DX Vista slomo problem (need help)
Postby {DXC} Smiffy » Tue Nov 13, 07 12:19 am
Hey guys, I've finnaly been bothered to post this to see if there is anyway to fix this problem anyways this is what usually happens.
The start up menu goes slower and when i go in game it goes extremaly slow i was woundering if this was happening because of my amd dual core so if there is anyway to fix this i would thankfull if you could post your ideas. Thanks.
{DXC} Smiffy
Postby Tonnochi » Tue Nov 13, 07 4:21 am
This is interesting. Slow on Vista, fast on Mac.
Postby Dae » Tue Nov 13, 07 12:06 pm
[FGS]Zeitgeist wrote:Slow on Vista, fast on Mac.
The problem is in game, not OS :wink:
{DXC} Smiffy wrote:The start up menu goes slower and when i go in game it goes extremaly slow i was woundering if this was happening because of my amd dual core so if there is anyway to fix this i would thankfull if you could post your ideas. Thanks.
try running the game in Windows 98 compatibility mode. In order to do that, find DeusEx.exe in DeusEx/System folder, right click on it, go to properties and in one of the tabs find compatibility options.
Postby {DXC} Smiffy » Tue Nov 13, 07 9:34 pm
Nope, I've still got the slomo problem thanks for the idea tho anyone else know any ideas?
{DXC} Smiffy
aa
Postby ~DJ~ » Wed Nov 14, 07 8:38 am
blah ..arnt u were in ^i?
well
anyways go to game ( first Enabled Cheats)
then type without say slomo 9
then slomo 0
then slomo 1
and walah! its fixed :D
Postby Kaiden » Wed Nov 14, 07 10:12 am
He enables cheats how on a server? :wink:
And no, that's just someone taking his name most likely.
Postby Jon » Wed Nov 14, 07 11:42 am
http://www.amd.com/us-en/assets/content_type/utilities/Setup.exe
Specifically for Dual Core AMD processors.
Postby Dae » Wed Nov 14, 07 6:42 pm
{DXC} Smiffy wrote:Nope, I've still got the slomo problem thanks for the idea tho anyone else know any ideas?
try this: launch Deus Ex, in-game press Ctrl + Alt + Del, switch to "processes tab", then find "DeusEx.exe", right click on it -> in the context menu select the bottom menu item -> leave only one tick (either CPU 0, or CPU 1, not both)
then check if your Deus Ex runs any better
Postby Kaiden » Wed Nov 14, 07 7:35 pm
Cool, I'll try that and see if it helps mine! =D
Postby Jon » Thu Nov 15, 07 1:00 am
The optimiser does all that without having to reset it every time you run it.
Postby Professor Layton » Fri Nov 16, 07 9:49 am
Another way would be modifying the .exe with imagecfg, so it automatically boots DX with affinity to one processor. (Also works for intel CPU's, I'll post it up if required)
Postby {DXC} Smiffy » Fri Nov 16, 07 11:04 pm
still got the slomo problem =[ any other ideas anyone?
[DX-ST]DJ wrote:blah ..arnt u were in ^i?
No, there's another smiffy on dx now so im chainging my name
{DXC} Smiffy
Postby Dae » Sat Nov 17, 07 9:38 am
{DXC} Smiffy wrote:still got the slomo problem =[ any other ideas anyone?
read my or Jon's replies above
if you do not understand something, please ask
Postby Baleout » Sat Nov 17, 07 2:35 pm
It's not just another person who happens to be called Smiffy, he has deliberately stolen your names; He sometimes goes by "Cheesemeister" as well.
Users browsing this forum: Google [Bot] and 1 guest
