OK I HAVE A BIG PROBLEM!!!!!
Postby Gishank » Fri Jan 27, 06 8:14 pm
Ok, i can't host in the log box it says where it connects to the master server....
Script Log: UdpServerUplink: Could Not Find a UdpServerQuery object, aborting.
Help Me Please.
[/quote]
Postby Alex » Fri Jan 27, 06 8:18 pm
Try placing DXIPServer/IPServer.u in your system folder, and next time, don't delete/edit it.
Postby Gishank » Fri Jan 27, 06 8:19 pm
Firstly i haven't tried editing/deleting it and if that file is missing i need someone elses copy please.
Postby Rödewijk » Fri Jan 27, 06 8:23 pm
here stupid
DXIPServer.u
(14.95 KiB) Downloaded 287 times
Postby Gishank » Fri Jan 27, 06 8:26 pm
That file wasn't the problem. :(
Postby Dae » Fri Jan 27, 06 8:34 pm
DXIPServer.u is not IPServer.u.
IPServer - original file.
DXIPServer - fixed version by Smuggler.
IpServer.u
Original IPServer.u from Deus Ex GOTY
(28.63 KiB) Downloaded 300 times
IpServer.int
(301 Bytes) Downloaded 279 times
Postby Gishank » Fri Jan 27, 06 8:36 pm
Ok G2G i will post later if it works.
Postby Gishank » Sat Jan 28, 06 10:05 am
IT DIDN'T WORK!
P.S:Sorry for the double post.
Postby Dae » Sat Jan 28, 06 3:58 pm
Post here your [DeusEx.DeusExGameEngine] section from DeusEx.ini.
Postby Gishank » Sat Jan 28, 06 4:20 pm
ok here it is.....
CacheSizeMegs=16
UseSound=True
ServerPackages=DXMTL152b1
ServerActors=IpDrv.UdpBeacon
ServerActors=UWeb.WebServer
ServerActors=IpServer.UdpServerUplink MasterServerAddress=master.godzserver.com MasterServerPort=27900
ServerActors=IpServer.UdpServerUplink MasterServerAddress=master0.gamespy.com MasterServerPort=27900
ServerActors=IpServer.UdpServerUplink MasterServerAddress=master.epicgames.com MasterServerPort=27900
ServerActors=IpServer.UdpServerUplink MasterServerAddress=master.fragaholic.com MasterServerPort=27900
ServerActors=MMSkinsV01.SkinsMutator
ServerPackages=DXMapVote100
ServerPackages=KULTIMA
Postby Dae » Sat Jan 28, 06 4:33 pm
Add
ServerActors=IpServer.UdpServerQuery
somewhere there.
Postby Gishank » Sat Jan 28, 06 4:40 pm
OK testing now.
EDIT:Nope still isn't working
Postby Dae » Sat Jan 28, 06 4:45 pm
0_o
odd
also try adding IPServer to EditPackages= in DeusEx.ini
and... what does it say? the same message?
Postby Gishank » Sat Jan 28, 06 4:48 pm
That lines alreadyu in editpackages :-S
Postby Alistair » Wed Feb 08, 06 5:40 pm
DXIPServer
Postby Gishank » Sun Feb 12, 06 10:05 am
Nope, someone please fix this i beg of you.
Postby IchoTolot » Sun Feb 12, 06 2:15 pm
rebuild your deusex.ini (delete deusex.ini and start the game)
IchoTolot
<i>Very</i> Friendly Clown
Location: Quad 1,0,0 - 3th Planet - 50.6909 North - 11.5947 South
Postby Wasted » Sun Feb 12, 06 4:39 pm
Or copy ur user ini, adn then reinstall ur whole game.
btw
*Cheers* WOOOO
Postby ~ô¿ô~Nobody~ » Sun Feb 12, 06 5:41 pm
~Wasted~ wrote:Or copy ur user ini, adn then reinstall ur whole game.
btw
*Cheers* WOOOO
beside this is pointless.. this is the whole opposite of that what icho said :roll:
Postby Wasted » Sun Feb 12, 06 6:30 pm
Meh, it would work.
Postby Gishank » Mon Feb 13, 06 9:51 am
Dip Shit, when i tried fixing my SDK after it said DX wasn't installed.
Postby Wasted » Mon Feb 13, 06 8:42 pm
Knock yourself out
Postby Gishank » Tue Feb 14, 06 9:44 am
Wasted, please shut up because your being as the old saying went...
"Gay leik Jay"
Postby IchoTolot » Tue Feb 14, 06 11:28 am
<~>K}Ã?Ã?<~> wrote:Dip poop, when i tried fixing my SDK after it said DX wasn't installed.
wrong deus ex path(not C:Deus Ex... but D:Deus EX....) or forgot you the registry ?
IchoTolot
Postby Gishank » Tue Feb 14, 06 11:41 am
D: is my CD Rom/DVD Drive. :-s
