UnrealEd problem...
UnrealEd problem...
Postby Icarus » Sat Feb 26, 05 2:28 am
Icarus
Postby Alex » Sat Feb 26, 05 9:25 am
Is that everytime that you load it?
Postby Jeoh » Sat Feb 26, 05 11:09 am
Re-install Deus Ex and UEd.
Jeoh
Postby Icarus » Sat Feb 26, 05 4:24 pm
it's not a problem with ued or dx, i made 2 dx.ini's , one i put all the mods i have in the editpackages so i could use them in ued, so its something to do with mods, i could post my editpackages list ?
Icarus
Postby Alex » Sat Feb 26, 05 5:41 pm
why the hell make 2 deusex.ini's? just keep it to one, i think then ur prob. is solved.
Postby AlexDenton » Sat Feb 26, 05 7:47 pm
GeneralJeoh wrote:Re-install Deus Ex and UEd.
he's right
its your best bet
i had problems with UEd, and by simply re-installing it... the problem was solved
AlexDenton
Postby Bob » Sat Feb 26, 05 9:21 pm
If you have Mtl installed, re-install that too.
It is know to conflict with the basic editor
Postby kBo » Sun Feb 27, 05 1:44 am
It has something to do with a variable (ScriptText) in a subclass (MTLPlayer) of MTL v1.5.2 beta 1 (DXMTL152b1), so try removing all traces of that in DeusEx.ini and deleting the actual .u package in your system directory. Then re-install MTL and report back.
Seriously though, did any of you guys even READ the message?
kBo
Postby Dae » Sun Feb 27, 05 11:45 am
Next time you say this on tech problems, i'll simply delete the message. It's better to shut up if the only thing you know is this incompetent solution.
Icarus
No need to reinstall something. No need to remove mtl. Let's better explore a reason.
I recommend you doing these things:
1. Post editpackages list here.
2. Remove all mods you've added. Then, try loading each one manually (go to Browse > Classes, then, load button, where you select what to load) and explore which package is the cause of the conflict.
3. Post the problematic mod's name here.
Postby Jeoh » Sun Feb 27, 05 1:18 pm
It works. It's a solution to his problem. Ofcourse, if you want him to do 23.999~ things before finding his problem out, be my guest.
Jeoh
Postby Dae » Sun Feb 27, 05 4:13 pm
Aha, next time advise formatting C:/ :lol:
Postby AlexDenton » Sun Feb 27, 05 4:27 pm
seriously
what is the point in making this difficult when simply re-installing the program (which takes 5 mins) would sort it all in no time with little effort
AlexDenton
Postby Jeoh » Sun Feb 27, 05 4:34 pm
Wouldn't fix the problem, would only make it worse. Formatting is only to be used if your OS no longer works.
Jeoh
Postby Icarus » Wed Mar 02, 05 4:24 am
alright. i had uninstalled dxmtl before cuz i figured it had something to do with that from the error (didnt get rid of the .u file though) , and i have 2 ini's cuz, one works, one doesnt so i have one to backup to, my editpackage's list is quite lenghty, i like modded weapons :P :D (thinkin about making a simple map with every modded weapon i have , 100's ! :D ) i'll try re-installing Unreal ed in a minute and i'll tell yeah how it works, for now here's my editpackages list -
Editpackages=ww
Editpackages=weaponstunrifle
Editpackages=weaponlord
Editpackages=weapon
Editpackages=ufobeam
Editpackages=tyrinoxiii
Editpackages=trigun
Editpackages=tnag
Editpackages=tnagmapconversion
Editpackages=thehqmod
Editpackages=teleportermod
Editpackages=targetgenerator
Editpackages=t-369
Editpackages=switcha
Editpackages=superrocket
Editpackages=stereo
Editpackages=starwars
Editpackages=sparkler
Editpackages=smg_mod
Editpackages=slotmachine
Editpackages=sheepmutators
Editpackages=securekeypad
Editpackages=sclan
Editpackages=pyrotechnics
Editpackages=poolparty
Editpackages=palmtree
Editpackages=nphase
Editpackages=nc
Editpackages=mpkeypad
Editpackages=mpcharacters
Editpackages=mpbots
Editpackages=mpack1
Editpackages=moop
Editpackages=mmskinsv01
Editpackages=mm
Editpackages=minimtl143
Editpackages=lowweapons
Editpackages=leftleakin
Editpackages=kou2
Editpackages=jsg
Editpackages=hellfire
Editpackages=godzfireworks
Editpackages=funlinecorer1
Editpackages=fm
Editpackages=flserversv3
Editpackages=flkeypad
Editpackages=flkeypad2
Editpackages=flibzone
Editpackages=flibmods
Editpackages=flclothes
Editpackages=fireworklauncher
Editpackages=fireworklaunchernew
Editpackages=fire
Editpackages=exp-w
Editpackages=dtriv
Editpackages=dtriii
Editpackages=dtrii
Editpackages=dtrcrate
Editpackages=disseromod
Editpackages=deusexml
Editpackages=deathawaitsthou
Editpackages=darkforce1
Editpackages=daft
Editpackages=d12
Editpackages=cyanmatrix
Editpackages=caroneelevatorset
Editpackages=boompigeon
Editpackages=bomb
Editpackages=bleater100
Editpackages=bkjm
Editpackages=bandit
Editpackages=atdm
Editpackages=armymod
Editpackages=arbb
Editpackages=aradmin
Editpackages=am
Editpackages=alrightys
Editpackages=alrightypad
Editpackages=alrightygame
Editpackages=amtest
Editpackages=akpad
Editpackages=akimboweapons
Editpackages=aa
Editpackages=healweapons
Editpackages=pigeon
Editpackages=somemod2
maybe one of the mod's conflict's with MTL ?
Icarus
Postby kBo » Wed Mar 02, 05 10:46 pm
Anything that messes with the Player class, as MTL makes a new Player class (MTLPlayer) will screw it up.
kBo
