Serverlist GPF
Serverlist GPF
Postby Jon » Fri Jun 22, 07 9:45 pm
Might be associated with the recent install of MMUserInterface, but its really starting to annoy me.
In the serverlist, any double click of a server name causes an immediate GPF relating to my double click, although I can connect via IP/Join Game button as normal. Image as attached.
Postby Magus » Fri Jun 22, 07 11:08 pm
I posted up a log of one of these errors like, a month ago in the GPF collection topic or whatever it was called.
Magus
Postby MainMan » Fri Jun 22, 07 11:08 pm
I think it's to do with MMUserInterface. Try removing it and see if you still get the error.
Postby Jon » Sat Jun 23, 07 7:58 am
No, its all good when the mod is disabled.
Thats a bummer.
Postby Professor Layton » Sat Jun 23, 07 8:28 am
I'm using an older version off MMUserinterface, 120 I believe, never gave any problems as far as I know. I could upload it if you want, dunno what the keychanges are between 120 and latest, though.
Postby Jon » Sat Jun 23, 07 7:25 pm
No its fine, I'll cope without.
Re: Serverlist GPF
Postby synthetic » Sat Jun 23, 07 8:30 pm
Jon wrote:Might be associated with the recent install of MMUserInterface, but its really starting to annoy me.
When I started DXMP it was the first reoccurring cause for GPFs for me, so I dont think it is because of the mod.
I think the problem solved by itself, I just got used to clicking once on the server and then clicking manually on the connect button..
Also it didnt happen 100% but more like.. often. Back then I didnt even have MTL.
Postby Alex » Sat Jun 23, 07 8:47 pm
MMUserInterface somehow motivates the bug to come up more often. I have 2 DX's installed, well, had, I deleted them both, but on one DX it worked all fine, and on the other it didn't. I will find out why and how.
Postby Tonnochi » Sun Jun 24, 07 1:10 am
I'm always getting errors related to MMUI. Shake it off man.
Postby Kaiden » Sun Jun 24, 07 1:11 am
I used to get it whenever I tried to join a server.. Now I get it sometimes.. Like, if I play on a server and disconect, then try to join another, I'll often get the error, if that makes sense.
Postby Dae » Sun Jun 24, 07 8:11 am
~[A]Kaiden~ wrote:I used to get it whenever I tried to join a server.. Now I get it sometimes.. Like, if I play on a server and disconect, then try to join another, I'll often get the error, if that makes sense.
Yeah, exactly same here.
Postby ~ô¿ô~Nobody~ » Sun Jun 24, 07 3:18 pm
I got that GPF whenever I just clicked at the MP menu button to open the server list window. :roll:
Postby {17}agentsmith » Sun Jun 24, 07 6:55 pm
mine always problems with that
it usually fixes it if you install one of the older versions of that mod and then update it to the new one
it worked for me 8)
{17}agentsmith
