"I can't see my server in the server list"
Postby ~SyStEm~ » Fri Nov 23, 07 4:21 pm
~[A]Kaiden~ wrote:Try the following -
admin
Admin
password
pass
1234
If not, and no-one has changed it manually, then look in your Help Document you should have with it, you will be told the default code.
If someone has changed it and forgotten it, you should be able to reset your router to factory default.
Either push a pin into a small hole in the back of the router for like 10-20 seconds, or do it from your Router Menu (192.168..etc) if possible!
it worked thanks :P i offer u cake.
¤թí§§ ƒÄ©€¤
....(^_^)....
._/...._..
Win.
~SyStEm~
Postby Kaiden » Fri Nov 23, 07 6:10 pm
Which part lol? I suggested like 8 different things. :shock:
Postby ~SyStEm~ » Sat Nov 24, 07 4:08 pm
my server still show up in the LAN i cant get it worky :(
¤թí§§ ƒÄ©€¤
....(^_^)....
._/...._..
Win.
~SyStEm~
Postby Bear » Sat Nov 24, 07 4:13 pm
Fuck sake , to see it in inertnet open port 7730 , you will always see it in LAN , people can see it in internet even if you cant , ports are always the problem... If only you could use UpNp
Bear
Postby ~ô¿ô~Nobody~ » Sun Nov 25, 07 12:26 am
You could just see your own server in the internet list, if your router supported NAT loopback, which most routers do not support.
Postby Kaiden » Sun Nov 25, 07 12:40 am
Mine is in Internet list hehe.
Postby ~ô¿ô~Nobody~ » Sun Nov 25, 07 12:43 am
Cos you're special.
You are the chosen one! :o
Postby Kaiden » Sun Nov 25, 07 12:57 am
Yay me.
Postby Bear » Sun Nov 25, 07 7:50 am
Why dont you just upgrade the FirmWare of the router? When I upgraded it I could see in internet list without opening port 7730.
Bear
Postby ~SyStEm~ » Fri Nov 30, 07 5:28 pm
oh yeh =D
¤թí§§ ƒÄ©€¤
....(^_^)....
._/...._..
Win.
~SyStEm~
Postby Artin » Sun Dec 02, 07 4:45 am
erm...I've been following your directions and such, and for some reason I still can't see the server. I'm not really great with a computer, so can you help me out? Every time i start up the server the console thing says a variation of "Nephthys: 2007/12/01 19:45:12: Uplink query rejected from non-master server 207.38.8.27:1199" and such. What do i need to do?
I've also tried uninstalling nephthys, but then i can't go on DX, and it tells me to reinstall Nephthys.
Artin
Postby Zora » Wed Dec 05, 07 5:14 pm
Please attach your server's current DeusEx.log and DeusEx.ini (without passwords, etc.).
Zora
Zora
Nephthys developer
Postby Artin » Thu Dec 06, 07 4:02 am
Erm...here are the DeusEx.ini and DeusEx.log...
DeusEx.ini
(11.67 KiB) Downloaded 1383 times
DeusEx.log
(19.75 KiB) Downloaded 1556 times
Artin
Postby Zora » Thu Dec 06, 07 5:55 pm
DeusEx.log wrote:DXMTL: InitGame: ?Game=DXMTL152b1.MTLTeam?Mutator=mPack1.DXWeaponSelector,Nephthys.Nephthys?listen?Name=Player?Class=DXMTL152b1.MTLJCDenton?Team=1?Skin=?Face=
Nephthys is NOT a mutator. Remove it from the list!!!
DeusEx.log wrote:ScriptWarning: NptServerQuery DXMS_Breakout.NptServerQuery0 (Function IpServer.UdpServerQuery.PreBeginPlay:0030) BindPort: bind failed
ScriptLog: UdpServerQuery: Port failed to bind.
You have a port binding problem. Maybe you have to allow your Deus Ex server to listen on ports in your firewall. Maybe you configured your ports wrong. How exactly do you start your server? Are there any command line options? Please describe the exact steps.
Zora
Zora
Nephthys developer
Postby Artin » Fri Dec 07, 07 2:39 am
When i start my server, i start up DX, go to internet game, host, i choose my mutators, change the game settings (like augs, etc), make it Dedicated, then i start it. I'm pretty sure i did my port thing correctly, since I followed the portforward.com steps.
Artin
Postby Zora » Fri Dec 07, 07 8:34 am
What firewall do you run?
Zora
Nephthys developer
Postby Artin » Sat Dec 08, 07 1:31 am
erm.. Norton, right now, if that's what you mean.
Artin
Postby Survive. » Sat Dec 08, 07 1:59 am
Do you also have another kind of firewall like Windows SP2 or something?
Survive.
Postby Artin » Sat Dec 08, 07 3:56 am
erm... i think there's that windows defender thing too.
Artin
Postby Zora » Sat Dec 08, 07 12:42 pm
1. You must not run 2 firewalls at once. That never works, no matter which 2 products you combine. It's just a principle responsibility issue which can't be solved. Running 2 or more personal software firewalls at once gives you less security than running any product alone. Decide which suits best to you and use only that. Disable or uninstall all other firewalls.
2. I'm not sure about Norton, but some firewalls can prevent programs (like game servers) from binding ports to listen on them. Check all firewall rules in Norton if you have such a rule for your DX server (maybe it's an implicit rule which applies if no other rule fits). Only for a very short testing session I would suggest that you disable the firewall. Don't connect to the internet without any firewall all the time.
3. While your server is running, open a dos box (command prompt, e.g. by hitting WINDOWS+R and then enter "cmd.exe") and enter the command
netstat -anop udp
Send me the entire result in a PM.
Zora
Zora
Nephthys developer
Postby Kaiden » Sat Dec 08, 07 1:16 pm
I think Windows Defender just checks Startup programs, registry edits, etc.. I think.
Postby [RTK] Guy » Thu Dec 20, 07 7:52 pm
i need help i found the nat table but all i see is a log i cant type in there wat do i do? any help would b gr8 thx :)
[RTK] Guy
Postby Bear » Fri Dec 21, 07 9:27 am
Dont you create a new protocol? On my router is diffrent, as I have to make a service then firewall rules, I geuss you just make a new port, SRC and DST Im geussing are TCP/UDP, so just forward them both.
Bear
Postby Alex » Fri Dec 21, 07 10:15 am
Hi all! Please look at the start-post, I have changed it and it should probably work for all routers now!
Postby Imperial » Fri Dec 21, 07 11:43 am
Also, just to add on a bit of advice.
If you are trying to host a server, make sure that the lines in your ini for server packages and such correspond to the files in your system folder. So don't have motd listed in server packages if it has since been removed.
I'm pretty sure it's also the other way around. So if you decied to remove the motd mod from sytem folder, make sure anything relating to it in your ini is also removed. I'm not sure if this is because of Nephthys or just applies in general, but my server refused to show on the list until looked up my deusex log and saw a warning for motd.
Postby [RTK] Guy » Fri Dec 21, 07 10:59 pm
dident work :S idk y here is the log (i attemted manuly 2 go in the server and connect 2 a diff mad but it was stuck at the connecting screen [i could see it in lan but not internet and the map name was "Dx"])
user.ini
user
(12.73 KiB) Downloaded 1316 times
server log.txt
log
(11.96 KiB) Downloaded 1278 times
[RTK] Guy
Postby [RTK] Guy » Sat Dec 22, 07 4:02 am
sorry 4 double post but it wouldent let me edit :S
i dlled dx from the internet (apha dll section) and was wondering if it matters cas thats wat i heard
[RTK] Guy
Postby Bear » Sat Dec 22, 07 9:19 am
Alex, it does not work if you have a wirless bridge to do a wirless bridge it is very hard, I have a USB one so its easy for me, not sure about you guys with Ethernet.
Bear
Postby [RTK] Guy » Sun Dec 23, 07 12:34 am
i tried agian using the user.ini in the kb
serverlog 2.txt
log the 2nd time
(4.36 KiB) Downloaded 1306 times
User.ini
i got from the kb
(12.9 KiB) Downloaded 1158 times
[RTK] Guy
Postby [FTF]Freedom » Sun Dec 23, 07 12:46 am
Fuck sake to whatever numpty was yakking about 7730.... DX doesn't fkn use 7730!!
The ports are as follows:
UDP: 7790, 7791, 7792, 8777, 7666,
TCP/UDP: 27900
You probably will only need 7790-7792 and 27900 open.
Also if you have a router and use XP firewall, don't worry, just disable XP firewall. Your router will most likely give you enough protection. Especially if you have NAT (like me!)
Also if it helps, Netgear's DG834G modem/router is a nice, intuitive and (for me) very reliable router.
[FTF]Freedom
