GUYS HELP ME!!
GUYS HELP ME!!
Postby [A]CäS » Thu Jan 27, 05 4:22 pm
Need little help ... i now got wireless internet, thats means 2 routers 2 firewalls and 2 ip adresses ....
I have opened the ports in both routers, but i thin the 2 ip adresses make the connection confused ..... so the deus ex server wont show on the internet....
plz help me
Thanks
[A]CaS
[A]CäS
Postby AlexDenton » Thu Jan 27, 05 6:47 pm
wait, why ahve you got 2 IPs?
you only have 1 WAN (internet connection) right?
therefore, you should use that connection's IP in order to connec to the world wide web
inside your network, those 2 other IPs apply, but in the in the WWW, they mean nothing because they are only used in the LAN you have
find you internet connection IP and use it for connections
AlexDenton
Postby kBo » Thu Jan 27, 05 10:59 pm
Give me your physical address so I can wardrive of of your WAN. :P
Just kidding. Doesn't seem like that should cause the DX server not to show... have you tried looking for other stuff that may have caused it?
kBo
Postby Jeoh » Fri Jan 28, 05 7:58 am
You only need 1 router right?
Jeoh
Postby [A]CäS » Sat Jan 29, 05 1:35 am
GeneralJeoh wrote:You only need 1 router right?
No, i need two i dont got tcp/ip cabel anymore...hehe.
I have tryed everythin.
I got one internet connection. but i got a hub in a other room and i got wireless connection in my room.and that wireless connection is one more hub/switch. ... new ip adress
[A]CäS
Postby DarkKnight » Sat Jan 29, 05 9:51 am
Have you tried forwarding the right ports to your server in -both- routers...?
Postby [A]CäS » Sat Feb 05, 05 5:33 pm
what do ya mean?
[A]CäS
Postby Grayfox » Sun Feb 06, 05 3:16 am
Port fowarding is the correct term for what you call "opening the ports"
Grayfox
Postby DarkKnight » Sun Feb 06, 05 4:32 am
[A]CaS wrote:what do ya mean?
You only need to do this on your router with the internet connection, go into the router config menu (consult your router handbook) and forward the ports DX needs to the network IP of your server.
If you don't do this then all DX server traffic will be ingored.
(Also, try looking in the LAN game area of DX to see if your server is there.)
Postby [A]CäS » Sun Feb 06, 05 1:50 pm
i have done that..... dont work ... :(
Grayfox wrote:Port fowarding is the correct term for what you call "opening the ports"
sry, im not english...!
Please do not double-post. ~GeneralJeoh
[A]CäS
