Password box missing for some people
Postby Tonnochi » Fri Dec 21, 07 10:34 pm
Exactly what mod or code does someone need to have a password box?
Re: Password box missing for some people
Postby Dex » Fri Dec 21, 07 10:36 pm
[FGS]Zeitgeist wrote:Exactly what mod or code does someone need to have a password box?
.... Deus Ex 1112fm......
Postby Cozmo » Fri Dec 21, 07 10:39 pm
DXMTL
Postby Dex » Fri Dec 21, 07 10:40 pm
do you need?
Postby Tonnochi » Fri Dec 21, 07 10:49 pm
Can you link me to the precise file? Cannot find it.
Postby Dex » Fri Dec 21, 07 10:52 pm
DXMTL-v152b1.zip
(85.45 KiB) Downloaded 332 times
Postby Kaiden » Sat Dec 22, 07 12:24 am
Indeed, MTL does it, but you can delete say and type in the IP with :Password: and other complicated things lol.
Postby [FTF]Freedom » Sat Dec 22, 07 12:11 pm
That's not complicated.
And also d'uh, MTL is obvious. q
[FTF]Freedom
Postby Cozmo » Sat Dec 22, 07 12:36 pm
What about the Password= field in User.ini? Is that the same variable?
Postby Dex » Sat Dec 22, 07 1:39 pm
I thought i had Password box without MTL... lol
Postby [FTF]Freedom » Sat Dec 22, 07 2:44 pm
Like Kaiden said, you can use the password variable.
Did ya know, in any server you can instantly travel to another server?
E.g: when I play in my server (which is located at ftf.servegame.com), if I type open 82.18.154.81 I will travel to my mate's server, Destiny's End. (he has a static IP - I don't, so I set up a domain with dynamic IP update)
So, let's say you had the misfortune of playing in my server, and you wanted to travel to another (I'll use my mate's as an example), which was protected with password "n00bmuncher", you would do the following:
1. Delete say. (no shit sherlock!)
2. type open 82.18.154.81:n00bmuncher (i think)
Not totally certain aboutthe password bit, tho.
[FTF]Freedom
Postby Dae » Sat Dec 22, 07 2:52 pm
~Cozmo~ wrote:What about the Password= field in User.ini? Is that the same variable?
It is the variable for hosters.
Without MTL, you can delete say and type: open serverip:serverport?password=password, e.g.
open 192.168.161.1:7790?password=mypass
Postby Dex » Sat Dec 22, 07 3:57 pm
You can make a map and host it on two servers, and add a teleporter that teleports you to the other server, right?
Postby ~ô¿ô~Nobody~ » Sat Dec 22, 07 4:10 pm
In theory that is possible.
Postby Dae » Sat Dec 22, 07 5:09 pm
~[A]Nobody~ wrote:In theory that is possible.
in practice too
Postby VodunLoas » Sat Dec 22, 07 7:36 pm
Awhile back I made a map called [GODZ]Ship_v2 or something like that, and its pitch black and as you spawn you fall into a teleporter that sends you to Rhino's Server. I renamed the server to look like Godz server. At that time too many people played on godz and didn't go anywhere else, so I tested this out. A good few did come in, but they left rhinos once they figured out where they were. lol
Postby Survive. » Sat Dec 22, 07 10:47 pm
Haha, I think that is the best mod to make a popular server. Fill a game up with servers hosted off your computer, with the same map, but different names, that takes you to the same server. :lol:
Survive.
Postby Dex » Sat Dec 22, 07 11:00 pm
It is possible, i did that on a LAN a while ago.
Postby [FTF]Freedom » Sun Dec 23, 07 12:30 am
Interesting. I actually think that's quite a novel idea. It has a fair amount of practical joke potential.
Not sure how to do it though...
Thanks for correcting me about the password variable Dae.
[FTF]Freedom
