRDBugFix,
miniMTL,etc...), you should be able to select a mutator. Turn MMImTyping110 on. After this, run your
server as normal.
These are two different installation methods. Servers who did both may have the mutator spawned twice.
Postby ~ô¿ô~Nobody~ » Fri Feb 02, 07 6:35 pm
..which might end in a crash, due to infinite script recursion :P
Postby Tonnochi » Tue Jun 26, 07 4:05 pm
Type-killing is whining. End.
Nice mod, I've seen it around a lot. It's good when it doesn't fly up in your face.
Postby thinkr » Fri Aug 03, 07 8:01 pm
server as normal.
I did see mine spawned twice... so to make it just once... I would remove both lines or just the ServerActor= part? isn't Serverpackage just make it a download by the client? or should i delete both if i enable it in the DXMTL
thinkr
Postby Dae » Fri Aug 03, 07 8:15 pm
If you enabled the mutator in the mutators window AND edited .ini, then just get rid of both lines in deusex.ini
Return to alpha laboratories
