Mega lag on my server
Postby Bear » Sun Oct 21, 07 8:34 pm
People are saying mega lag , from no-one downloading , is there somthn roung with my ini /TCp net driver , or is there a mod that can fix this?
DeusEx.ini
(15.47 KiB) Downloaded 484 times
Bear
Postby Professor Layton » Sun Oct 21, 07 9:07 pm
What kind of connection and computer do you have?
Postby Bear » Sun Oct 21, 07 9:23 pm
Heres my PC details
1.24 GHZ , wirless connection NETGEAR , graphics card NVIDA 5200 Fx , uses NORTON 360 , 108 Mps wirless connection (already said) , old processor , unkown make of PC , is that all you need to know? 100% bandwidth to this server , no other programs running.
Bear
Postby [FTF]Freedom » Sun Oct 21, 07 10:00 pm
I very much doubt your netspeed is 108mbps!!
Jesus how much that must cost...
I think your pblem is your wireless. Get the latest drivers.
[FTF]Freedom
Postby Bear » Mon Oct 22, 07 7:43 am
Mps it the wirless speed not the BT connection speed im sorry , i would love to have 100 megs , but no.
Bear
Postby [FTF]Freedom » Mon Oct 22, 07 11:12 am
So would I! Lol.
Put it this way, my wireless USB adaptor connects to my router at 54Mbps, and my router's modem connects out to TalkTalk at 8123kbps (round 8meg).
I''ve taken a look over ur dx.ini, but I've saved it somewhere and can't fkn find it.
I'll post it in a minute or 2.
[FTF]Freedom
Postby [FTF]Freedom » Mon Oct 22, 07 11:19 am
Right.
I couldn't change anything without knowing ur bandwidth, so I'll tell ya how to do it.
Okay - a few recommendations:
1. Get your upload bandwidth from your isp or router config page or something (mine is 446kbps, which is kinda crappish).
2. GEt ur upload bandwidth in bytes per second (use google: "xxxkbps to bytes per second" without quotes)
3. Divide ur upload bandwidth by the no of players ya want. I see urs is set to 16, so let's say u have 500kbps u/l. You have 64000 bytes per second, 64000/16=4000.
4. Your answer from part 3 goes into DeusEx.ini in the "MaxClientRate=" value under the IP bit.
A MCR over 5000 is considered okish. 2600 is 56k, 5000 is ISDN. If your MCR ends up being lower than about 5000 i would recommend lowering your player number.
Hope that helped.
PS: Change the game engine cache from 4 megs to 12 megs or 8 megs that helped me a bit. Never know, it mite work.
[FTF]Freedom
Postby Bear » Mon Oct 22, 07 1:47 pm
Myn is a ADSL router , I use DSL as connection type in DX ,
Bear
Postby Professor Layton » Mon Oct 22, 07 1:57 pm
1.24GHz is quite low, I honestly don't expect it to run a server properly, if it has more than 3 players.
Postby Gishank » Mon Oct 22, 07 2:10 pm
It still should run a server with upto 16 players. As, DeusEx only requires a Pentium 3, 300MHz to run.
If you see my point.
Postby [FTF]Freedom » Mon Oct 22, 07 2:36 pm
True, but DXMP players hosting dedicated and playing on the same machine will need a fairly large amount of RAM and a couple of Xeon's do work properly!
But then again my Pentium3 450MHz 128Mb RAM system runs okay with 4 players. Ish.
[FTF]Freedom
Postby Professor Layton » Mon Oct 22, 07 2:39 pm
Are you sure it runs good for the rest too? :P
Postby [FTF]Freedom » Mon Oct 22, 07 2:41 pm
Never said that did I!?!? :p
It's sorta ok. Ping of around 90-120 for UK players.
...and bout 900 during fights.
Heh.
[FTF]Freedom
Postby Bear » Mon Oct 22, 07 7:28 pm
Ok driver updated , the shit is , now i cant see it in the internet list only in LAN , which is anyoying for me , atleast peeps still see it.
Bear
Postby bambi » Tue Oct 23, 07 3:16 am
wait a sec. what does the cpu have to do with it, I think his settings are not right, or his upload bandwith is too low. Do cntrl alt delete, and look, I doubt a server running dx with a pentium III will even utilize 35% of cpu.
bambi
Postby Kaiden » Tue Oct 23, 07 6:16 am
How much RAM do you have to start off?
My old computer downstairs which I used to host on would handle up to about 8 players, but I couldn't join the server without it lagging out or browse the internet, unless I hosted Non-Dedicated, which meant I had to play the game.
P.C is 2.0GHZ.
Postby Bear » Tue Oct 23, 07 8:10 am
CPU when no-one is in the game is 04 , I set it to realtime , should I set my WPN111 wirless adaptor priority to realtime too? it uses 0 CPU> but the server takes up 43,340 K , I have 1 GB of RAM. My Wirless bridges firmware is updated , My router DG834GT and the acess point WPN802 , both firm wares upgrade , would the lag be people from outside of the UK?
Bear
Postby Professor Layton » Tue Oct 23, 07 2:17 pm
bambi wrote:wait a sec. what does the cpu have to do with it, I think his settings are not right, or his upload bandwith is too low. Do cntrl alt delete, and look, I doubt a server running dx with a pentium III will even utilize 35% of cpu.
Well honestly, I don't know how DX deals exactly with the processor, but fact remains that a server runs significantly smoother on 3 GHz than on 1.25 GHz. Besides, I think {17}HeY plays on his own server too, with the same comp.
Anyways {17}HeY, are you sure your processor is that bad, or that you have that amount of ram? Because your amount of ram is really much compared to that processor.
Last edited by Professor Layton on Tue Oct 23, 07 2:27 pm, edited 4 times in total.
Postby [FTF]Freedom » Tue Oct 23, 07 2:30 pm
NOn-Ded + me playing = awful for everyone else.
Ded + me NOT playing = not too bad for everyone else.
Gah. I think my PC is trying to tell me something!!
CPU, RAM and U/L Bandwidth will affect it the most. NO good have a 20megs upload or something if ya running it on a 90Mhz pentium laptop is it.
[FTF]Freedom
