OpenGL
OpenGL
Postby Bear » Tue Oct 23, 07 10:23 am
I installed OpenGL rendera in my deus ex/system folder , following the artical on it , it has the music but I cant see anything on it , only a black screen.
DeusEx.ini
(15.77 KiB) Downloaded 322 times
DeusEx.log
(62.34 KiB) Downloaded 320 times
OpenGlDrv.ini
(1.13 KiB) Downloaded 288 times
Bear
Postby Dae » Tue Oct 23, 07 12:36 pm
Did you install a Deus Ex render, or Unreal one?
Postby [FTF]Freedom » Tue Oct 23, 07 12:53 pm
It's <a href="http://cwdohnal.home.mindspring.com/utglr/dxglr18.zip">THIS ONE</a> ya want.
[FTF]Freedom
Postby [FTF]Freedom » Tue Oct 23, 07 12:54 pm
Your dx.ini says that Glide is set as ur rendering device.... That could be why!
[FTF]Freedom
Postby Bear » Tue Oct 23, 07 2:49 pm
Nope does not work Freedom , I just downloaded of Freedom , the one that he posted , I have no idea if its unreal or Dx rendera. My graphics card is NIVIDA 5200 , could that be the prob?
Bear
Postby [FTF]Freedom » Tue Oct 23, 07 2:57 pm
That definitely is the DX renderer. Here's the page it's from:
Copy the files into ur dx/system folder, start the game in safe mode and change the driver to "OpenGL" (you imte have to clikc "show all devices").
Then post back here. If it doesn't work I'll have another think.
PS: Your card is fine, mine is even older.
[FTF]Freedom
Postby Bear » Tue Oct 23, 07 4:10 pm
The old one dont work too lol.
Bear
Postby Professor Layton » Tue Oct 23, 07 4:19 pm
Let's see, OpenGL has a known error that the brightness is way too low on some computers. Try the following: start DX, then when it's gone to fullscreenmode:
press your talk button (default = t)
Hold down backspace for a while
then type in: brightness
and press enter
Do that a couple of times and see if you can see anything on the screen meanwhile.
D
Postby Bear » Tue Oct 23, 07 5:33 pm
Mmm here , I dont know what is roung lol.
DeusEx.ini
(19.04 KiB) Downloaded 356 times
DeusEx.log
(66.39 KiB) Downloaded 302 times
OpenGlDrv.ini
(1.13 KiB) Downloaded 308 times
Bear
Postby [FTF]Freedom » Wed Oct 24, 07 11:36 am
Umm... Beats me... haven't had time to look at your files yet tho.
Got the latest Nvidia ForceWare drivers??
[FTF]Freedom
Postby Dae » Wed Oct 24, 07 2:43 pm
Use OpenGL instead of D3D which is 'beta'
Postby [FTF]Freedom » Wed Oct 24, 07 4:11 pm
Check again, Dae, only some of the OpenGL versions are betas.
I think most players will tell ya that OpenGL gives better performance than D3D. Besides, I don't know of anybody who has had problems with the OpenGL renderers on Nvidia cards.
To hey: You could try the beta OpenGL renderers, but I reckon the dxglr 1.8 renderer works fine for most ppl. The 1.6 one gave me a problem where if I was at any height (e.g. walking along the walkways in Silo) I'd get black sections, almost as if there were giant BSP holes. But as I said, 1.8 really should work fine on your 5200 card.
[FTF]Freedom
Postby Dae » Wed Oct 24, 07 4:50 pm
[FTF]Freedom wrote:Check again, Dae, only some of the OpenGL versions are betas.
D3D isn't OpenGL :wink:
Postby Bear » Wed Oct 24, 07 5:16 pm
Well , it dosent show on "show all devices"in safe mode. So I ahve to change threw Deus Ex.Ini
Bear
Postby [FTF]Freedom » Wed Oct 24, 07 5:35 pm
if it doesn't show you haven't installed it right lol.
ake sure to delete the old opengl.dll b4 adding the one from the download. btw make sure ur copying the download to ur system folder.
[FTF]Freedom
Postby Kaiden » Wed Oct 24, 07 7:26 pm
Just follow the guide in the KB, it has worked for everyone else!
Postby [FTF]Freedom » Wed Oct 24, 07 9:42 pm
Yep. Fuck, man. I coulda just said that =(
*shoots self*
[FTF]Freedom
