My Server
My Server
Postby Bear » Sat Sep 01, 07 9:09 pm
it will not connect i know why cus of the ports, its too difficult for me cus im not on my main computer , where the adaptor connects to. Id like it if someone made say a patch or a mod to automaticly forward all ports for DX, can any1 help?
Bear
Postby Dae » Sat Sep 01, 07 10:01 pm
What kind of adapter?
Postby Karkian » Sun Sep 02, 07 2:18 am
What do you mean it wont connect? You sayin it wont show or what :?
Karkian
Postby Bear » Sun Sep 02, 07 9:04 am
well its a NETGEAR DG834GT i am hoping either of you can perhaps make a mod or a patch as it would help alot of ppl beacause they have the same problam , if they didnt there would be over 30 servers.
Bear
Postby Alex » Sun Sep 02, 07 10:09 am
Postby Dae » Sun Sep 02, 07 10:09 am
{17}HeY wrote:well its a NETGEAR DG834GT
try this.
Since it's Wifi, I can tell you apriori that the pings won't be the best, if not bad.
The patch you're talking about is technically impossible as there are many models of routers. Maybe I don't know something, but at least I haven't ever seen such patch.
Postby Alex » Sun Sep 02, 07 10:10 am
Haha, Dae, you're too late :P
Postby Dae » Sun Sep 02, 07 10:13 am
goddamn again :cry:
Postby Bear » Sun Sep 02, 07 5:04 pm
i cant log into it is tehre a hack i could do?
Bear
Postby Dae » Sun Sep 02, 07 5:14 pm
If 'admin' as login and 'password' as password don't work, you may try to reset the router but you'll have to reconfigure it again :? The best would be to find the working login and password.
Postby Bear » Sun Sep 02, 07 5:19 pm
ok
Bear
Postby Alex » Sun Sep 02, 07 5:38 pm
If what Dae suggested doesn't work, try "admin" as login, and "1234" as password.
Postby Bear » Sun Sep 02, 07 6:06 pm
Is it inbound or outbound i have no idea i have just doen inbound
Bear
Postby Bear » Sun Sep 02, 07 6:42 pm
i am also unsure if it is UDP or TCP i have done a thing called UCP/TCP
Bear
Postby Kaiden » Sun Sep 02, 07 6:59 pm
Yeah, you need both. =D (I believe) So UDP + TCP is good. (I think that's what they're called)
Ports Guide:
http://www.dxalpha.co.uk/kb/hosting/opening-ports
Postby Dae » Sun Sep 02, 07 7:33 pm
{17}HeY wrote:i am also unsure if it is UDP or TCP i have done a thing called UCP/TCP
Do you follow this tutorial?
Postby Bear » Sun Sep 02, 07 7:41 pm
iv now changed it to UDP only for 27000 and seprete UDP and TCP ports but i still cant see my svere in the internet game only in lan , any idea? what to do?
Bear
Postby Kaiden » Sun Sep 02, 07 8:21 pm
Yes, it will appear in the LAN list. But to others it may still be in the Internet list.
Postby Aidan » Sun Sep 02, 07 11:17 pm
Make sure you have internet first..
Postby Bear » Mon Sep 03, 07 8:59 am
well im puting TCP and UDP on all ports , if it works thanks , if it dont i may need more help...
Bear
Postby Bear » Mon Sep 03, 07 9:05 am
i have just done it , on the port opening tutorial it says to start port 7770 and end port 7792 is this right?
Bear
Postby Dae » Mon Sep 03, 07 9:31 am
{17}HeY wrote:start port 7770 and end port 7792 is this right?
right
Postby Bear » Mon Sep 03, 07 10:03 am
good
Bear
Postby Bear » Mon Sep 03, 07 10:05 am
the server is called Proffesionals Only No Noobs dats what its called its on all the time i am on DX pelase tell me if u can see it.
Bear
Postby Bear » Mon Sep 03, 07 10:08 am
i tried to join it just shutdown any idea what to do heres the server. in systam folder.
Nephthys.Nephthys,DXMapVote100.MVMutator,mPack1.DXWeaponSelector
DXMTL: Add mutator DXMapVote100.MVMutator
MVMutator: 43 Maps, 538 Bytes
DXMTL: Add mutator mPack1.DXWeaponSelector
ScriptLog: UdpServerQuery: Port 7791 successfully bound.
Log: Resolving master0.gamespy.com...
Log: Resolving master.epicgames.com...
Log: Resolving master.fragaholic.com...
Log: Loading: Package DeusExConText
Log: MedicalBot2 fell out of the world!
ScriptWarning: MTLTeam DXMS_Intimidation.MTLTeam0 (Function DeusEx.DeusExMPGame.Killed:0112) Accessed None
Log: Resolved master0.gamespy.com (207.38.11.34)
ScriptLog: UdpServerUplink: Master Server is master0.gamespy.com:27900
ScriptLog: UdpServerUplink: Port 7792 successfully bound.
Log: AInternetLink Resolve failed: Can't find host master.epicgames.com (WSANO_DATA)
ScriptLog: UdpServerUplink: Failed to resolve master server address, aborting.
Log: AInternetLink Resolve failed: Can't find host master.fragaholic.com (WSANO_DATA)
ScriptWarning: Karkian DXMS_Intimidation.Karkian0 (Function DeusEx.ScriptedPawn.LoopAnimPivot:0045) LoopAnim: Sequence 'Swim' not found in Mesh 'Karkian'
ScriptWarning: Karkian DXMS_Intimidation.Karkian2 (Function DeusEx.ScriptedPawn.LoopAnimPivot:0045) LoopAnim: Sequence 'Swim' not found in Mesh 'Karkian'
ScriptWarning: Karkian DXMS_Intimidation.Karkian1 (Function DeusEx.ScriptedPawn.LoopAnimPivot:0045) LoopAnim: Sequence 'Swim' not found in Mesh 'Karkian'
ScriptLog: ProcessServerTravel: DXMP_Smuggler
Log: Server switch level: DXMP_Smuggler
Log: Browse: DXMP_Smuggler?Name=~{17}Hëý~?Class=MMUserInterface160.MMUIPlayer?Team=0?Game=DXMTL152b1.MTLTeam?Mutator=Nephthys.Nephthys,DXMapVote100.MVMutator,mPack1.DXWeaponSelector?-server?log=server.log
Log: Doing load, not loadgame
Log: Current mission number is 7, next is -1
Log: Unloading: Package DXMS_Intimidation
Log: LoadMap: DXMP_Smuggler?Name=~{17}Hëý~?Class=MMUserInterface160.MMUIPlayer?Team=0?Game=DXMTL152b1.MTLTeam?Mutator=Nephthys.Nephthys,DXMapVote100.MVMutator,mPack1.DXWeaponSelector?-server?log=server.log
Log: Loading: Package DXMP_Smuggler
Log: Loading: Package NewYorkCity
Log: Loading: Package CoreTexWood
Log: Loading: Package Dockyard
Log: Loading: Package CoreTexBrick
Log: Loading: Package Paris
Log: Loading: Package Cmd_tunnels
Log: Loading: Package V_Com_Center
Log: Loading: Package CoreTexConcrete
Log: Loading: Package NYCStreets_Music
Exit: WinSock shut down
Log: Collecting garbage
Log: Purging garbage
Log: Unloading: Package CoreTexFoliage
Log: Unloading: Package CoreTexStone
Log: Unloading: Package BobPage
Log: Unloading: Package Constructor
Log: Unloading: Package UNATCO
Log: Unloading: Package DeusExConText
Log: Unloading: Package DXMTL152b1
Log: Garbage: objects: 49962->34278; refs: 426606
Log: Loading: Package DXMTL152b1
Log: Game class is 'MTLTeam'
Init: WinSock: Socket queue 131072 / 131072
DevNet: TcpNetDriver on port 7790
Log: Spawning: IpDrv.UdpBeacon
Log: Spawning: IpServer.UdpServerQuery
Log: Spawning: IpServer.UdpServerUplink
Log: Bringing Level DXMP_Smuggler.MyLevel up for play (20)...
DXMTL: InitGame: ?Name=~{17}Hëý~?Class=MMUserInterface160.MMUIPlayer?Team=0?Game=DXMTL152b1.MTLTeam?Mutator=Nephthys.Nephthys,DXMapVote100.MVMutator,mPack1.DXWeaponSelector?-server?log=server.log
DXMTL: Base Mutator: DXMP_Smuggler.CBPMutator0
DXMTL:
DXMTL: Starting anti-cheat mutator...
DXMTL: Allow CenterView: True
DXMTL: Continuous CenterView: False
DXMTL: CenterView Delay: 2.500000
DXMTL:
DXMTL: DeusExLevelInfo Repaired!
DXMTL: Mutators Nephthys.Nephthys,DXMapVote100.MVMutator,mPack1.DXWeaponSelector
DevNet: NotifyAcceptingConnection: Server MyLevel accept
NetComeGo: Open MyLevel 09/03/07 10:06:22 192.168.0.136:1918
DevNet: NotifyAcceptingChannel Control 0 server Level DXMP_Smuggler.MyLevel: Accepted
DevNet: Level server received: HELLO REVISION=0 MINVER=1100 VER=1100
DevNet: Level server received: NETSPEED 20000
Log: Client netspeed is 20000
DevNet: Level server received: LOGIN RESPONSE=-767472405 URL=Index.dx?Name=~{17}Hëý~?Class=MMUserInterface160.MMUIPlayer?Team=1?lan?Checksum=NoChecksum
DevNet: Login request: Index.dx?Name=~{17}Hëý~?Class=MMUserInterface160.MMUIPlayer?Team=1?lan?Checksum=NoChecksum
Log: UDP recvfrom error: 10054
Log: Bound to WinDrv.dll
NetComeGo: Open MyLevel 09/03/07 10:07:02 192.168.0.136:1920
DevNet: Level server received: LOGIN RESPONSE=-1397733264 URL=Index.dx?Name=~{17}Hëý~?Class=MMUserInterface160.MMUIPlayer?Team=1?lan?Checksum=NoChecksum
DevNet: Level server received: JOIN
DevNet: Join request: Index.dx?Name=~{17}Hëý~?Class=MMUserInterface160.MMUIPlayer?Team=1?lan?Checksum=NoChecksum
Warning: Failed to load 'MMUserInterface160': Package 'MMUserInterface160' is not accessible in this sandbox
Warning: Failed to load 'Class MMUserInterface160.MMUIPlayer': Package 'MMUserInterface160' is not accessible in this sandbox
Warning: Package 'MMUserInterface160' is not accessible in this sandbox
Warning: Failed to load 'Class DeusEx.NSFterrorist': Failed to find object 'Class DeusEx.NSFterrorist'
Warning: Failed to find object 'Class DeusEx.NSFterrorist'
Critical: appError called:
Critical: Failed to load player class
Critical: ULevel::SpawnPlayActor
Critical: ULevel::NotifyReceivedText
Critical: UControlChannel::ReceivedBunch
Critical: UChannel::ReceivedSequencedBunch
Critical: Direct
Critical: UChannel::ReceivedRawBunch
Critical: DispatchDataToChannel
Critical: BunchData
Critical: UNetConnection::ReceivedPacket
Critical: UNetConnection::ReceivedRawPacket
Critical: UTcpNetDriver::TickDispatch
Critical: UpdatePreNet
Critical: ULevel::Tick
Critical: (NetMode=1)
Critical: TickLevel
Critical: UGameEngine::Tick
Critical: XGameEngineExt::Tick
Critical: UpdateWorld
Critical: MainLoop
Exit: Exiting.
Uninitialized: Log file closed, 09/03/07 10:07:03
Bear
Postby Alex » Mon Sep 03, 07 10:30 am
Can you please attach your DeusEx.ini (not POST, ATTACH!) (So press on Post Reply, and then attach it ;)), make sure you remove your admin password, seeing there are some lamers on this forum that will try to abuse it.
Postby Bear » Mon Sep 03, 07 10:37 am
ok here it is
DeusEx.ini
(12.27 KiB) Downloaded 317 times
Bear
Postby Alex » Mon Sep 03, 07 10:40 am
Ok, try using this DeusEx.ini:
DeusEx.ini
(12.27 KiB) Downloaded 325 times
Postby Bear » Mon Sep 03, 07 10:54 am
thanks alex ill PM u n dae the login teh new one.
Bear
Postby Alex » Mon Sep 03, 07 10:57 am
The login? No need to send me the adminpassword! It's your server :) We help people because we want to, we don't want to be rewarded :)
Even though, cash is always welcome...hehe.
