Binding help..
Binding help..
Postby ~DJ~ » Sat Aug 09, 08 10:18 am
Okay... i am trying to make this Bind but its not working.. Any help?
Aliases[18]=(Command="ActivateBelt 9|onrelease ParseLeftClick|Activatebelt 2|Duck|Fire",Alias=MedKit)
I Am aliasing it as medkit.. But when i did it H=Medkit and pressed it in game.. It only fires..
Can anyone help me out there? :)
Postby Professor Layton » Sat Aug 09, 08 10:53 am
You can't just take out a medkit, use it, take out a weapon, crouch and then fire with the weapon, all with one bind.. Taking out the medkit takes time, but so does taking out the weapon, thus you cant go firing around with the weapon yet as you'll need to wait for the weapon to come fully out.
Furthest you could go is to have a bind, that takes out the medkit, uses it, and takes out a weapon (Mind you, that bind IS buggy and will not work properly in laggy conditions) If you want I could copy that bind here.. just let me know.
Postby ~DJ~ » Sat Aug 09, 08 10:57 am
Alright.. Sure copy it here :)
Postby Professor Layton » Sat Aug 09, 08 11:03 am
Aliases[18]=(Command="ActivateBelt 9|onrelease ParseLeftClick",Alias=MedKit)
H=ParseRightClick|ParseRightClick|MedKit|OnRelease ActivateBelt 2
