Server problems
Server problems
Postby Saradin » Wed Jun 08, 05 9:32 pm
DXMTL: DeusExLevelInfo Repaired!
Log: Loading: Package DeusExConText
ScriptLog: UdpServerUplink: Could not find a UdpServerQuery object, aborting.
Init: Game engine initialized
Log: Startup time: 3.184943 seconds
Log: CBPWeaponRifle0 fell out of the world!
Log: WLog::OnCommand ID_NotifyExit
Log: appRequestExit(0)
Exit: Preparing to exit.
Could someone please tell me how to fix this?
Saradin
Postby Alistair » Wed Jun 08, 05 9:34 pm
Copy your default.ini into deusex.ini | Start over installing the UDP Server Query patch.
Postby Saradin » Wed Jun 08, 05 9:55 pm
ok now I have the following problem
ScriptLog: UdpServerQuery: Port 7791 successfully bound.
Log: Resolving master0.gamespy.com...
Log: Resolving master.epicgames.com...
Log: Resolving master.fragaholic.com...
Log: Startup time: 3.079126 seconds
Log: WeaponRifle1 fell out of the world!
Log: Resolved master0.gamespy.com (207.38.11.34)
ScriptLog: UdpServerUplink: Master Server is master0.gamespy.com:27900
ScriptLog: UdpServerUplink: Port 7792 successfully bound.
Log: AInternetLink Resolve failed: Can't find host master.epicgames.com (WSANO_DATA)
ScriptLog: UdpServerUplink: Failed to resolve master server address, aborting.
Log: AInternetLink Resolve failed: Can't find host master.fragaholic.com (WSANO_DATA)
Saradin
Postby ~ô¿ô~Nobody~ » Wed Jun 08, 05 10:15 pm
i see no problem...
that the other 2 master servers are offline is just normal
Postby Saradin » Wed Jun 08, 05 11:42 pm
Well I am unable to see my server, I thought that there was a problem still showing in the log.
Saradin
Postby Alex » Thu Jun 09, 05 7:08 am
Try instead of Internet Game, Lan Game(If you see your game there) If you do, or if you don't :P i think you have a router..?
Postby Dae » Thu Jun 09, 05 8:11 am
Saradin
in some cases you may not find your server in the internet server list but the rest of people can see it. So, connect to your server via LAN.
Postby ~ô¿ô~Nobody~ » Thu Jun 09, 05 3:24 pm
if you have a router you neve see your own server in the internet list
you can join it by clicking to lan game and clicking to your server there
however.. the others can just see your server if you said the router that certain data on certain ports needs to be send to a certain IP (the IP of your DX server PC)
that's also called port fortarding or redirection
Postby Alex » Thu Jun 09, 05 5:11 pm
~[A]Nobody~ wrote:if you have a router you neve see your own server in the internet list
I can see my server in internet list...
Postby ~D[A]rren~ » Thu Jun 09, 05 5:15 pm
Mate, one word, Bullshit. :) You just need to learn to configure your router properly. Its port forwarding, on the newer routers they have "UPnP" Which basically is universal plug and play which means that certain programs which use UPnP don't need a manual port forward configured, However, DX does need it doing manually. So all you should do in your router (Depending how good your router UI is) is type in the ports, name them something and set them up to allow always and to send to your networked computer IP address that your using DX on.
JC
Postby Saradin » Thu Jun 09, 05 7:48 pm
I believe I got it working, I hosted a LAN game and I was able to see it on my LAN list and connection. I hosted an Internet game just now and I was able to see it through the LAN game list.
Thank you for all the help.
Saradin
Postby Alex » Thu Jun 09, 05 7:59 pm
Well, first ask your friends, if they can see it.
Postby Saradin » Thu Jun 09, 05 8:05 pm
ok I'll get them to check, also where can I find the lastest MiniMTL?
Saradin
Postby ~ô¿ô~Nobody~ » Thu Jun 09, 05 8:21 pm
~D[A]rren~ wrote:Mate, one word, Bullshit. :)
don't see any bullshit...
now you only repeated the same that i said just with the difference that you mentioned something that DX doesn't support anyways :roll:
Postby kBo » Thu Jun 09, 05 9:37 pm
JC
UPnP is evil anyways.
kBo
Postby Saradin » Thu Jun 09, 05 10:19 pm
I got some people to check but they didn't see it. What do I need to do in order to fix this?
Saradin
Postby Jeoh » Sat Jun 11, 05 8:56 pm
leet hax
Jeoh
Postby Saradin » Sun Jun 12, 05 7:30 pm
No really, what do I need to do? I'd like to be able to host a server for people to play on.
Saradin
Postby ~ô¿ô~Nobody~ » Sun Jun 12, 05 8:56 pm
the problem is that noone can really help you remotely...
i can tell you what ports you have to forward in your router but i can'T really tell you how you do it because i neither know if you know what i want of you nor i'm familiar with the user interface of your router
Postby Saradin » Mon Jun 13, 05 3:46 pm
It's a AMBIT DOCSIS 2.0 Cable Modem, if that helps.
Saradin
