[MUTATOR] MMPlayerStats
Postby Alex » Sun Dec 17, 06 8:10 pm
<center>MMPlayerStats</center>
Description
This mutator saves some information about players.
It saves for example the player who got the most kills, or most deaths.
It currently saves the following: most Kills, most Deaths, biggest Streak, best Kill/Death Ratio.
I have added the ratio, so you can kind-of see who the best player is.
Of course, it is possible that people obtain kills through fighting weak, or strong players, but I cannot implement that in the mod, so I need to keep it like this.
Installation
Just throw MMPlayerStats100.u into your system folder, and open up DeusEx.ini.
Then, go look for "[DeusEx.DeusExGameEngine]" and below that, add the following line:
ServerActors=MMPlayerStats100.PlayerMutator
Usage
When someone dies, for whatever reason, or if someone kills someone else, your kills/deaths/streak/ratio gets compared to those saved as best. If yours are better, a new record is being saved, together with the name you were playing under, and the time of when you got the new record.
You can see who is currently has the record, by using the following command:
Mutate Game.Stats
If you find any bug, report it as soon as possible. I haven't tested this mod as much as I normally do, since I didn't had the time for it.
MMPlayerStats100.u
(8.2 KiB) Downloaded 1675 times
Re: [RELEASE] MMPlayerStats [Mutator]
Postby ~ô¿ô~Nobody~ » Sun Dec 17, 06 8:13 pm
~[A]lex~ wrote:If you find any bug, report it as soon as possible. I haven't tested this mod as much as I normally do, since I didn't had the time for it.
Right, first quantity, then quality :!: :P
Postby Alex » Sun Dec 17, 06 8:14 pm
I did test it! I murdered 40 JCDentonMale's! And I suicided 20 times!
Postby Allan » Sun Dec 17, 06 8:14 pm
Wow man, this sounds good. You're churning out mutators like goodness knows what!
Has MMImTyping110 inspired you? :lol:
Postby ~ô¿ô~Nobody~ » Sun Dec 17, 06 8:17 pm
I r teh fortuneteller. And I say, that he will say no!
Postby Alex » Sun Dec 17, 06 8:43 pm
[A]llan wrote:Wow man, this sounds good. You're churning out mutators like goodness knows what!
Not really :P I just had a lot of idea's lying around, but never got to 'em.
Postby Mastakilla » Sun Dec 17, 06 10:30 pm
Nobody predicted that! It's the end of the world I tell you...
Return to alpha laboratories
Users browsing this forum: No registered users and 8 guests
