Opening Port...?
Opening Port...?
Postby ~BlooDRaiN~ » Sat Mar 25, 06 8:06 am
umm dad is havin a cry cause he dosnt want me to open a port because he dosnt know..
1.What opeing a port does
2.Do ppl conect to the server ON my computer
3.Can ppl hack my computer and acces files/ect
if you can help it would be much apreciuated and maby i can get an australian server goin
...Blood Will Rain From The Sky's...
~BlooDRaiN~
Postby Alex » Sat Mar 25, 06 8:57 am
1. A port is more like a small opening in the protection.
2. Well, since the server is hosted on your computer, people connect to your computer.
3. Hmmm, not that I know. There aren't a lot of hackers in Deus Ex, and it is hard to actually hack. If you have a firewall, just only allow Deus Ex to connect through those ports. If anything else connects through it --> Bam, rejected.
Postby Dae » Sat Mar 25, 06 3:50 pm
I doubt hackers are really interested in hacking your computer, unless you're Bill Gates or someone else well known :P However, yes, it is possible, but if you use Windows XP service pack 2 you're less vulnerable than if you used Windows 98/ME/2000.
I recommend you to buy (or just download and crack it like we all do here) a firewall like Kaspersky AntiHacker or Agnitum Outpost Pro (the best at the moment). With a good firewall you have nothing to be afraid of.
Postby Allan » Sat Mar 25, 06 6:20 pm
... I have Outpost, and it wont let me connect to the net with it on, regardless of what i do with it :? . I prefer McAffee firewall, or something like that.
Postby kBo » Sat Mar 25, 06 6:38 pm
~[A]lex~ wrote:1. A port is more like a small opening in the protection.
Not really true. Just use this analogy to show him: You computer is like a house. Opening a well secured port is like leaving a door on the outside of the house unlocked, but that door only access one room with no other doors of valuables.
Opening a port doesn't make your computer vulnerable unless the service running on it (in this case, Deus Ex) is vulnerable because of poor coding.
~[A]lex~ wrote:3. Hmmm, not that I know. There aren't a lot of hackers in Deus Ex, and it is hard to actually hack. If you have a firewall, just only allow Deus Ex to connect through those ports. If anything else connects through it --> Bam, rejected.
Also not really true. It's very easy to hack, as long as the server you're hacking is running a vulnerable program, and almost ALL programs are vulnerable at some level if you look hard enough. The reason that people aren't getting hacked left and right isn't because it's hard to do per se, it's just that it takes a while to do it.
Now then, you only really have to worry if Deus Ex is vulnerable.
kBo
Postby Siva » Sat Mar 25, 06 6:39 pm
I recently uninstalled all my firewalls.
I'd rather just have a good virus scanner, firewalls create so much confusion.
Windows Firewall Only.
Postby Dae » Sat Mar 25, 06 8:38 pm
XII//:Prod1gy wrote:I recently uninstalled all my firewalls.
Actually it's better to have a decent firewall instead. "Confusion" is caused by lack of knowledge, right?
Postby Wasted » Sat Mar 25, 06 8:54 pm
So thats why I diont knwo the meaning of confusion. or possibly, Im jsut dumb.
Postby ~BlooDRaiN~ » Sun Mar 26, 06 12:19 am
thats alot of help guys i shal see what i can do about it all and maby there will be a australian server running sooner rather then later
~BlooDRaiN~
Postby Alistair » Sun Mar 26, 06 10:59 am
Your hosting right? So why is he crying over a UDP port??
Postby Alex » Sun Mar 26, 06 11:26 am
If you open a port, is is a small opening in the protecting. A router works some what like a firewall (Not really but ok). If you open a port, you allow connection through it.
Now you are saying 2 opposing things. You say it's not hard, but it just takes time. If it's easy, it wouldn't take a lot of time would it?
Postby ~BlooDRaiN~ » Sun Mar 26, 06 11:39 am
[T]Kon wrote:Your hosting right? So why is he crying over a UDP port??
no im not hosting yet because i odnt no what problems it could cause n stuff
~BlooDRaiN~
