Can't right click in sdk ¬_¬
Postby Gishank » Sun May 21, 06 8:38 am
Hello. For some reason i can't right click in sdk, everytime i do there is a really big lag interference and when it recives the command it doesn't work correctly. I use obodys version of SDK, can anyone help me fix it?
Postby Dae » Sun May 21, 06 8:56 am
Does this problem appear when you use normal SDK?
Postby Gishank » Sun May 21, 06 8:58 am
The proberlem only started yesterday, i have been using nobodys sdk since he uploaded it here for download. The normal sdk, i'm not sure if it does. CAn you please give me a link to nobodys version so i can replace it so it should work again, because i can't seem to find the topic.
P.S. CAn someone also give me the Ucc-make.bat, i re-formatted lol.
Postby Dae » Sun May 21, 06 9:21 am
Gishank wrote:The proberlem only started yesterday, i have been using nobodys sdk since he uploaded it here for download. The normal sdk, i'm not sure if it does. CAn you please give me a link to nobodys version so i can replace it so it should work again, because i can't seem to find the topic.
viewtopic.php?t=7039 - Nobody's
UnrealEd.rar
Normal UnrealEd.
(182.44 KiB) Downloaded 236 times
Postby Gishank » Sun May 21, 06 9:22 am
thanks dae :)
EDIT!!!!
Shh, i need the files to compile mods ffs ¬_¬
Postby MainMan » Sun May 21, 06 11:38 am
Gishank wrote:thanks dae :)
EDIT!!!!
Just use cmd.
Postby Gishank » Sun May 21, 06 11:49 am
i don't have UCC.exe ¬_¬
Plus that idea didn't work dae :(
Postby Dae » Sun May 21, 06 11:59 am
Um, I didn't understand: does your UnrealEd open at all when you click it?
And also: do you have such problems with another programs?
UccMake.rar
UccMake.bat -&gt; to DeusEx/System
(367 Bytes) Downloaded 210 times
Postby Gishank » Sun May 21, 06 12:02 pm
~[A]Daedalus~ wrote:Um, I didn't understand: does your UnrealEd open at all when you click it?
Yes it does, it's just i can't rightclick in it also...
Gishank wrote:I don't have ucc.exe
Hence i cannot run uccmake ¬_`
Postby ~ô¿ô~Nobody~ » Mon May 22, 06 6:19 pm
reinstall the SDK
and try it with unrealed or the DeusExED again
Postby Gishank » Mon May 22, 06 6:51 pm
I can't find a copy of sdk (Well not 1112fm) please help, all i can find are your version and the exe dae uploaded ¬_¬
Postby Alex » Mon May 22, 06 7:18 pm
Postby Gishank » Mon May 22, 06 7:24 pm
I did, but all i keep getting is deus ex patch 1112fm without sdk and sdk 1109 (Or something like that)
Postby Alex » Mon May 22, 06 7:27 pm
