Hitman 2 - Silent Assassin
Postby ~SaSQuAtCH~ » Sat Dec 12, 09 2:48 pm
Downloaded this today and I'm facing some real shit bugs here..
I installed, all goes fine, I don't even need a crack or something but when I enter the game and set up the movement keys instead of arrows (that's default option) to WASD, my character won't move as it's supposed to.. It acts like when I press "W" it leans right, "A" button makes it walk backwards etc.
However this problem is solved by 1.1 patch. But when I install that patch and crack the game, I lose all sound. I can't even set up sound settings because in the menu I can't select that line.
I tried installing 1.2 patch but the installer can't find the folder and I can't manually locate it either.
Halp anyone? :(
Postby Professor Layton » Sat Dec 12, 09 3:52 pm
You using a crack? Patches usually need the original exe to work. (or the one from the last patch)
Postby MainMan » Sat Dec 12, 09 4:32 pm
Install a clean version, patch it, and then crack it (using the crack for version 1.2, not for 1.0)
Postby ~SaSQuAtCH~ » Sun Dec 13, 09 12:31 pm
Clix wrote:You using a crack? Patches usually need the original exe to work. (or the one from the last patch)
Ye I'm using crack, but I have different cracks for 1.0 and 1.1
MainMan wrote:Install a clean version, patch it, and then crack it (using the crack for version 1.2, not for 1.0)
I don't have a crack for 1.2 but I can't install 1.2 patch anyway. The version I have is probably warez, that's why it didn't ask for a crack right after installation.
Postby Professor Layton » Sun Dec 13, 09 9:49 pm
Get another download then ye :$
Postby Mastakilla » Tue Dec 15, 09 5:23 am
~SaSQuAtCH~ wrote:I'm using crack
Postby ~SaSQuAtCH~ » Tue Dec 15, 09 12:30 pm
for 1.1, not 1.2 :P
1.0 didn't require a crack
Postby Aidan » Thu Dec 17, 09 3:17 pm
I liked contracts, and blood money the best.
Postby synthetic » Thu Dec 17, 09 9:23 pm
Could you run bloodmoney without problems to the end? I had some gamebreaking bugs there :S
Postby Bob » Fri Dec 18, 09 1:56 am
Hitman 2? Shoot the guy in the cock.
