My fps is low
My fps is low
Postby Imperial » Mon Aug 13, 07 4:22 pm
Usually 75 but at 31 now, any reasons?
Postby Gishank » Mon Aug 13, 07 4:43 pm
Odd, Might be drivers, or your graphics card is old. I used to get 120 FPS, but then my other graphics card died, and i only got 5 FPS on DX =/
Postby Allan » Mon Aug 13, 07 4:43 pm
High poly weapons in use? (anything made by Derek)
Big levels?
Jay?
Postby Imperial » Mon Aug 13, 07 4:53 pm
:idea:
JAY!
Nah, cmd, all orginal maps, shouldn't get low fps and maybe something to do with drivers, purrrrhaps
Postby Dae » Mon Aug 13, 07 5:14 pm
-[JTB]-Imperial wrote:Usually 75 but at 31 now, any reasons?
may vary from scene on old (or laptop) video cards
Postby Imperial » Mon Aug 13, 07 5:20 pm
I think I solved it, installed wrong video card :S
Postby Imperial » Mon Aug 13, 07 5:53 pm
Nope.. not working still :x
Postby System » Mon Aug 13, 07 6:24 pm
Drivers for video + Drivers for mobo
System
Postby Imperial » Mon Aug 13, 07 6:31 pm
Mobo?
Hobo, bobo, what is Mobo :?
Postby System » Mon Aug 13, 07 7:42 pm
Motherboard. Sorry if I wasn't clear.
System
Postby Imperial » Mon Aug 13, 07 7:44 pm
no worries dear
Ye I might try it for motherboard, although I didn't have to before :?
Postby Kaiden » Tue Aug 14, 07 12:36 am
Install OpenGL and see how that does:
Guide
Postby [FGS]ShadowRunner » Fri Aug 17, 07 7:28 am
In my DeusEx.ini changing "NumAASamples=0" to "NumAASamples=4" increased my FPS from less than 30 to more than 40. (using an 8yr old card, temporarily), thanks to Kaiden's KB.
[FGS]ShadowRunner
Postby clyzm » Fri Aug 17, 07 7:31 am
Funny, I had 255 FPS in fights with my old card but when I put NumAntialiasingSamples to 4, it went down to 125. :S
Postby Karkian » Fri Aug 17, 07 9:01 am
255?! CRAP! I fixed my FPS ingame, and it's only maximum is 40! :shock:
Karkian
Postby ~ô¿ô~Nobody~ » Fri Aug 17, 07 12:10 pm
Omg, I ot an FPS problem too.. it's too much, so my client wants to move faster on a server and the server keeps pushing me back.. rly annoying :x
Postby Professor Layton » Fri Aug 17, 07 12:44 pm
ShadowRunner wrote:In my DeusEx.ini changing "NumAASamples=0" to "NumAASamples=4" increased my FPS from less than 30 to more than 40. (using an 8yr old card, temporarily), thanks to Kaiden's KB.
You sure you didn't change anything else? Antialiasing (AA) Increases quality at the cost of performance, it's impossible that increasing the AA samples it would increase your fps, unless there's a severe bug in the renderer. =\
As for Nobody, do you have a dual core processor or something like that?
Postby ~ô¿ô~Nobody~ » Fri Aug 17, 07 12:51 pm
Yeh
Intel Core E6600
Odd is, that it's quite normal in fullscreen mode, but there I have a delay at rotation when moving the mouse.
That's why I prefer windowed mode, but there it's that fast. (at least there is no delay between mouse move and rotation)
Postby Professor Layton » Fri Aug 17, 07 12:54 pm
I might be able to solve your problem then, DX fucks up for some with dual core and alike, come on msn for a possible fix :P
Postby Dae » Fri Aug 17, 07 2:46 pm
If you're using DX on dual core, try setting up Window 98 compatibility mode or something like that in options of .exe. It's a new solution which we found on our Russian forum.
Postby ~ô¿ô~Nobody~ » Fri Aug 17, 07 2:56 pm
Unfortunately, Clix solution did not work.
But as I said.. it's not fast in general.. just if I play in windowed mode. :?
Postby Professor Layton » Fri Aug 17, 07 3:07 pm
Dae just means you try to use compatability mode, it's completely different than my thing :P My fix just makes the game always run one one core, which voids any affinity problems, but yeah, in your case it wasn't that, so you could try dae's compatibility mode's thing.
Postby Kaiden » Fri Aug 17, 07 5:26 pm
Duel core is usualy to small cores combined usually, DX would probably run badly on just one? :shock:
Postby ~ô¿ô~Nobody~ » Fri Aug 17, 07 6:05 pm
Don't worry. In case of my Core E6600, already one core is 4 times faster than a common Pentium4 with 2.4GHz
