Need help again :@
Need help again :@
Postby GuardianDevil » Tue Dec 18, 07 1:26 pm
Got dx to work n stuff.
When I try to connect to a server I get this:
ScriptLog: Received text \gamename\deusex\gamever\1100\minnetver\1100\location\0\hostname\§§§§§§§§~ [A] Inspired 2.0 feat. DXSG // dxalpha.com\hostport\7780\maptitle\Untitled\mapname\DXSG_Area51Bunker_V3_152\gametype\MTLTeam\numplayers\0\maxplayers\16\gamemode\openplaying\gamever\1100\minnetver\1100\password\False\SkillsAvail\0\SkillsPerKill\0\InitialAugs\3\AugsPerKill\2\KillsToWin\50\mutators\MMExplosive100\listenserver\False\password\False\AdminName\see thread on [A] forum\AdminEMail\support@dxalpha.co.uk\queryid\80.1\final\
Log: Assigning Last Button Window to MenuUIListWindow DX.MMUIPlayer0.DeusExRootWindow0.MMUIMenuScreenJoinInternet0.MenuUIClientWindow2.MenuUIScrollAreaWindow0.ClipWindow3.MenuUIListWindow0
ScriptLog: Received text \gamename\deusex\gamever\1100\minnetver\1100\location\0\hostname\§§§§§§§§~ [A] Inspired 2.0 feat. DXSG // dxalpha.com\hostport\7780\maptitle\Untitled\mapname\DXSG_Area51Bunker_V3_152\gametype\MTLTeam\numplayers\0\maxplayers\16\gamemode\openplaying\gamever\1100\minnetver\1100\password\False\SkillsAvail\0\SkillsPerKill\0\InitialAugs\3\AugsPerKill\2\KillsToWin\50\mutators\MMExplosive100\listenserver\False\password\False\AdminName\see thread on [A] forum\AdminEMail\support@dxalpha.co.uk\queryid\81.1\final\
Log: Tried to remove lastbuttonwindow descendant. MenuUIListWindow DX.MMUIPlayer0.DeusExRootWindow0.MMUIMenuScreenJoinInternet0.MenuUIClientWindow2.MenuUIScrollAreaWindow0.ClipWindow3.MenuUIListWindow0
Log: Browse: 85.249.166.196:7780/Index.dx?Name=lame.?Class=MMUserInterface140.MMUIPlayer?Team=128
Init: WinSock: Socket queue 32768 / 32768
DevNet: Game client on port 0, rate 20000
DevNet: Connection timed out after 0.000000 seconds (0.003116)
Log: Pending connect to '85.249.166.196:7780/Index.dx?Name=lame.?Class=MMUserInterface140.MMUIPlayer?Team=128' failed; Connection failed
NetComeGo: Close TcpipConnection0 12/18/07 12:22:16
Exit: WinSock shut down
How do I fix :@
GuardianDevil
Postby Kaiden » Tue Dec 18, 07 2:22 pm
Eeh first Update your MMUserInterface to the lastest version! It fixes all the connection errors, refresh errors, etc, find it in the Labs.
Postby GuardianDevil » Tue Dec 18, 07 4:38 pm
ty but it still doesnt work :@
ScriptLog: Received text \gamename\deusex\gamever\1100\minnetver\1100\location\0\hostname\§§§§§§§§§[24/7] [A] Cathedral Terra ~ 'RPG'\hostport\7790\maptitle\Untitled\mapname\Lees_HongKongInfiniteParty-3\gametype\MTLDeathMatch\numplayers\4\maxplayers\12\gamemode\openplaying\gamever\1100\minnetver\1100\password\False\SkillsAvail\0\SkillsPerKill\0\InitialAugs\5\AugsPerKill\0\KillsToWin\50\listenserver\False\password\False\player_0\[FGS]Majestic\frags_0\0\ping_0\ 102\team_0\0\skin_0\None\mesh_0\MTLMJ12\queryid\78.1
Log: Tried to remove lastbuttonwindow descendant. MenuUIListWindow DX.MMUIPlayer0.DeusExRootWindow0.MMUIMenuScreenJoinInternet0.MenuUIClientWindow3.MenuUIScrollAreaWindow0.ClipWindow3.MenuUIListWindow0
Log: Browse: 84.244.186.129/Index.dx?Name=Testing?Class=MMUserInterface180.MMUIPlayer?Team=128#7790
DevNet: Connection timed out after 0.000000 seconds (0.034036)
Log: Pending connect to '84.244.186.129/Index.dx?Name=lame.?Class=MMUserInterface180.MMUIPlayer?Team=128#7790' failed; Connection failed
NetComeGo: Close TcpipConnection0 12/18/07 15:37:09
GuardianDevil
Postby Kaiden » Tue Dec 18, 07 5:21 pm
On that server or all?
Post your entire DeusEx.log, and post a screenshot of any errors you get.
Postby GuardianDevil » Tue Dec 18, 07 9:50 pm
Happens on all servers, as soon as I click a server to join the menu disapears and instantly shows
Connection Failed
Connection Failed "
Also! Deus Ex is newly installed, just using old user.inis and deusex.ini and all like dxmtl n stuff.
DeusEx.log
(9.1 KiB) Downloaded 327 times
GuardianDevil
Postby Zora » Tue Dec 18, 07 11:16 pm
It looks like a firewall issue to me. What do you use?
Zora
Zora
Nephthys developer
Postby Kaiden » Tue Dec 18, 07 11:38 pm
WTH is:
Init: WinSock: I am your-evf1tfj8b7 (192.168.1.64)
Postby GuardianDevil » Wed Dec 19, 07 1:14 pm
LOL
New name of pc since I formatted :p
Asked me what I wanted to call it or something and i just left it as that :S
for firewall I use! Windows Firewall (yeh i know it sux.) and the firewall on the bt home hub thingy
GuardianDevil
Postby GuardianDevil » Sat Jan 12, 08 10:52 pm
Tried to edit last post but apps i need to edit it within 180 minutes :/
Reason for me not being able to connect was something to do with that MMUserInterface thing, cos I removed everything so it was just like normal dx, and it worked installed mtl and it worked then installed mmuserinterface and it didnt :/
GuardianDevil
Postby Kaiden » Sun Jan 13, 08 12:34 am
O_o, works with everyone else? Did you alter some random settings? Which version did you install?
Postby GuardianDevil » Sun Jan 13, 08 10:44 pm
I installed the 180 one
I think it might be something to do with me copying my old dx to like formatted pc or w.e
But even though I reinstalled dx idk why it still wnt work, seems to work fine without it tho - as in I never really used it before cos it was kinda broken to begin with :/
GuardianDevil
