"I can't see my server in the server list"
Postby Professor Layton » Sun Jun 24, 07 7:31 pm
:S, seems your deusex.ini doesnt have any
[IpServer.UdpServerUplink] section, replace your current one with the one i uploaded in attachment.
deusex.ini
(10.59 KiB) Downloaded 1278 times
Postby Tonnochi » Sun Jun 24, 07 8:17 pm
Alright thanks. Also, what about the other fixes? Those are just because I've lost my memory...
Postby Kaiden » Sun Jun 24, 07 11:17 pm
Have you added the map to your DeusEx.ini yet? Here's a guide how:
Open your Deus Ex.ini:
Locate this section (Near the bottom):
IF you can't see this, Open Deus Ex, click on Multiplayer>Lan>Host. Host a basic game, then close it. Open your .ini again and it should be there.
Enter the map name you want, in this case:
DXMP_FunLine_BigFlyingParty-2
Add this to the next avaliable number, most likely Maps[4]=.
Now the map is in your System. Next scroll abit up, and find this section:
You can see it says CurrentMap=. The map name after this will be the map that automatically starts if you, for example, run a .bat file I believe. To be fair, when you press Host, you can choose the map to host anyway.
Add the map you want, most likely
DXMP_FunLine_BigFlyingParty-2.
And of-course the final thing to do is:
So then, hope that helps!
Postby MainMan » Sun Jun 24, 07 11:39 pm
Nice try with the logo, but it's dxalpha.co.uk actually :wink:
Postby Tonnochi » Mon Jun 25, 07 1:26 am
~[A]Kaiden~ wrote:Here's a guide how:
That was awesome.
Postby Alex » Mon Jun 25, 07 7:03 am
~MainMan~ wrote:Nice try with the logo, but it's dxalpha.co.uk AND dxalpha.com actually :wink:
Postby Kaiden » Mon Jun 25, 07 1:59 pm
Lol, np, glad to help. I should probably add this to the KB. :D
Edit: Done! http://www.dxalpha.co.uk/kb/hosting/Add-ini-maps
Postby Tonnochi » Thu Jun 28, 07 10:08 pm
I don't have that section in my DeusEx.ini. I think I know why.
Postby Six Of Seven » Fri Jun 29, 07 2:53 pm
I had this problem and I never managed to fix it :(
Six Of Seven
Postby Karkian » Fri Jul 06, 07 7:10 am
Same with me, i followed a tutorial on how to open my ports, but it'll never work, i turned my firewall off and i get the same results :cry:
Karkian
Postby Alex » Fri Jul 06, 07 7:20 am
Ok, since you all have different routers, I have a better tutorial.
Step 1
Go to http://www.portforward.com/routers.htm and find your router (And click on the link, of course)
Step 2
Go to the list with all D's, and look for 'Dues Ex' (Yes, Dues! They made a mistake, a stupid one), and click on the link.
Step 3
Follow all instructions that are on the page you reached.
Postby Karkian » Fri Jul 06, 07 10:33 am
Lol, i'm so smart i already done that and it still wont show :shock:
Karkian
Re: "I can't see my server in the server list"
Postby ~[ß]iohazardous~ » Fri Jul 06, 07 9:42 pm
Alex wrote:As port range, we need to open the following ports:
7790
7791
7792
8777
27900
From the deus ex Readme file :
make sure that ports 7790, 7791, 7792 and 27900 are allowed through.
so the port 8777 isn't needed
~[ß]iohazardous~
Postby Alex » Fri Jul 06, 07 10:10 pm
That's old. I know 27900 isn't required aswell. At least, I tried hosting a server without having 27900 & 8777 bound, and that worked out just fine.
Postby Karkian » Sat Jul 07, 07 6:39 am
Well, seems ill never be able to host :(
Karkian
Postby Allan » Sat Jul 07, 07 3:54 pm
Alex wrote:That's old. I know 27900 isn't required aswell. At least, I tried hosting a server without having 27900 & 8777 bound, and that worked out just fine.
Is it just me, or do games now show up regardless of being hosted on LAN or internet? I keep hosting LAN games for my friends, yet somehow it keeps getting gate-crashed by DX-ST members asking for admin/killing my mates...
Postby ~ô¿ô~Nobody~ » Sat Jul 07, 07 4:03 pm
LAN server just means that the uplink is not set.
If the ports are forwarded, others can still join if they know IP and port.
Postby Allan » Sat Jul 07, 07 4:30 pm
But it also shows up on internet games to me, despite the fact i'm behind a router, with properly forwarded ports, regardless of whether it's a LAN game or not... =S
Postby ~ô¿ô~Nobody~ » Sat Jul 07, 07 4:31 pm
Then the uplink is set..
Apart of that, it's unlikely that you see your own server shown in the internet. :?
Postby Allan » Sat Jul 07, 07 4:36 pm
Ah well, I'm not complaining. ( that much :P )
It's just an inconvenience that I can't host in privacy. But I guess it's better than most people here.
Postby ~ô¿ô~Nobody~ » Sat Jul 07, 07 4:46 pm
Yeah, most will have the problem the other way around.
Postby Kaiden » Sat Jul 07, 07 4:51 pm
Yeah, I hosted a LAN to test a map I was making and like 5 people came on complaining it wasn't RPG lol.
Postby Allan » Sat Jul 07, 07 4:58 pm
Are you using MMUserInterface160, per chance?
Postby Kaiden » Sat Jul 07, 07 11:24 pm
Not when I last hosted on LAN I wasn't.
Postby x_Rewind_x » Sun Jul 08, 07 12:58 am
I used to have this probelm but i fixed it by going to my router configation and forwarding the ports:
TCP 7790 - 7792
UDP 27900
hope this helps some people who are having the saem problem
x_Rewind_x
Postby Karkian » Mon Jul 09, 07 7:46 am
x_Rewind_x wrote:I used to have this probelm but i fixed it by going to my router configation and forwarding the ports:
TCP 7790 - 7792
UDP 27900
Would'nt everyone would've done this? because like, who wouldnt of opened them,ready a tutorial saying to open those ports :roll:
Karkian
Postby ~{17}~JIN~ » Mon Jul 09, 07 7:31 pm
some people don't know know how to open their ports even with a tutorial.. :roll: Its not as explanatory as a real human being who knows what to do, doing it right beside the other one.
~{17}~JIN~
DarkVader
Postby clyzm » Mon Jul 09, 07 9:12 pm
[EL]PenetrationBat wrote:some people don't know know how to open their ports even with a tutorial.. :roll: Its not as explanatory as a real human being who knows what to do, doing it right beside the other one.
wtf, that makes no sense
Postby Karkian » Mon Jul 09, 07 11:00 pm
Wtf, if they didnt knew how to open their ports, then what was that post all about? it wouldn't of helped me at all :?
Karkian
Postby Kaiden » Tue Jul 10, 07 12:02 am
I didn't know how to open ports in my very old router, so I go Alex to Remote Desktop my computer and have a look at it. :wink:
Users browsing this forum: No registered users and 13 guests
