bind help
bind help
Postby Cozmo » Fri Feb 24, 06 10:40 pm
ive been making some basic binds for a while now but theres one that puzzles me.
1.im a bad sniper while in scope :lol: -i tried making one that will scope then fire then scope out again but it fires weirdly uses no ammo its rapid and does 0 damage :?
i cant see anything wrong though...
ToggleScope|Fire|ToggleScope
why dosent it work!?! ^ :evil:
2.and while im here, what does parseleftclick or parserightclick do? im want to know that. :-k
Postby Alex » Fri Feb 24, 06 10:47 pm
ParseLeftClick = Left Mouse Button Click,
You know the other one yourself :)
Postby IchoTolot » Sat Feb 25, 06 1:19 am
lol .... binds are for loosers .... i use binds(custom binds) only for name changin, adminlogin/out and altfire
*sing "im a looser baby"*
roflmfao
IchoTolot
<i>Very</i> Friendly Clown
Location: Quad 1,0,0 - 3th Planet - 50.6909 North - 11.5947 South
Postby Alex » Sat Feb 25, 06 9:44 am
I use em for AltFire, Name changing, Tantalus.
Postby Cozmo » Sat Feb 25, 06 11:34 am
~[A]lex~ wrote:ParseLeftClick = Left Mouse Button Click,
i think i figured that bit out but it sits right in the middle of a medbind i have but i dont get what it does :?
oh yeah icho, binds make dx easier. :D
Postby Wasted » Sat Feb 25, 06 11:36 am
I use some binds that involve kiling, but i have tant, opensesame and stuff like that.
Postby Splitter » Sat Feb 25, 06 11:37 am
Err it probably uses the med XD
The reason your sniper bind doesn't work is that there is a delay for scoping in on internet servers depending on your ping, so it will be clicking before you've actually zoomed in, or just missing it out all together : /
»§plíttèr/§plícè«
» ÐÇsß « » eNigma² «
Getting TK'd since 24/11/03
Splitter
Postby Cozmo » Sat Feb 25, 06 11:38 am
ah so if i put a load of crap in between like duck etc.?
Postby MainMan » Sat Feb 25, 06 11:42 am
~Cozmo~ wrote:ah so if i put a load of crap in between like duck etc.?
No, make it an alias, and change Fire to OnRelease Fire
Postby Cozmo » Sat Feb 25, 06 1:11 pm
~MainMan~ wrote:No, make it an alias,
what do u mean by that :?
Postby Wasted » Sat Feb 25, 06 1:49 pm
Well I ahve the same as mainman, and all i know is that means the lines with
Aliases[39]=(Command="",Alias=None)
Basically, You say what you want it to do in command, And name it somewthing in alias. So you jsut find a key and put your name there. For example your bind dont work but..
Aliases[39]=(Command="ToggleScope|Fire|ToggleScope",Alias=Cozmo-is-gay)
so then..
Enter=Cozmo-is-gay
*waits for someone to correct him*
Postby Cozmo » Sat Feb 25, 06 2:17 pm
oh thanks.
begins typing... "Cozmo-is-gay.. :-k ..Hey!!"
Postby Wasted » Sat Feb 25, 06 2:59 pm
lol u can name it anything you want but thats the principal, and it should work. Im beign serious.
Postby ~ô¿ô~Nobody~ » Tue Feb 28, 06 5:10 pm
you're all H4X0RS!
i'm not using such binds at all
well.. neither i've no time to play at all
Postby Wasted » Tue Feb 28, 06 10:10 pm
I like cheese cause it is really funky ANyways thats not thew point, actually there isnt a poihnt im just typing small for fun.. Anyway gorgozola is a quality cheese, although cheddaer is a wuss cheese, so i like it :) all offtopic. genius.
Postby Shinobi » Thu Oct 04, 07 1:33 pm
I can't get my med bind to work =/
I set it up as per the [A] KB. Didn't use the alias one, just ther normal one, but nope. It successfully fires my weapon in belt space 2 (assault rifle in case you care), but doesn't use the med before bringing wep 2 out.
Any help?
Postby Professor Layton » Thu Oct 04, 07 3:05 pm
Post the bind and I'll try to help out.
Postby Shinobi » Thu Oct 04, 07 3:36 pm
Alt=ActivateBelt 9|onrelease ParseLeftClick|ActivateBelt 2
Tried it with other keys, but still to no avail.
Also tried yours:
Advanced medkit bind (may have problems in lag or bad ping) — bind was compiled by Clix:
1. First create Aliases[...] bind
Aliases[23]=(Command="ActivateBelt 9|onrelease ParseLeftClick",Alias=MedKit)
2. Then find a button to bind it to. For example, button H:
H=ParseRightClick|ParseRightClick|MedKit|OnRelease ActivateBelt 1
But it screws up during laggy fights real bad.
I wanna get the first one to work.
Any help wud b appreciated.
Postby Professor Layton » Fri Oct 05, 07 9:21 am
I don't have a working DX copy atm it seems, so I just have to guess here, for now:
ActivateBelt 9|Onrelease ActivateBelt 2
What it does, is take out medkit (remember that you will have to hold it until its fully out) And once you release it, it should take out whatever you got in the second slot.
It's not a fully automatic bind, so you will have to press fire once the med is fully out, to use a medkit, then you just release the "medbutton" and you got your gun out again.
Postby Shinobi » Fri Oct 05, 07 9:40 am
Ahh. The tutorial didn't say that.
I thought that I could just press the key I bound it to (in this case Alt) and it would use my med and then pull my assaultgun out.
Thanks! q
Postby Professor Layton » Fri Oct 05, 07 10:02 am
No problem, only bind which is fully automatic is that bind which is oversensitive to lag.
Postby SnakeEater » Tue Jan 22, 08 3:31 am
how do you do say binds inn user.ini and have them stay? because i do say binds and each game and new map i always have to re put them in
The eye sore has been removed!
I really do think Deus Ex is the all-time best game ever made.
SnakeEater
Postby Dae » Tue Jan 22, 08 9:47 am
SnakeEater wrote:how do you do say binds inn user.ini and have them stay? because i do say binds and each game and new map i always have to re put them in
after editing "user.ini" save it to "defuser.ini"
Postby Kaiden » Tue Jan 22, 08 10:39 am
Postby Siva » Tue Jan 22, 08 10:54 am
I have bound every button on my keyboard to a line from a song.
Is this awesome y\n
Postby ~[R2K]D-BLOCK~ » Tue Jan 22, 08 11:17 pm
I have one bind leftclick=activate slot 8
~[R2K]D-BLOCK~
