Uploading Avatar
Uploading Avatar
Postby Gustertote » Sun Jun 05, 05 2:22 am
Hey, im having a problem with uploading pictures from my machine onto my avatar...it wont let me for some reason...altho i can guess from what it sez at the top....
Warning: copy(./images/avatars/211572731242a2535cad596.jpg): failed to open stream: Permission denied in /home/dxalpha/public_html/forum/includes/usercp_avatar.php on line 238
Warning: Cannot modify header information - headers already sent by (output started at /home/dxalpha/public_html/forum/includes/usercp_avatar.php:238) in /home/dxalpha/public_html/forum/includes/page_header.php on line 482
Warning: Cannot modify header information - headers already sent by (output started at /home/dxalpha/public_html/forum/includes/usercp_avatar.php:238) in /home/dxalpha/public_html/forum/includes/page_header.php on line 484
Warning: Cannot modify header information - headers already sent by (output started at /home/dxalpha/public_html/forum/includes/usercp_avatar.php:238) in /home/dxalpha/public_html/forum/includes/page_header.php on line 485
wtf?
help please...
BLUE and RED
Gustertote
Postby Alistair » Sun Jun 05, 05 3:43 am
gayed
Postby Alex » Sun Jun 05, 05 9:09 am
Maybe the premissions aren't set right.
Postby ~ô¿ô~Nobody~ » Sun Jun 05, 05 11:06 am
btw.. i wasn't able to upload an attachment for a post in my MPKeypad topic too
Postby James » Sun Jun 05, 05 11:19 am
I'll let Darren fix this.
Postby ~D[A]rren~ » Sun Jun 05, 05 12:52 pm
~[A]LTKJAY~ wrote:I'll let Darren fix this.
Nah you won't, It's a database error, "Calls for Dae" 8)
JC
Postby DarkKnight » Sun Jun 05, 05 1:01 pm
JC
Unless you store you avatars in the db, it is a file permission problem ;)
It can not open a stream to copy it.
Those are caused by the first error sending the headers early.
Postby ~D[A]rren~ » Sun Jun 05, 05 1:03 pm
JC
That's what I meant. :P He deals with that too, unless you can tell me what to do?
JC
Postby DarkKnight » Sun Jun 05, 05 1:11 pm
~D[A]rren~ wrote:
JC
JC
Depends on your setup, try this: chmod -R 0775 /home/dxalpha/avatars/
(Assuming thats where the avatars are kept.)
Postby ~D[A]rren~ » Sun Jun 05, 05 1:14 pm
DarkKnight wrote:
~D[A]rren~ wrote:
JC
JC
So I just set the chmod number on that folder to 0775?
JC
Postby DarkKnight » Sun Jun 05, 05 1:17 pm
Indeed.
Although doing it recursivly is always good. :)
Postby ~D[A]rren~ » Sun Jun 05, 05 1:19 pm
DarkKnight wrote:Indeed.
What does that mean? :P and it isn't that folder, the folder I can find with all the uploaded files in is called 'files' and its CHMOD properties are set to 755 not 775, should it be set to 775?
JC
Postby DarkKnight » Sun Jun 05, 05 1:30 pm
Ok, chmod changes the permissions on any given file/directory.
0775 is just the code that really means this:
~~~~~~~Read~~~Write~~~Execute
Owner~~~~X~~~~~X~~~~~~X~~
Group ~~~~X~~~~~X~~~~~~X~~
Others~~~~X~~~~~~~~~~~~X~~
In other words, the group and the ownder can write to it.
The code to allow anyone to write to it would be 0777, but thats a bad idea.
Also, your avatars are held in a different place to the files (although possibly in the files dir), if uploads work, simply give avatars the same permissions. :)
Postby ~D[A]rren~ » Sun Jun 05, 05 2:05 pm
DarkKnight wrote:Ok, chmod changes the permissions on any given file/directory.
Ok, I found the avatars folder, the uploading files don't work on 755, or 775 so whats the point changing the avatars one? DK, got any ideas?
Darren AKA [A]JCDenton says:
DK? I'm confused
Stevie/123 164 145 166 151 145 says:
About what?
http://www.dxalpha.com/forum/viewtopic.php?p=73053#73053
Ah.
The uploading files dont work on the original number of 755, and then i chmodded the folder to the 775 number and it still dont work
Damn...
What kind of host is this?
Pro host?
www.collateralfx.net
(Linux I'm assuming)
yes
Ok, try this real quick, chmod the directory to 0777. Try uploading an avvie, and if it doesn't work, chmod it back to 0755
ok hang on
Upload Error: Could not upload Attachment to ./files/1_125.jpg.
Does it state why?
no
Ah, thats files
Not avvies
yes
Did you chmod files instead of avvies?
yes, becuase there the same number, 755
Ah.
Hmmm...
How very strange...
yes
im going to try and chmod avvies to 775 and see if they work
I'd probly have to be sitting in front of it to help anymore
If it doesn't work as 0777, then it isn't a file permission problem... :-k
im going to try avvies though, files might be a different problem
Yeah.
just so you know; 0777 would let any user on the server write to that file.
If that fixes the problem, then your web host has PHP running as a user it would seem...
user with a lower uid anyways.
k avvies work on 777
well it says avatars must be less than 20kb so its working
Cewl.
You should talk to your web hoster and see if there is anyway to get them working besides using 0777, since it isn't 100% secure.
i will do when he comes back online, or get dae to, but why dosent files work?
Does it spit out any errors?
no, just that Upload Error: Could not upload Attachment to ./files/1_125.jpg.
Also, are you using IE or Firefox?
IE, but other people have had the prob
Ah, nm, it would give more errors...
k ill talk to dae and hoster,thanks
no worries.
It'll probly be something small.
cool
Although no doubt it will need to be set as 0777 if that got the avvies working...
Ah well, wait for dae.
Yeah i will, thanks mate.
JC
