DXMS Server Crash Issue
Postby Jon » Fri Jun 29, 07 1:00 am
Not quite sure where I should've posted this due to the personal nature of it, but I'm having server problems; anyone know what the attached log means?
DXMS Server Log.txt
(20.3 KiB) Downloaded 185 times
Postby Professor Layton » Fri Jun 29, 07 10:35 am
I've seen this error a few times in UT, usually it was due to a faulty mod or something... I'd recommend reinstalling all mods and deleting your deusex.ini
Can't be really more specific as I never really looked much into the matter back then. Also, where's the rest of the log?
And if that doesnt work, reinstall the game, as for some it seemed to be something corrupted system files. (you could of course try copying all the system files from another deusex, if you have a second version lying around somewhere)
Postby MainMan » Fri Jun 29, 07 10:53 am
Jon if you need some un-corrupt files, you can copy them from my directory on the dxms server. (You can shut down the MMCity server)
Postby Jon » Fri Jun 29, 07 11:28 am
Clix wrote:Also, where's the rest of the log?
It was so abrupt that I had a log of Mastakilla saying something right before that fat lump of code, then nothing - as you can see, it even cut out in mid log!
