My FPS
My FPS
Postby Survive. » Sun Oct 28, 07 8:54 pm
Ok, I am here to post about my miserable FPS in DEUS EX. Out of all games Deus Ex. It has only started being very bad recently. I will have 60 FPS without walking, 30 FPS walking and in middle of fights, it gets as low as 3!
Any help please, 3 is very abad :evil:
Thanks, Survive.
Survive.
Postby Kaiden » Sun Oct 28, 07 9:45 pm
Postby Survive. » Sun Oct 28, 07 10:15 pm
Thanks very much, I have had to turn all my DX graphics to the lowest :shock:
Survive.
Postby Tonnochi » Sun Oct 28, 07 10:26 pm
I had a full single player version of Counter-Strike 1.6 on my phone. FPS was 2.
Postby Survive. » Sun Oct 28, 07 10:32 pm
Lol.
Here is a very good link to see ways of boosting your system preformence:
http://registry-repair-software-review.toptenreviews.com/how-to-improve-system-performance.html
Survive.
Postby [FTF]Freedom » Mon Oct 29, 07 12:48 am
That's all common sense stuff rly.
My FPS is the same as yours, Survive. I notice it the most with user maps, with the worst and most memorable one being a map called Duality2005. Had an FPS of maximum bout 6!!
This might sound crazy but try to limit ur fps in dx.ini! Limiting it to about 60 will at least give you SOME consistency. There's nothing worse than being in a rly small, undecorated room getting 100+ FPS, then sum fucker comes and pelts you with an assault rifle... coz you'll have to deal with an FPS of like 10 or less and that's fucked up when you just had an FPS which is rly high lol.
SWcuse me I'm drunk.
But yah - wats ur PC specs?? Bet they ain't as shite as mine!!
[FTF]Freedom
Postby Survive. » Mon Oct 29, 07 1:43 am
I have limited it to 60 :oops:
I can't be bothered looking at the moment, but they probibaly are. Hopefully getting a laptop soon if I save up the money. Or maybe a new graphics card or computer... [ O'r Both ]
Survive.
Postby Kaiden » Mon Oct 29, 07 1:46 am
On laptop it's max of about 30, crappy computer downstairs 15-25, be greatful! =D
Postby Survive. » Mon Oct 29, 07 1:48 am
How, with an FPS of 3 - 40! :P . My max FPS might be bigger, but my minimum! :P
But you do get a bit of bad FPS. Is i't possible to get 1000 FPS in Deus Ex?
Survive.
Postby Kaiden » Mon Oct 29, 07 1:48 am
Lol! I doubt it, max I know is like 200 withsome people.
Postby Survive. » Mon Oct 29, 07 1:49 am
Ok thanks :oops: :lol:
Survive.
Postby Dae » Mon Oct 29, 07 8:15 am
Did you try OpenGL?
Postby [FTF]Freedom » Mon Oct 29, 07 12:44 pm
Oh aye - forgot bout that. OpenGL does indeed give better performance (altho I've heard it only rly gives better of Nvidia cards, but I'm probably mistaken).
I have an old Voodoo 3 2000 AGP card... DX was made for glide, right? Coz atm I'm using a Creative Nvidia GeForce 4 MX 420 PCI card with OpenGL... I was wondering if I'd get better performance on my 3DFX card.
BUT... then again, 3DFX cards don't have drivers for XP =(
[FTF]Freedom
Postby Kaiden » Mon Oct 29, 07 2:12 pm
Ah yeah.. Guide on installing OpenGL here:
http://www.dxalpha.co.uk/kb/improvement ... ng-devices
Postby bambi » Tue Oct 30, 07 5:44 am
deer B3S Survive,
Hint: Dont' limit your fps to 60, turn vsync or swap off...you'll fire faster...And, no the max is not 200 fps. I'm sure with the modern comps, you can get around 350. Heck I got 220 - 300
bambi
Postby Kaiden » Tue Oct 30, 07 10:33 am
Yes but I bet you have a quad-core super deluxe £2,000 processor and everything else awesome. =D
Postby [FTF]Freedom » Tue Oct 30, 07 11:24 am
I was speaking to someone in-game, I forget who, but he/she said they had a quad-core (dunno specs, just said quad core) and they were getting 220ish.
Not sure bout the vsync settings or the swap rate, but it's all explained <a href="http://www.dxalpha.co.uk/kb/improvements/deusex-ini-settings">here</a>
[FTF]Freedom
Postby Professor Layton » Tue Oct 30, 07 11:46 am
I should improve that guide one day I guess... it's not really explaining every option, yet.
Anyways: People with bad computers are better off with using VSync: more stable fps (So you get used to that fps and don't end up helpless in big fights) and less low fps drops (still existant though, obviously)
People with good computers can play without vsync, though they could limit their fps at 130 without performanceloss if they want to decrease the stress on the graphics card (Most monitors support an update rate of 85, having fps way higher than that doesn't help you in any way.) Reason for not capping it at 85 (DesktopRefreshRate): The rendering won't always be at 85 fps, sometimes it'll be a bit above that amount, sometimes a bit below it: having it at 130 should ensure you of having it above 85 at all times (given your comp can handle that).
Postby [FTF]Freedom » Tue Oct 30, 07 12:17 pm
It'd be nice to see all the options explained. It's starting to bug me what they do lol.
I actually emailed the dude who makes the updated OpenGL renderers for DX, asking him about the options... but no reply yet :(
To use VSync do I set it to default (-1) or on (1)?
[FTF]Freedom
Postby Professor Layton » Tue Oct 30, 07 12:27 pm
There's a lot of options he simply put there and you're not allowed to touch :P
"SwapInterval=-1 // Controls V Sync. If set to the default value of -1, the default buffer swapping method is used. Set to 0 to disable V Sync. Set to 1 to enable V Sync."
Simple answer: 1 (If that doesn't work your graphical driver's settings probably override the game settings, I could try helping you out with that, in that case.)
Postby bambi » Tue Oct 30, 07 6:00 pm
LOL CLIX DONT' DO IT!!! ONLY LEETERS K!? um, btw, no my comp is a POS, but I have the graphics on the absolute lowest
bambi
Postby Professor Layton » Tue Oct 30, 07 6:13 pm
You shouldn't even complain if some here still have a comp which struggles to give 10 fps in some situations :P
Postby Survive. » Tue Oct 30, 07 7:42 pm
Yey I downloaded the open driver or whatever you call it for Deus Ex, installed it. And now I get 40 - 60 FPS. But crap graphics :(
Thanks all who helped me.
Survive.
Postby [FTF]Freedom » Wed Oct 31, 07 10:58 am
Try upping the main gfx settings one by one, till it looks at least acceptable.
I should start a "please pity my computer" thread with some lovely screenshots of my game!!
Btw, what sorta performance boost would I get from setting "NoFiltering" to true?? Coz it's currently set to true, as I get sharper gfx, coz my LODBias is so high, everything is blurred at a distance, but with filtering off it's all sharp.
Tell ya what though, I played a map called DXMP_Medievil today, and set all gfx to highest, and detailmax to 2... WOW.
[FTF]Freedom
