admin servertravel doesn't work
Postby Theo » Tue May 04, 04 12:38 am
i have used this command before but now when i try to use it it goes back to the original map and everyone's names are reset to "player"
also, how do i instal mapvote100. it says in the notepad:
Install:
1. Copy DXMapVote100.u and DXMapVote100.int to the DeusEx\System folder.
2. Open DeusEx.ini and find the [DeusEx.DeusExGameEngine] section.
Add this line to the end of that section:
ServerPackages=DXMapVote100
3. Select the DXMapVote mutator from the mutator list. If you are hosting a
dedicated server, then the startup line should look like this:
<map_name>?Game=<game_type>?Mutator=DXMapVote100.MVMutator?-server?log=server.log
but.. there is also a folder called dxmapvote100 and it has a foldeer caled classes in it. where does this go?
Theo
Postby AlexDenton » Sat Jul 10, 04 12:30 am
aye aye aye!
first things first
do u hav the latest DXMP patch?
that being 1112fm??
get it
also get MTL if u dont
2 move map
simply login as admin and type
admin servertravel DXMP_Smuggler (or the name of a map)
make sure the map u wanna travel to is inculded in ur DeusEx.ini file, which is in ur system folder
AlexDenton
Postby AlexDenton » Sat Jul 10, 04 12:36 am
ok
about mapvote
do exactly what it tells u to.... ..... .....
  • move the 2 files DXMapVote100.u and DXMapVote100.int from the Zip folder into the System folder
  • open the DeusEx.ini file, which is found in the system fodler
    look for a section called [DeusEx.DeusExGameEngine]
    at the bottom of this section, copy and paste the line
  • the other thing is editing the mapvote mutator itself.... u can change it so it locates maps from ur map folder, or from ur dx.ini
AlexDenton
Re: admin servertravel doesn't work
Postby DoughBoy » Sat Jul 10, 04 1:31 am
Theo wrote:i have used this command before but now when i try to use it it goes back to the original map and everyone's names are reset to "player"
Install:
1. Copy DXMapVote100.u and DXMapVote100.int to the DeusExSystem folder.
I thought you got this working, remember when I set it up for you? :?
DoughBoy
Postby Zarger » Sat Jul 10, 04 1:36 am
This is how I use it Admin ServerTravel DXMP_Smuggler. But if that doesnt work there is another way if you have mutaters map vote then you go mutate mapvote click on the map you want and there is a button on mutate mapvote and click that and your there but if that doesnt work i don't know what to tell you. :smt102.
[A]fireball[tr]
[url=http://www.dxalpha.com/forum/viewtopic.php?t=4607[/url][A]lpha Forum Rules[/url]
~[A]Zarger~/~[A] Z a r~
Zarger
Postby trancekiller » Sat Jul 10, 04 8:40 am
i think switchlevel is same command
trancekiller
Postby Theo22 » Thu Jul 15, 04 9:43 pm
naw i stopped watching this topic after 2 months ago. now all of a sudden it is replied to.
i already have all that installed and working but thanks anyways for the help.
Theo22
Postby AlexDenton » Thu Aug 12, 04 11:33 pm
no problem son..... did i help at all?
AlexDenton
Postby Aidan » Sun Aug 13, 06 9:25 am
Lol, i have a question too, where do you get the mapvote anyways?
I had it from an e-amil from someone on my old comp, and I switched to
my new comp i got a while ago and i lost the file due to my old comp breakdowns. plz guys it would be helpfull if i could have a direct file ty :)
Postby [ß]Lost » Sun Aug 13, 06 10:07 am
PsHyCo)(K!//3R wrote:Lol, i have a question too, where do you get the mapvote anyways?
I was in ur server earlier and I had a bad ping all the time. Why do u even bother to host? :roll:
[ß]Lost
Postby Dae » Sun Aug 13, 06 10:43 am
It's not your business Sike.
http://des.deusex-online.com/MOD_dx_MapVote_100.zip
Postby Aidan » Sun Aug 13, 06 7:33 pm
I Know it seems bad at the moment, but i'm doing all this now as i'm getting a T-1 Connection for around 500kbps. Just to Clarify things :)
Postby Aidan » Sun Aug 13, 06 7:35 pm
Oh, and thanks for the mapvote too daed 8)
Postby Dae » Sun Aug 13, 06 8:02 pm
Don't doublepost and create a new topic next time.
Postby clyzm » Sun Aug 13, 06 10:38 pm
Also, a word to the wise: look at the topic dates before posting. Bringing back dead topics is very annoying.
