Sound crackling
Sound crackling
Postby Allan » Fri Nov 26, 10 6:03 pm
Something that's been bugging me for ages, yet I thought was isolated only to my computer TBH.
When I load up DX, the sound will intermittently start making a horrid crackling on loud noises (Imagine someone screwing up a crisp packet near your ear, that kinda noise).
The problem persists regardless of which version of DX I use, and what game-mode (DXMTL, standard DX, etc etc) I run DX through. Anyone got any ideas how to fix this?
I has attached my DX.ini for you to have a look at if required. Kay-thanks. :3
DeusEx.ini
(8.64 KiB) Downloaded 361 times
Postby Professor Layton » Fri Nov 26, 10 7:37 pm
I don't know if you have it every time... but sometimes i ended up rebooting dx about 10 times to get the game without crackling. Don't know any proper fix for it though.
Postby ~DJ~ » Fri Nov 26, 10 7:48 pm
yep, happens to me. Have to relaunch DX.. sometimes multiple times.
Postby ~Blade~ » Fri Nov 26, 10 7:58 pm
Never had this before ...
Just curious, whats your sound sample rate thingy set to? (44100Hz?) Not sure if that will make a difference though :D.
THC
Well go grab a baseball bat and do something about it.
~Blade~
Postby Hanover Fist » Fri Nov 26, 10 10:43 pm
This happens to me all the time. I don't know the cause, but I usually just put up with it until it straightens itself out. This normally takes about 5 minutes or so.
It may have something to do with the amount of Hz the sound is set to. I can only speculate.
Hanover Fist
Postby synthetic » Sat Nov 27, 10 3:58 am
Only happens to me on the newer hardware set up. Old PC builds I had never experienced the problem. I reboot dx just like the people above, indeed it doesnt always immediately fix it.
Postby Allan » Tue Nov 30, 10 2:51 pm
I always use 44,100Hz quality, myself.
Postby ~s0ap~ » Mon Dec 27, 10 7:09 pm
I use top quality sound too. I have 4 tweeters, 2 mid-pitch, and a sub-woofer hooked up to my PC. Still get crackling.
~s0ap~
