MTLColorPatch.exe error
Postby Vexus » Sat Oct 17, 09 10:51 pm
I downloaded the mtlcolorpatch.exe to enable colors on my server, but for some reason it gives me this error:
any idea how to fix it?
p.s. Hi Noodz :P
ShadowRunner wrote:lol, the mayhem of this thread is huge...
~][FGS][Nobody~ wrote:Is there anything I can put in your mouth to make you stop talking rubbish? :-s
anax wrote:wow you are amazing. like this woman
http://www.youtube.com/watch?v=bl4B9NA-NLE
[FGS]Kalman wrote:Lol I thought for 2-3 months everybody talks like a sir here, then I realised it's the forum's censorship
Vexus
Postby Hanover Fist » Sat Oct 17, 09 10:52 pm
Restart in MS DOS, type delete win.
Hanover Fist
Postby Vexus » Sat Oct 17, 09 11:01 pm
Try not to post if you can't really help.
kthxbai. :D
Vexus
Postby Dae » Sat Oct 17, 09 11:09 pm
You're running Kaspersky which gives a false alarm on some of Nobody's programs.
Kaspersky online scanner.gif (40.59 KiB) Viewed 9945 times
Postby Vexus » Sat Oct 17, 09 11:17 pm
But I'm not running kaspersky, I don't even have that.
Vexus
Postby Dae » Sat Oct 17, 09 11:21 pm
Then what antivirus you are running?
Postby Vexus » Sat Oct 17, 09 11:22 pm
None atm, I'm pretty sure.
Vexus
Postby ~ô¿ô~Nobody~ » Sat Oct 17, 09 11:40 pm
It's a strange thing with the virus warning on this patch though... all other patches don't have it... :?
But your message is no error message of the problem.. the cause must be located at your system.. :?
Postby Vexus » Sat Oct 17, 09 11:41 pm
So whut do I do?
Vexus
Postby ~DJ~ » Sat Oct 17, 09 11:53 pm
Same ol' XP problem.
I have one conclusion..
If the patch is an .exe, and then you accidently turned off your windows or something else, or it couldn't run for some reasons.. it got corrupted.
The only reason I can tell you is to...
simply delete it..
I know that it'll say "Access denied"
You'll have to terminate "Explorer.exe" from your processes, and then start a new task, type "CMD" and head towards the folder where the MTLColorPatch is, by a command called "CD"
For example:
"cd C:\DeusEx\System\"
Then just press DIR, or if you know the exe's name.. type
del "EXECUTEABLE NAME"
(quotations recommended if the file has spaces in it's name)
And then simply start "Explorer.exe" task again.
After it is deleted, re-download the color patch, and simply run it.
That SHOULD fix. :oops:
Postby Hanover Fist » Sun Oct 18, 09 1:48 am
Vexus wrote:Try not to post if you can't really help.
kthxbai. :D
Don't post at all if you're not yet out of gradeschool and have the tendency to piss me off. You shit kicking ringworm.
Hanover Fist
Postby Vexus » Sun Oct 18, 09 2:41 am
kthxbai. :D
Just don't post at all.
kthxbai.
Also, problem wasn't really solved, but Nobody gave me the patched dxmtl152b1.u file, so it works like it should anyway. LOCK REQUESTED
Vexus
Postby Hanover Fist » Sun Oct 18, 09 10:19 am
kthxbai doesn't make me go away. The admins warning me to a ban does. You're still a fag.
Hanover Fist
