Deus Ex crashes with the newest OpenGL renderer
Postby Dex » Mon Jul 28, 08 8:57 pm
I have downloaded and installed the newest OpenGL renderer (beta version) and enabled some of the beta functions.
I made a map and put some Derek's weapons in it to test my graphics. I can pickup those weapons normally. If I try to put them in my hand, (f.e. if the M16 was in slot "3", and if I pressed 3), the game crashes and I get the following error:
Some weapons, thou, not a-lot, work without any crashing:
(Screenshot messes up the graphics, better in-game)
Any help would be appreciated, thanks.
Postby clyzm » Mon Jul 28, 08 9:03 pm
Do the weapons work utilizing DirectX as well?
Postby Dex » Mon Jul 28, 08 9:10 pm
cataclyzm wrote:Do the weapons work utilizing DirectX as well?
Yes they do.
This seems to be a problem due to the beta functions of the renderer. I've disabled them and it works.
Should I use D3D9 or OpenGL for the best quality in graphics?
Postby clyzm » Mon Jul 28, 08 9:14 pm
I would say OpenGL.
Find a line that says LODBias= extending [OpenGL.drv] or something along those lines in DeusEx.ini and change it to -1.
Then play Deus Ex in the highest quality settings (change the graphic settings in-game, in the settings menu) and see if it works.
Postby Dex » Mon Jul 28, 08 9:21 pm
Highest Quality Settings in the menu already set to highest.
It's because of the EnablePatch= line which enables the beta functions.
Not really much of a change with or without it turned on.
It turns out your weapons have too amazing and powerful graphics that the renderer doesn't support them quite well :lol:
Postby clyzm » Mon Jul 28, 08 9:32 pm
Dextruktor wrote:Highest Quality Settings in the menu already set to highest.
Can you please PM me the highest quality settings you set? Appreciated. :)
Postby Shinobi » Mon Jul 28, 08 11:10 pm
Bear in mind the renderers aren't actually supported in the editor.
Postby Dex » Mon Jul 28, 08 11:13 pm
I didn't say I had any problems with the editor........
