Many questions about computer parts
Postby Dae » Thu Jul 30, 09 10:16 pm
1. Would you choose a water cooling over air one?
2. Would you choose QX9650 (older gen — Core 2) over i7 920 (new gen — Nehalem)?
3. Would you overpay for Core i7 965 to get better performance at Adobe Suite or any other professional apps?
4. Would you overpay for NVidia Quadro to get better performance at Adobe CS4 or any other professional apps? If so, which NVidia Quadro would you choose in terms of best price/value ratio?
5. Additionally, what would you choose to work with professional apps: hyperthreading or overclocking? (I can't do both for some reason on Core i7 920).
Any thoughts on any of the questions are welcome. Thanks.
Postby clyzm » Thu Jul 30, 09 10:20 pm
1. No, I believe air cooling is easier to install and requires less maintenance not to mention is cheaper overall.
2. Yes. I believe i7 is extremely overpriced even for today's standards, not to mention the unique X58 mobo that you have to buy. Core 2 Extreme uses older LGA 775 or even LGA 771 (QX9775 only) which is versatile with most Intel builds today
3. No I would not -- I'd rather use a Quadro or similar graphics accelerator.
4. Yes -- the CX accelerator edition for CS4: http://www.nvidia.com/object/product_quadro_cx_us.html
5. Both are very important - but hyperthreading is a bit more important to me due to 3D rendering. If I had a Skulltrail build they wouldn't be problems, since it is 8 threads with 3.2+ ghz clock
Postby Dae » Fri Jul 31, 09 2:18 pm
Thanks for the advice, Derek.
Quadro CX indeed, I meant — which of them? There is 1700, 3700, 5600:
http://www.compusa.com/applications/cam ... aignID=759
Postby clyzm » Fri Jul 31, 09 2:22 pm
Dae wrote:Thanks for the advice, Derek.
Those are the Quadro FX series - CX is a unique version meant only for Adobe CS4. I used to have one, I think it was an FX 1700, at work, believe it or not :^D
I would also look at the latest FireStream cards from AMD - they seem cheaper and more functional than Quadro series. Alternatively, if your workload is more scientific and requires superprocessing, you can always pick up a Tesla. I've always wanted to try out one of those.
Postby Dae » Fri Jul 31, 09 3:05 pm
Oh wow looks like I've mixed them up. Thanks.
Is there still any point in getting an FX card? CX seems to be too overpriced and an overkill for solely Photoshop editing, as the only thing it does better is zooming and navigating on big pictures (it doesn't speed effects up and such).
Postby clyzm » Fri Jul 31, 09 3:54 pm
Dae wrote:Oh wow looks like I've mixed them up. Thanks.
Oh it does, just that it works with other programs as well, especially Premiere. Render time is much faster with it.
It depends on what you use. Quadros are for digital content creation and CAD - this means they'll mostly help with multiple monitor solutions. When I was using the FX 1700 at work, I barely noticed a difference from using my GTX 260 in Cinema 4D, Maya, 3DS Max and XSI.
If you're looking for Photoshop and CS4 stuff, you can either get a CX or just upgrade your processor and RAM. FX doesn't specifically help "speed" up CS4 products.
Postby Dae » Fri Jul 31, 09 4:11 pm
Interesting.
All reviews I've read didn't convince me that I should get a CX for Photoshop. It makes much sense for Photoshop 3D editing and Premiere though.
New question: is there any point in a two processor configuration? Like, Xeon 5500?
Postby clyzm » Fri Jul 31, 09 4:18 pm
Dae wrote:Interesting.
Oh yes, server processing power. Dual processors are very powerful, and most likely they'll give you that "boost" of speed you'll need for Photoshop or similar.
I don't see a huge benefit though - I have a mid-level quadcore with 8GB of RAM, and Photoshop CS4 is extremely fast for me, even when opening/editing renders of 5,000 x 5,000 pixel size and higher.
Postby James » Fri Jul 31, 09 4:19 pm
By dual processors are we talking about dualcore or 2 processors running along side by side?
Postby clyzm » Fri Jul 31, 09 4:22 pm
James wrote:By dual processors are we talking about dualcore or 2 processors running along side by side?
The latter, like watered down Skulltrail builds.
Postby Dae » Sun Sep 27, 09 7:27 pm
SAS drives — would you use them?
Postby Siva » Sun Sep 27, 09 9:07 pm
Dae wrote:1. Would you choose a water cooling over air one?
Nope. Watercooling is overkill and requires too much maintenance.
Nope. I THINK that that i7's are more power/heat efficient and that is a gain imo.
No. It's still going to take a while and I'm patient.
If I was a professional yes, it's like buying a taxi license to be a taxi driver imo.
Overclocking.
Postby clyzm » Mon Sep 28, 09 12:24 am
core i7s are not heat efficient at all lol, and they use like 120W
Postby ~[ß]Lost~ » Mon Sep 28, 09 9:05 am
Dae wrote:New question: is there any point in a two processor configuration? Like, Xeon 5500?
Only if you want to set up a data server box.
Sike
clanb.deus-ex.net
~[ß]Lost~
Postby Siva » Mon Sep 28, 09 11:27 am
portable mp3 player wrote:core i7s are not heat efficient at all lol, and they use like 120W
Statement retracted
Informant killed
