Unreal Editor And Starting Deus Ex
Postby Guest » Thu Nov 11, 04 8:16 pm
I reinstalled Deus Ex so that I could use Unreal Editor 2 but when I had finished that box you know that appears the first time you play Deus Ex after installing it after it the computer says please insert Deus Ex and press ok but the disc is already in and i have cleaned it, restarted computer and almost everything else i can think of please help me.
ALSO
I tried going on to uneal editor 2 but it says assertion failed please help me with it too.
Guest
Postby AlexDenton » Fri Nov 12, 04 12:43 am
ppl have probelsms with UEd 2 cos they dont read the ReadMe properly
please make sure that ALL the files are in the abseloutly correct locations
it may be a little confusing
also, the original SDK problem with the GOTY edition of DX can be easily fixed by simply re-installing the game
and if the Disk is faulty to this
open the File from the directory
C:DeusExSystem
called DeusEx.ini
find the line that says
CDPath=D: (or whatever drive u use)
change that line to
CDPath=
or
CDPath=..
and the disk is no longer needed
AlexDenton
Postby ynnaD » Fri Nov 12, 04 8:53 am
Wow thanks Alex you know ur stuff :D
Postby ynnaD » Fri Nov 12, 04 8:54 am
O by the way just to let u know this is my topic
Postby AlexDenton » Fri Nov 12, 04 7:40 pm
lol np mate
others know more than me tho
i just like helping ppl
AlexDenton
Postby ynnaD » Fri Nov 12, 04 7:54 pm
ty mate so if i delete that cd path thing I NEVER NEED TO USE DISK EVER AGAIN
Postby AlexDenton » Fri Nov 12, 04 8:06 pm
yeh
but dont make the mistake and delete the whol line
make it
CDPath=..
some ppl make an error and delete the entire line, making the game unplayable... and they hav 2 re-install again lol
AlexDenton
Postby ynnaD » Sat Nov 13, 04 4:32 pm
Lol idiots but if u do that and put in the disc will it run anyway or can it run with and without disc
Postby Marouku » Sat Nov 13, 04 7:57 pm
(DXM)007 wrote:Lol idiots but if u do that and put in the disc will it run anyway or can it run with and without disc
you can run it either way
Marouku
Postby Jeoh » Mon Nov 15, 04 9:10 am
thanks :D so um should i close thi topic now?
Jeoh
Postby ynnaD » Mon Nov 15, 04 9:10 am
OMG I KEEP FORGETTING TO LOG IN
Postby Bobo. » Mon Nov 15, 04 3:51 pm
I will lock it for you
Bobo.
