Server List not responding.
Postby Eçheløn » Fri Feb 08, 08 1:13 am
I have been forced to use DXSL to join servers, because
my Deus Ex is not showing servers on its server lister.
Attached is my DeusEx.ini, am i missing something ?
Note: I only want to fix this server listing problem.
"Since that is my only problem =)"
I don't want to do any other changes to my DeusEx.ini.
DeusEx.ini
My DeusEx.ini
(11.67 KiB) Downloaded 268 times
Eçheløn
Postby ~DJ~ » Fri Feb 08, 08 2:48 am
do u have a anti-virus like Mcafee etc.. disable it and then play DX. also disable firewall too. it blocks it too. maybe it should work...
EDIT: i think there is a mistake... try replacing with this DX.ini. note backup first...
DeusEx.ini
(11.97 KiB) Downloaded 271 times
Postby Dae » Fri Feb 08, 08 10:20 am
~[XPS]~Eçheløn
the multiplayer 'build' downloaded from deusexmultiplayer.com / dxmp.net is bound to another masterserver. It was dejavu's plan about "taking over" the community and splitting it into two parts.
Open your DeusEx.ini, press Ctrl + H, type in
master.dxmp.net
and to "replace with":
master0.gamespy.com
then press "replace all" and save the file.
Postby NightRaver » Fri Feb 08, 08 10:39 am
what he says... worked for me!
Raving through life!
NightRaver
Postby ~ River ~ » Fri Feb 08, 08 3:14 pm
Yep, Same. :)
<center>Image</Center>
AquaShock wrote:Stop looking at child porn klop!
~ River ~
Postby ~DJ~ » Fri Feb 08, 08 3:37 pm
Dae[A] wrote:~[XPS]~Eçheløn
master.dxmp.net
master0.gamespy.com
aw man i saw this but i dint replace it i added new lines :/
oh well problem solved so lets Lock Topic :D?
