DX Server start on computer bootup
Postby ~s0ap~ » Mon May 17, 10 12:51 am
Is it possible to have my dx server automatically start on my computer bootup? I'm at school for half the day, and my computer gets turned on alot when im not at home. So if its possible could you post how to do it?
~s0ap~
Postby MainMan » Mon May 17, 10 1:09 am
yeah just make the server starter script run at startup
Postby Dae » Mon May 17, 10 5:57 am
You need to create a batch file to start it and then drag and drop it into Start Menu > Programs > Startup.
To create a batch file, follow the first 3 steps of the tutorial.
Paste the following into it and save it:
deusex.exe DXMP_Smuggler?Game=DXMTL152b1.MTLTeam?-server?log=server.log
You can as well change the map ("DXMP_Smuggler" part) and gametype ("DXMTL152b1.MTLTeam" part) in the code above. The code for deathmatch is "DXMTL152b1.MTLDeathmatch" (I believe).
Place the batch file in your DeusEx\System directory. From there you can drag and drop it to Startup as I said above.
Postby ~s0ap~ » Tue May 18, 10 12:49 am
Thanks Dude, except how can I make that box not pop up, or automatically close?
~s0ap~
Postby Batchy » Tue May 18, 10 2:29 am
icepick wrote:Thanks Dude, except how can I make that box not pop up, or automatically close?
Yeah brah, try this;
start deusex.exe DXMP_Smuggler?Game=DXMTL152b1.MTLTeam?-server?log=server.log
Batchy
Postby Dae » Tue May 18, 10 11:13 am
Batchy wrote:Yeah brah, try this;
How is it supposed to help? Adding "start" closes the batch window after command completion?
Postby Allan » Tue May 18, 10 12:59 pm
True, the command (DeusEx.exe) doesn't "complete" until you close it.
So, you either have to make a shortcut(s) that'll run the server(s) at startup, and then drag 'em to the Startup folder in your Start menu.
Wow, I just said Start three times in once sentence. :o
Postby Batchy » Tue May 18, 10 4:18 pm
Oh, I see.
Carry on.
Batchy
Postby DxPlayer » Tue May 18, 10 4:19 pm
exit
DxPlayer
Postby ~s0ap~ » Tue May 18, 10 11:14 pm
Adding exit to the end does not work, same with terminate and others...
Also if any of you are telling me to try a .cmd, I already did.
~s0ap~
Postby DxPlayer » Wed May 19, 10 5:28 pm
What does it say about the "Exit" command?
DxPlayer
Postby Allan » Wed May 19, 10 6:20 pm
Okay, make a Windows shortcut (right click desktop, new, Shortcut)
and type in the following:
C:\DeusEx\System\DeusEx.exe *game map*?game=*game type class* -server ini=*server ini* USERINI=*server user ini* log=*server log file*
Fill in the *this*'d bits, then run the shortcut. It should start up your server.
If it starts correctly, move the shortcut to:
Start.
All Programs.
Startup.
(not sure what this is on Vista / Win7 - have to check later.)
Restart your computer, and the server should start at startup.
Postby ~ô¿ô~Nobody~ » Wed May 19, 10 10:50 pm
You need to mention that
Needs to be replaced with the actual path.
Just noobs install DeusEx to C:\ :lol:
Postby ~DJ~ » Thu May 20, 10 12:11 am
so am i a noob
Postby ~ô¿ô~Nobody~ » Thu May 20, 10 12:39 am
Well, in order NOT to break the axiom, you need to move DeusEx to somewhere else now. :o
Postby ~DJ~ » Thu May 20, 10 11:49 am
It's better at C:\
Postby Professor Layton » Thu May 20, 10 1:29 pm
mine's at L:\
Last edited by Professor Layton on Thu May 20, 10 1:30 pm, edited 1 time in total.
Postby ~ô¿ô~Nobody~ » Thu May 20, 10 1:46 pm
L:\ is cool
I got it on E:\ like dEusEx :o
Postby Shinobi » Wed Apr 20, 11 2:26 pm
Right, serious question dickz.
My serverstarter batch file:
@echo off
:start_server
echo Starting Shinobi Server
DEUSEX.EXE DXMP_CTF_Zan-Goh?Game=miniMTL222.miniMTLCTF?Mutator=mPack1.DXWeaponSelector?-server?log=server.log
GOTO start_server
How would I go about making this startup on computer boot (all users, please, not just my account)?
I also need it hidden. As in NO windows popping up. It is possible??
