Turns out I've finally found an error report containing what happened with a crash. Seems to be ATI, look at this:
This page contains the following errors:
error on line 121 at column 1: Extra content at the end of the document
Below is a rendering of the page up to the first error.
Microsoft Windows XP Professional 5.1.2600 2.0 1033 ACPI Fixed Feature Button ACPI\FixedButton Intel Processor ACPI\GenuineIntel_-_x86_Family_15_Model_0 intelppm intelppm.sys Programmable interrupt controller ACPI\PNP0000 System timer ACPI\PNP0100 Direct memory access controller ACPI\PNP0200 Standard 101/102-Key or Microsoft Natural PS/2 Keyboard ACPI\PNP0303 i8042prt i8042prt.sys Printer Port ACPI\PNP0400 Parport parport.sys Communications Port ACPI\PNP0501 Serial serial.sys Communications Port ACPI\PNP0501 Serial serial.sys Standard floppy disk controller ACPI\PNP0700 fdc fdc.sys System speaker ACPI\PNP0800 PCI bus ACPI\PNP0A03 pci pci.sys Extended IO Bus ACPI\PNP0A06 System CMOS/real time clock ACPI\PNP0B00 System board ACPI\PNP0C01 Motherboard resources ACPI\PNP0C02 Numeric data processor ACPI\PNP0C04 ACPI Power Button ACPI\PNP0C0C ACPI Sleep Button ACPI\PNP0C0E PS/2 Compatible Mouse ACPI\PNP0F13 i8042prt i8042prt.sys SCSI/RAID Host Controller ACPI\PNPA000 ajg8i0hn Microsoft ACPI-Compliant System ACPI_HAL\PNP0C08 ACPI ACPI.sys ATI WDM Specialized MVD Codec DISPLAY\NTativmd40 MVDCODEC atinmdxx.sys
