Abismal Packetloss
Abismal Packetloss
Postby -HDD21- » Mon Jan 05, 09 6:28 pm
Hi all. Im posting about a packetloss problem in DeusEx. (and unreal for that matter).
We had a power outage, and upon power returning went for a game of DX.
50-80% packetloss at all times. Its only on this PC. Its wireless is fine, but with ethernet it does this. Im starting to think a small surge may have trashed the ethernet card (please no, onboard the motherboard).
No other faults have occoured. I dont have a spare ethernet card to try, (an old ISA one, but NO ISA SLOTS HERE!). Voice chatting is also extremely dodgy, assuming because of lost packets. This PC i built myself,not a single problem until today. I do take the following precations:
Surge protectior, Ground fault interrupter outlet (the protecter was like £40 itself), Good quality powersupply, phone line surge protection. (my parents dont know crap about this, i do all this stuff :P)My server machine is showing no ill effects, and DX works without flaw on it. Narrowing it down. P.S The motherboards warrenty expires in feb. I can replace it, but i dont want to waste time unnecisarily. Also ive tried Clearing CMOS, removing all non essential expansion cards. Any other stuff you suggest i try?
Many thanks.
-HDD21-
Postby Jon » Tue Jan 06, 09 1:05 pm
Did you have the ethernet cable plugged in when you lost power?
Postby KillerZ » Tue Jan 06, 09 1:19 pm
Make sure it's not the cable itself that is damaged
Try the cable elsewhere :)
KillerZ
Postby -HDD21- » Tue Jan 06, 09 7:03 pm
Yeah i did.
Also i tried the cable on the server machine, it works fine. No problems there
-HDD21-
Postby Fatman » Tue Jan 06, 09 9:31 pm
you could just pick up either a USB to Ethernet Or a PCI to Ethernet card so u dont have to pick up a new motherboard
Fatman
Postby -HDD21- » Tue Jan 06, 09 11:27 pm
Yeah ill do that instead. But as MBs under warrenty mightaswell get it replaced. I looked very close, and i see visble charring and scorching. You have to look very closely. its around the ethernet socket. So ill just take the motherboard for a replacement. Many thanks for all the help guys :)
-HDD21-
