DXWeaponSelector
DXWeaponSelector
Postby -HDD21- » Tue Sep 01, 09 10:54 pm
Hi all. This is directed at tech heads from Deus Ex,
It is a problem with Deus Ex weapon selector.
I have set all the required settings in mutators.ini (i.e no geps etc)
and referenced it in DXMTL.ini.
I cant access the command line for the server starter, not sure if id have to anyway...
none of the changes appear to take effect, i.e geps still there etc.
Any help would be appreciated.
Many thanks.
-HDD21-
Postby Dae » Wed Sep 02, 09 6:34 pm
I dunno, if you attached all .ini's, it'd be easier to find a solution.
I don't think I've ever used the Mutators menu that DXMTL adds to Deus Ex, I always activated such mutators using a Mutator= parameter specified in the .bat that launches the server (deusex.exe DXMP_Smuggler?gametype=... etc)
Edit: also check if the mutator is turned on! As far as I remember there was something like bOn in Mutators.ini.
Postby Professor Layton » Wed Sep 02, 09 7:03 pm
ye something like bInitialized
Postby -HDD21- » Wed Sep 02, 09 8:43 pm
here are inis, mind you i dont have access to the ocmmand line with this server
Mutators.ini
(722 Bytes) Downloaded 354 times
DXMTL.ini
(698 Bytes) Downloaded 364 times
DeusEx.ini
(10.82 KiB) Downloaded 360 times
-HDD21-
Postby D13GO » Thu Sep 03, 09 12:03 am
I STOLE UR DX INI LOLOLOL :!: :!: :!:
D13GO
Postby Dae » Fri Sep 04, 09 8:22 pm
As far as I can see, you're missing some ServerPackages and ServerActors in DeusEx.ini for MTL and mPack1. I can tell more when I transfer my old DX folder to the current computer.
Postby ~DJ~ » Fri Sep 04, 09 8:50 pm
Reinstall DXMTL, best solution!
